Power steering ?
05-02-2007, 10:07
Power steering ?
Larry, I believe that is for your hydraulic jacks. If your jacks are
extended, don't add fluid- you will have a mess. Yes, it is transmission fluid.
83PT40
Livingston, Mt
05-02-2007, 13:53
Power steering ?
I was cleaning the steps today and found a door, Under the door was a
plate and under the plate was a screw handle with a dip stick. I am
guessing it is the fill for the power steering. Nothing showing on
the dip stick. I put a screw driver in and the fluid looks like
transmission fluid. Could not find any info on what fluid is
recommended. Please tell me what to use..
Larry Kehler
94 PT-40
05-02-2007, 14:15
Power steering ?
It is the reservoir for the HWH Leveling System on my coach. The system calls
for Dextron II. I think Dextron II is not available but Dextron III is
compatable. If you look under the step toward the center of the bus you should
see a valve surrounded by a protective shroud which has 4 solenoids on it. That
is what makes the jacks go. Your power steering reservoir is the large black
canister in the left engine bay that uses 30w oil and also is the reservoir for
the hydraulic cooling fan. That is how my coach is. Check to be certain.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Leroy Eckert
Niceville, FL
Sent: Wednesday, May 02, 2007 8:53 PM
Subject: [WanderlodgeForum] Power steering ?
Larry Kehler
94 PT-40
05-02-2007, 14:18
Power steering ?
Thanks Ernie
OK so where is the power steering fill?
Larry Kehler
94 PT-40
St Louis
transmission fluid.
> Ernie Ekberg
> 83PT40
> Livingston, Mt
05-02-2007, 15:40
Power steering ?
Powersteering and Fan are the same hydrolic pump and resevoir. In the
engine bay to the left of the turbo. may have a rubber plumbers
expand plug in it.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Larry Kehler"
> Thanks Ernie
> Larry Kehler
> 94 PT-40
> St Louis
are
> transmission fluid.
> > Ernie Ekberg
> > 83PT40
> > Livingston, Mt
