Rear End
03-16-2007, 02:48
Rear End
Depending on cost of drive shaft work and amount of farmed out labor, could cost
half as much or twice as much. In my case, about 2/3 cost. Us air cylinder to control trans net 8 speed fwd with 14% OD. MH ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Friday, March 16, 2007 7:40 AM Subject: [WanderlodgeForum] Re: Rear End How does the price compare between changing out the gears and a auxilliary OD trans? Kerry 82 Fc 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > That's why I went with an auxiliary OD trans. > MH > ----- Original Message ----- > From: davidkerryedwards > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, March 15, 2007 5:01 PM > Subject: [WanderlodgeForum] Re: Rear End > > > I can see one possible drawback in changing the rear end ratio. Coming out of Palo Duro > Canyon with my 82 FC (10% grade as I recall), was quite a pull. 1st gear the whole way and > down to about 1850rpms. With a higher gear ratio (I think I have the 5.29) that pull might > have become touch and go. > > Kerry > 82 Fc 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > > > Thanks Tom! Gardner do you have any thoughts since you now own this coach? > > > > > > > > - Chuck Wheeler - > > > > 82 FC 31 SB > > > > Fort Worth, TX > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
03-16-2007, 03:50
Rear End
Mike,
Could I have a little more information? Any Pictures? I have watched the shop that does my work install Telma retarders, aux transmissions, etc., so they could do the work. I was just trying to figure how things would fit together under the bus. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Mike Hohnstein Sent: Thursday, March 15, 2007 9:02 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: Rear End That's why I went with an auxiliary OD trans. MH ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@ yahoogroups.com Sent: Thursday, March 15, 2007 5:01 PM Subject: [WanderlodgeForum] Re: Rear End I can see one possible drawback in changing the rear end ratio. Coming out of Palo Duro Canyon with my 82 FC (10% grade as I recall), was quite a pull. 1st gear the whole way and down to about 1850rpms. With a higher gear ratio (I think I have the 5.29) that pull might have become touch and go. Kerry 82 Fc 35 Denver --- In WanderlodgeForum@ yahoogroups.com, "Chuck Wheeler" > > Thanks Tom! Gardner do you have any thoughts since you now own this coach? > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
03-16-2007, 03:56
Rear End
PM me; mhohnstein@... and I'll beam some images of the install to you.
MH ----- Original Message ----- From: Chuck Wheeler To: WanderlodgeForum@yahoogroups.com Sent: Friday, March 16, 2007 8:50 AM Subject: RE: [WanderlodgeForum] Re: Rear End Mike, Could I have a little more information? Any Pictures? I have watched the shop that does my work install Telma retarders, aux transmissions, etc., so they could do the work. I was just trying to figure how things would fit together under the bus. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Mike Hohnstein Sent: Thursday, March 15, 2007 9:02 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: Rear End That's why I went with an auxiliary OD trans. MH ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@ yahoogroups.com Sent: Thursday, March 15, 2007 5:01 PM Subject: [WanderlodgeForum] Re: Rear End I can see one possible drawback in changing the rear end ratio. Coming out of Palo Duro Canyon with my 82 FC (10% grade as I recall), was quite a pull. 1st gear the whole way and down to about 1850rpms. With a higher gear ratio (I think I have the 5.29) that pull might have become touch and go. Kerry 82 Fc 35 Denver --- In WanderlodgeForum@ yahoogroups.com, "Chuck Wheeler" > > Thanks Tom! Gardner do you have any thoughts since you now own this coach? > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
03-16-2007, 03:59
Rear End
That would be about right if you have 24.5" tires on your coach. That's
just about where I would be with my 22.5" tires and a 4.63 rear end. BUT...you have a turbo and more power. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of M Thomas Eastham Sent: Thursday, March 15, 2007 10:27 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Rear End I have a factory 4.89 in my 83' FC 35SB and it runs 67mph per GPS at about 2600rpm. For me that is pretty good, I can avoid being a major bottle neck for traffic and still have pulling power on the hills. We took some steep passes in Mexico above 6000ft and were pleased with the climbing performance. Thomas Eastham Houston, TX 83' FC35SB 84' FC33SB (parts unit) [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
