Drivers seat easing out of position.
05-01-2005, 08:01
The Flexsteel seat on my 78 FC slowly slides out of position after I set. Not a
bad position for an astronaut, but a little disconcerting on the highway. Any ideas? John Fitz 78 FC 31 Maynard MA. |
05-01-2005, 11:49
It sounds like the air side-slide is not locking.
It is essentially a regular manual seat-slide, sitting sideways on the swivel base, with an air-cylinder pulling the unlock lever (behind and beneath the seat). The air cylinder might be bound up, work the lever by hand to see. There is a spring return on the lever also, make sure it is in place. If simply a bound cylinder, clean the ram (shaft) with WD-40 or equivalent and work it until free, wipe clean. The swivel base is a large winged-rod under the left side of the seat just above the floor. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "bluebirdfitz" > The Flexsteel seat on my 78 FC slowly slides out of position after I set. Not a bad position > for an astronaut, but a little disconcerting on the highway. Any ideas? > > John Fitz > 78 FC 31 > Maynard MA. |
05-01-2005, 11:49
> The Flexsteel seat on my 78 FC slowly slides out of position after I set. Not a bad position > for an astronaut, but a little disconcerting on the highway. Any ideas? John, From your comment I think the recliner mechanism is slipping. You didn't mention if you have an air-ride seat. It's been a couple of years now since my wife disassembled the seats and reupholstered them. I can't seem to remember the mechanism - seems that there is a notched plate with the selector held in place by a spring which is released by the adjustment lever. The spring may be weak and/or the detents may be worn with the result that the seat back fails to fully lock into position. Your seats are probably attached to the seat base with four small bolts whose nuts are sandwiched between the plates above/below the seat pivot point. You'll need a combination wrench and a flat ratchet to remove them. The adjustment lever is held on by a phillips head screw. Once you have the seat removed, invert it, then lift up and peel back the seat cover to inspect the recliner mechanism. I'm not sure how easy your access will be - the wife cut the seat covers off and removed the foam - down to the bare frame. Not something I'd recommend just to check out the recliner. She's fearless! Helps to have worked for an automotive seat supplier. Hope this helps a little. Good luck! Jim & Pam Owens 77 FC33SB (Gas) Sweetie's Dream Lake of the Ozarks, MO |
05-01-2005, 16:09
Thanks Jeff,
The air side slide works fine. The problem is after I set it with the electric controls: the seat and back of the seat slide back ever so slowly. Thanks ofr your help. John Fitz --- Jeff Miller > It sounds like the air side-slide is not locking. > > It is essentially a regular manual seat-slide, > sitting sideways on the > swivel base, with an air-cylinder pulling the unlock > lever (behind and > beneath the seat). > > The air cylinder might be bound up, work the lever > by hand to see. > There is a spring return on the lever also, make > sure it is in place. > If simply a bound cylinder, clean the ram (shaft) > with WD-40 or > equivalent and work it until free, wipe clean. > > The swivel base is a large winged-rod under the left > side of the seat > just above the floor. > > - Jeff Miller > http://www.wanderlodge.net > http://www.millercoachworks.com > > > --- In WanderlodgeForum@yahoogroups.com, > "bluebirdfitz" > > > The Flexsteel seat on my 78 FC slowly slides out > of position after I > set. Not a bad position > > for an astronaut, but a little disconcerting on > the highway. Any > ideas? > > > > John Fitz > > 78 FC 31 > > Maynard MA. > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
05-02-2005, 01:20
Hmmm.
Then it sounds like your switch may be intermittently shorting? Take it apart and clean it? With the engine off so it's quiet, try tapping on the switch and/or bumping the seat around to simulate bumping down the road and see what happens... Gary Miller 83 FC 33 Wauwatosa, WI --- In WanderlodgeForum@yahoogroups.com, John Fitzsimmons > Thanks Jeff, > > The air side slide works fine. The problem is after I > set it with the electric controls: the seat and back > of the seat slide back ever so slowly. > > Thanks ofr your help. > > John Fitz > --- Jeff Miller > > It sounds like the air side-slide is not locking. > > > > It is essentially a regular manual seat-slide, > > sitting sideways on the > > swivel base, with an air-cylinder pulling the unlock > > lever (behind and > > beneath the seat). > > > > The air cylinder might be bound up, work the lever > > by hand to see. > > There is a spring return on the lever also, make > > sure it is in place. > > If simply a bound cylinder, clean the ram (shaft) > > with WD-40 or > > equivalent and work it until free, wipe clean. > > > > The swivel base is a large winged-rod under the left > > side of the seat > > just above the floor. > > > > - Jeff Miller > > http://www.wanderlodge.net > > http://www.millercoachworks.com > > > > > > --- In WanderlodgeForum@yahoogroups.com, > > "bluebirdfitz" > > > > > The Flexsteel seat on my 78 FC slowly slides out > > of position after I > > set. Not a bad position > > > for an astronaut, but a little disconcerting on > > the highway. Any > > ideas? > > > > > > John Fitz > > > 78 FC 31 > > > Maynard MA. > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com |
