Alarm On 1982 PT40?
07-09-2007, 07:59
Alarm On 1982 PT40?
In a message dated 7/9/2007 4:31:51 P.M. Mountain Standard Time,
ryanpwright@... writes: Sweet! My first successful assist here. ;-) I finally know enough about this old bus to begin to help others. -Ryan AHHHHHH- that's why the forum was created!!! Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
07-09-2007, 10:53
Alarm On 1982 PT40?
Hello:
I just enterned my '82 PT-40 and turned on the master battery switch and a very loud alarm started sounding. The alarm is above the kitchen sink and is black and about the size of a silver dollar. Any idea what this alarm is, and why its going off? Everthing seemsok... As always I apprecate your help greatly. Kevin Ford '82 PT-40 Richmond Tx. |
07-09-2007, 10:56
Alarm On 1982 PT40?
Did your "burglar alarm" get set accidentally? Not sure if your coach
has it, but if so, turn it off on the main dash. Should be a switch that says "burglar alarm" or some such. -Ryan '86 PT-40 8V92 Tri-Cities, WA On 7/9/07, Kevin Ford > > Hello: > I just enterned my '82 PT-40 and turned on the master battery switch > and a very loud alarm started sounding. The alarm is above the kitchen > sink and is black and about the size of a silver dollar. > > Any idea what this alarm is, and why its going off? Everthing seemsok... > > As always I apprecate your help greatly. > > Kevin Ford > '82 PT-40 > Richmond Tx. |
07-09-2007, 11:06
Alarm On 1982 PT40?
I do not know about yours specifically. Idea. Mine has a fridge and LP gas alarm
in the overhead panel above the zap oven. When you said master battery switch, are you talking about an electronics master? Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Kevin Ford To: WanderlodgeForum@yahoogroups.com Sent: Monday, July 09, 2007 5:53 PM Subject: [WanderlodgeForum] Alarm On 1982 PT40? Hello: I just enterned my '82 PT-40 and turned on the master battery switch and a very loud alarm started sounding. The alarm is above the kitchen sink and is black and about the size of a silver dollar. Any idea what this alarm is, and why its going off? Everthing seemsok... As always I apprecate your help greatly. Kevin Ford '82 PT-40 Richmond Tx. [Non-text portions of this message have been removed] |
07-09-2007, 11:12
Alarm On 1982 PT40?
Ok I found it. There is a alarm button that has been installed at the
drivers seat (looks like someone installed it). Anyway I got to thinking about that and went out and messed with that switch and that fixed it. Thanks Ryan for your help. Kevin --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Did your "burglar alarm" get set accidentally? Not sure if your coach > has it, but if so, turn it off on the main dash. Should be a switch > that says "burglar alarm" or some such. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > > On 7/9/07, Kevin Ford > > > > Hello: > > I just enterned my '82 PT-40 and turned on the master battery switch > > and a very loud alarm started sounding. The alarm is above the kitchen > > sink and is black and about the size of a silver dollar. > > > > Any idea what this alarm is, and why its going off? Everthing seemsok... > > > > As always I apprecate your help greatly. > > > > Kevin Ford > > '82 PT-40 > > Richmond Tx. > |
07-09-2007, 11:16
Alarm On 1982 PT40?
Thanks Leroy I found it. (I think this was a special installed alarm
by the previous owner) Kevin --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > I do not know about yours specifically. Idea. Mine has a fridge and LP gas alarm in the overhead panel above the zap oven. > When you said master battery switch, are you talking about an electronics master? > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: Kevin Ford > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, July 09, 2007 5:53 PM > Subject: [WanderlodgeForum] Alarm On 1982 PT40? > > > Hello: > I just enterned my '82 PT-40 and turned on the master battery switch > and a very loud alarm started sounding. The alarm is above the kitchen > sink and is black and about the size of a silver dollar. > > Any idea what this alarm is, and why its going off? Everthing seemsok... > > As always I apprecate your help greatly. > > Kevin Ford > '82 PT-40 > Richmond Tx. > > > > > > [Non-text portions of this message have been removed] > |
07-09-2007, 11:30
Alarm On 1982 PT40?
about this old bus to begin to help others. -Ryan On 7/9/07, Kevin Ford > > Ok I found it. There is a alarm button that has been installed at the > drivers seat (looks like someone installed it). Anyway I got to > thinking about that and went out and messed with that switch and that > fixed it. > > Thanks Ryan for your help. > Kevin |
