Pokeys air leak
12-04-2006, 09:53
Pokeys air leak
OK, As I understand it, The 2 air gauges on the dash only monitor brake
air pressure (not suspension pressure). Under the bus, about in line (F to R speaking) there are 2 air tanks, one for the front brakes and one for the rear...I assume. I think there is also a "wet" tank somewhere, further toward the compressor I would guess. My LH dash gauge bleeds down many times faster than the RH one (when I shut the rig down). Now the questions: Does the LH gauge monitor the air in the LH tank (sounds logical)? Which tank is for which end brakes? (LH for front? LH for rear?) Where is the wet tank located? Thanks as always, still cold here in Gunnison, Doug Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey" |
12-04-2006, 11:32
Pokeys air leak
The front tank on the driver-side is the front brake tank (also
called secondary), the front tank on the passenger/curb side is the "wet tank", the tank in the rear is the rear brake tank or primary. Pump the brakes very lightly, only the rear gauge should drop. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" wrote: > > OK, As I understand it, The 2 air gauges on the dash only monitor brake > air pressure (not suspension pressure). Under the bus, about in line (F > to R speaking) there are 2 air tanks, one for the front brakes and one > for the rear...I assume. I think there is also a "wet" tank somewhere, > further toward the compressor I would guess. My LH dash gauge bleeds > down many times faster than the RH one (when I shut the rig down). Now > the questions: > Does the LH gauge monitor the air in the LH tank (sounds logical)? > Which tank is for which end brakes? (LH for front? LH for rear?) > Where is the wet tank located? > Thanks as always, still cold here in Gunnison, Doug > Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey" > |
12-04-2006, 13:11
Pokeys air leak
Thanks Jeff. That helps..and limits my crawling around under the bus. Doug
Jeff Miller driver-side is the front brake tank (also called secondary), the front tank on the passenger/curb side is the "wet tank", the tank in the rear is the rear brake tank or primary. Pump the brakes very lightly, only the rear gauge should drop. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" wrote: > > OK, As I understand it, The 2 air gauges on the dash only monitor brake > air pressure (not suspension pressure). Under the bus, about in line (F > to R speaking) there are 2 air tanks, one for the front brakes and one > for the rear...I assume. I think there is also a "wet" tank somewhere, > further toward the compressor I would guess. My LH dash gauge bleeds > down many times faster than the RH one (when I shut the rig down). Now > the questions: > Does the LH gauge monitor the air in the LH tank (sounds logical)? > Which tank is for which end brakes? (LH for front? LH for rear?) > Where is the wet tank located? > Thanks as always, still cold here in Gunnison, Doug > Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey" > --------------------------------- Need a quick answer? Get one in minutes from people who know. Ask your question on Yahoo! Answers. [Non-text portions of this message have been removed] |
12-04-2006, 13:42
Pokeys air leak
Jeff,
Are you saying that the rear brakes are applied first and not at the same time as the front brakes? Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > The front tank on the driver-side is the front brake tank (also > called secondary), the front tank on the passenger/curb side is > the "wet tank", the tank in the rear is the rear brake tank or > primary. > > Pump the brakes very lightly, only the rear gauge should drop. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" > wrote: > > > > OK, As I understand it, The 2 air gauges on the dash only monitor > brake > > air pressure (not suspension pressure). Under the bus, about in > line (F > > to R speaking) there are 2 air tanks, one for the front brakes and > one > > for the rear...I assume. I think there is also a "wet" tank > somewhere, > > further toward the compressor I would guess. My LH dash gauge > bleeds > > down many times faster than the RH one (when I shut the rig down). > Now > > the questions: > > Does the LH gauge monitor the air in the LH tank (sounds logical)? > > Which tank is for which end brakes? (LH for front? LH for rear?) > > Where is the wet tank located? > > Thanks as always, still cold here in Gunnison, Doug > > Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey" > > > |
12-06-2006, 12:09
Pokeys air leak
It's been a while, I'll dig into the memory banks.
