Help! Tann Subway Safe Has Me Locked Out!!!
12-07-2006, 09:32
This is different than other safe questions posted in the past...I
know the combination. I have been into the safe several times. I have put lots of things into the safe that I would like to be able to access. Anyone have any hints to opening a safe? The only thing that has changed is that it has turned very cold here. David Hollis 84FC35 Fort Knox(Springfield),IL |
12-07-2006, 10:08
Try warming the tumblers up, they are probably just sluggush to respond. Doug
dthollis1961 other safe questions posted in the past...I know the combination. I have been into the safe several times. I have put lots of things into the safe that I would like to be able to access. Anyone have any hints to opening a safe? The only thing that has changed is that it has turned very cold here. David Hollis 84FC35 Fort Knox(Springfield),IL Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- Have a burning question? Go to Yahoo! Answers and get answers from real people who know. [Non-text portions of this message have been removed] |
12-07-2006, 14:31
David,
You're the first guy I've known to have the same safe as I do...I've had my BB for over 5 yrs, and have never been able to open the safe. Do you have the default, factory-set combination, or something else? I'd sure like to get mine open...also, so you have the Tann Subway booklet that came with the safe? I'd sure like a copy of it, if at all possible. I have nothing as far as documentation on the safe, and have called Tann, BB, with no luck. Thanks in advance...and good luck in getting your's open... Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] |
12-07-2006, 14:46
Thanks, Doug and Bim. 5 minutes with a hair dryer has everything
working again. David Hollis 84FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, Doug Engel wrote: > > Try warming the tumblers up, they are probably just sluggush to respond. Doug > |
12-07-2006, 15:03
David, No prob...even a blind pig finds an acorn every once in a while. Doug 'n
Pokey dthollis1961 minutes with a hair dryer has everything working again. David Hollis 84FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, Doug Engel wrote: > > Try warming the tumblers up, they are probably just sluggush to respond. Doug > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- Want to start your own business? Learn how on Yahoo! Small Business. [Non-text portions of this message have been removed] |
12-07-2006, 23:03
David,
Feel like sharing your combination with me to see if it works on mine (you can send me a private email if you'd like...that's what I would prefer if you were asking me). I promise I'll forget it if it doesn't work. Thanks.... Kevin McKeown Yorba Linda, CA 1986 38' PT krminyl@... [Non-text portions of this message have been removed] |
12-08-2006, 01:10
Kevin,
I've got no documentation for the Tann safe. In fact my Blue Box includes paperwork for the other brand safe(Sergeant&Greenleaf?) After buying this bus in June, I was looking through the Blue Box for the combination. I looked through hundreds of pages and finally found simply 4 numbers written on the last page of all documentation I had. Guess I got lucky. David Hollis 84FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > David, > > You're the first guy I've known to have the same safe as I do...I've had my > BB for over 5 yrs, and have never been able to open the safe. Do you have > the default, factory-set combination, or something else? I'd sure like to get > mine open...also, so you have the Tann Subway booklet that came with the > safe? I'd sure like a copy of it, if at all possible. I have nothing as far as > documentation on the safe, and have called Tann, BB, with no luck. > > Thanks in advance...and good luck in getting your's open... > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > > > [Non-text portions of this message have been removed] > |
12-08-2006, 04:35
Kevin,
I sent you an email. Let me know if it doesn't come through. David --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > David, > > Feel like sharing your combination with me to see if it works on mine (you > can send me a private email if you'd like...that's what I would prefer if you > were asking me). I promise I'll forget it if it doesn't work. > > Thanks.... > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > krminyl@... > > > [Non-text portions of this message have been removed] > |