Two things are at work here: First, the front brakes on FCs and PTs are 20"sq and the rears are 30"sq, so the rear brakes will use air at 150% of the rate of the fronts (both tanks are the same size) even with the same application pressure. Second, the '78 I believe has a valve (can't remember the name of the valve) which delays front brake application until the main/rear brakes exceed a set psi (memory tells me it something like 30psi). Not sure when it changed, but this was to avoid front wheel lockup in slippery conditions, common on older trucks. In later designs ratio valves replaced these valves. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > > Jeff, > Are you saying that the rear brakes are applied first and not at > the same time as the front brakes? > > Gardner > 78FC33 > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > > > > The front tank on the driver-side is the front brake tank (also > > called secondary), the front tank on the passenger/curb side is > > the "wet tank", the tank in the rear is the rear brake tank or > > primary. > > > > Pump the brakes very lightly, only the rear gauge should drop. > > > > - Jeff Miller > > in Holland, MI > > > > > > --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" > > wrote: > > > > > > OK, As I understand it, The 2 air gauges on the dash only > monitor > > brake > > > air pressure (not suspension pressure). Under the bus, about in > > line (F > > > to R speaking) there are 2 air tanks, one for the front brakes > and > > one > > > for the rear...I assume. I think there is also a "wet" tank > > somewhere, > > > further toward the compressor I would guess. My LH dash gauge > > bleeds > > > down many times faster than the RH one (when I shut the rig > down). > > Now > > > the questions: > > > Does the LH gauge monitor the air in the LH tank (sounds > logical)? > > > Which tank is for which end brakes? (LH for front? LH for rear?) > > > Where is the wet tank located? > > > Thanks as always, still cold here in Gunnison, Doug > > > Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey" > > > > > > |
12-06-2006, 13:43
Pokeys air leak
Jeff,
Thank you for the explanation. Now I think understand why I had problems with the front brakes grabbing when the rear brakes were way out of adjustment. Since I had the rears set properly the whole braking experience is significantly better. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > It's been a while, I'll dig into the memory banks. > > Two things are at work here: > > First, the front brakes on FCs and PTs are 20"sq and the rears are > 30"sq, so the rear brakes will use air at 150% of the rate of the > fronts (both tanks are the same size) even with the same application > pressure. > > Second, the '78 I believe has a valve (can't remember the name of > the valve) which delays front brake application until the main/rear > brakes exceed a set psi (memory tells me it something like 30psi). > Not sure when it changed, but this was to avoid front wheel lockup > in slippery conditions, common on older trucks. In later designs > ratio valves replaced these valves. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" > wrote: > > > > > > Jeff, > > Are you saying that the rear brakes are applied first and not > at > > the same time as the front brakes? > > > > Gardner > > 78FC33 > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > > > > > > > The front tank on the driver-side is the front brake tank (also > > > called secondary), the front tank on the passenger/curb side is > > > the "wet tank", the tank in the rear is the rear brake tank or > > > primary. > > > > > > Pump the brakes very lightly, only the rear gauge should drop. > > > > > > - Jeff Miller > > > in Holland, MI > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" > > > wrote: > > > > > > > > OK, As I understand it, The 2 air gauges on the dash only > > monitor > > > brake > > > > air pressure (not suspension pressure). Under the bus, about > in > > > line (F > > > > to R speaking) there are 2 air tanks, one for the front brakes > > and > > > one > > > > for the rear...I assume. I think there is also a "wet" tank > > > somewhere, > > > > further toward the compressor I would guess. My LH dash gauge > > > bleeds > > > > down many times faster than the RH one (when I shut the rig > > down). > > > Now > > > > the questions: > > > > Does the LH gauge monitor the air in the LH tank (sounds > > logical)? > > > > Which tank is for which end brakes? (LH for front? LH for > rear?) > > > > Where is the wet tank located? > > > > Thanks as always, still cold here in Gunnison, Doug > > > > Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey" > > > > > > > > > > |
12-06-2006, 13:48
Pokeys air leak
Welks.
I believe that it was '82 that BB started installing automatic slack (brake) adjusters. All prior need regular brake adjusments and checking, '82-up should just need the adjusters/adjustment checked. Many of us adjust the brakes tighter before mountain traveling also. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > Jeff, > Thank you for the explanation. Now I think understand why I had > problems with the front brakes grabbing when the rear brakes were > way out of adjustment. Since I had the rears set properly the whole > braking experience is significantly better. > > Gardner > 78FC33 |
