directionals not working?
07-03-2007, 20:16
Tom, my flasher is located behind the driver's headlite panel.
Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
07-03-2007, 21:12
We're leaving on a trip tomorrow and when I went to fuel up I notice
the directionals are not working, and either are the hazard lights. The last trip we had taken, there was a random (sounded like a relay clicking) noise coming from the center console (where two drawers are). Since then, I've had the drawers out and dash out replacing the EL inverters. I tried to be very careful putting everything back, not to leave any loose or disconnected wires. When I put on the directional or hazard switch now, there is a distinct click coming from a silver box (roughly 6" x 6" x 1" ) mounted right above the top drawer inside the center console. If I am reading the drawings correctly it is the PMMI switch relay box, or something like that ( I don't remember exactly what the drawing said). The drawing also shows a flasher and a fuse. So, is the clicking in the box a symptom or the problem? Is the box fixable, replaceable? From where? Does anyone know where the flasher and fuse physically are? Or basically where do I start with this problem??? I'd like to get it fixed before we leave. Thanks. Tom Sorrentino 1987 PT38 Bedford Hills, NY |
07-04-2007, 12:18
Thanks Ernie,
I'll be looking for it first thing tommorrow morning. Wish me luck finding it. Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Tom, my flasher is located behind the driver's headlite panel. > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
07-04-2007, 13:42
On my 86 38'PT, my turn signals quit working a few yrs ago...it was a glass
fuse under the dash, in front of your right knee, but up under the dash itself...next to the flasher unit. Hope you are as lucky... Kevin Mc Yorba Linda, CA 1986 38' PT ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
07-07-2007, 16:46
Tom,
I have an 87FC35, but I can tell you about the silver box. I many hours when i first got my bird in august trying to figure out where things were. I also had some problems with my blinkers. The silver box, if you open it up, is a bunch of relays mounted on a circuit board. I think there are 8 or 10. They are for the blinkers and emergency blinkers. They should be clicking when you turn on your blinkers, that is a good sign. I spent a bunch of time trying to figure all this out, including talking to PMMI. They eventually found a schematic. If i remember correctly, there is a front, rear, and side relay for right and left blinkers. Plus there is another relay that "fires" all of the relays if you have your emergencies on. I would bet (especially since you say you hear clicking) that the problem isn't in the relays, but I can't help you much beyond here. My relays were solid after 20 years. If you have a tester, you can probably see if you are getting 12 volts out of the flashers. It is probably possible that your relays are clicking, but because you have a fuse out somewhere, there is not 12 volt input coming into them to send on to the lights themselves. ...One of the PT guys can probably help you out here more than me. Good luck! (ps, I drove mine on one trip w/o blinkers. Not recommended, but I wanted to go bad enough and was just extra careful.) ![]() Alan Johnson 87FC35 --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > We're leaving on a trip tomorrow and when I went to fuel up I notice > the directionals are not working, and either are the hazard lights. > The last trip we had taken, there was a random (sounded like a relay > clicking) noise coming from the center console (where two drawers > are). Since then, I've had the drawers out and dash out replacing the > EL inverters. I tried to be very careful putting everything back, not > to leave any loose or disconnected wires. > When I put on the directional or hazard switch now, there is a > distinct click coming from a silver box (roughly 6" x 6" x 1" ) > mounted right above the top drawer inside the center console. If I am > reading the drawings correctly it is the PMMI switch relay box, or > something like that ( I don't remember exactly what the drawing > said). The drawing also shows a flasher and a fuse. > So, is the clicking in the box a symptom or the problem? Is the box > fixable, replaceable? From where? Does anyone know where the flasher > and fuse physically are? Or basically where do I start with this > problem??? I'd like to get it fixed before we leave. Thanks. > > Tom Sorrentino > 1987 PT38 > Bedford Hills, NY > |
07-07-2007, 19:01
will take a little bit of planning and execution But I would look at a
solid state flasher unit that is capable of handling multiple inputs and outputs and example would the true school bus type used on yes school buses but also on new high end coaches http://www.schoolbuspartscompany.com/Web...stems.html Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Alan" > > Tom, > > I have an 87FC35, but I can tell you about the silver box. I many > hours when i first got my bird in august trying to figure out where > things were. I also had some problems with my blinkers. The silver > box, if you open it up, is a bunch of relays mounted on a circuit > board. I think there are 8 or 10. They are for the blinkers and > emergency blinkers. They should be clicking when you turn on your > blinkers, that is a good sign. I spent a bunch of time trying to > figure all this out, including talking to PMMI. They eventually found > a schematic. > > If i remember correctly, there is a front, rear, and side relay for > right and left blinkers. Plus there is another relay that "fires" all > of the relays if you have your emergencies on. > > I would bet (especially since you say you hear clicking) that the > problem isn't in the relays, but I can't help you much beyond here. > My relays were solid after 20 years. If you have a tester, you can > probably see if you are getting 12 volts out of the flashers. It is > probably possible that your relays are clicking, but because you have > a fuse out somewhere, there is not 12 volt input coming into them to > send on to the lights themselves. ...One of the PT guys can probably > help you out here more than me. > > Good luck! > (ps, I drove mine on one trip w/o blinkers. Not recommended, but I > wanted to go bad enough and was just extra careful.) ![]() > > Alan Johnson > 87FC35 > > > --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > > > > We're leaving on a trip tomorrow and when I went to fuel up I notice > > the directionals are not working, and either are the hazard lights. > > The last trip we had taken, there was a random (sounded like a relay > > clicking) noise coming from the center console (where two drawers > > are). Since then, I've had the drawers out and dash out replacing the > > EL inverters. I tried to be very careful putting everything back, not > > to leave any loose or disconnected wires. > > When I put on the directional or hazard switch now, there is a > > distinct click coming from a silver box (roughly 6" x 6" x 1" ) > > mounted right above the top drawer inside the center console. If I am > > reading the drawings correctly it is the PMMI switch relay box, or > > something like that ( I don't remember exactly what the drawing > > said). The drawing also shows a flasher and a fuse. > > So, is the clicking in the box a symptom or the problem? Is the box > > fixable, replaceable? From where? Does anyone know where the flasher > > and fuse physically are? Or basically where do I start with this > > problem??? I'd like to get it fixed before we leave. Thanks. > > > > Tom Sorrentino > > 1987 PT38 > > Bedford Hills, NY > > > |
07-08-2007, 11:59
Alan,
Thanks for the reply.I think you may be right that the silver box is not the cause! Before I could actually trouble shoot anything, the directionals and hazards are working again. I now have two relays (1 for the left side and 1 for the right side) audibly clicking and working in the access panel above the driver. I still haven't been able to physically locate the flasher. And I am still getting the random clicking from the PMMI silver box (at least thats where I think its coming from). Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, "Alan" wrote: > > Tom, > > I have an 87FC35, but I can tell you about the silver box. I many > hours when i first got my bird in august trying to figure out where > things were. I also had some problems with my blinkers. The silver > box, if you open it up, is a bunch of relays mounted on a circuit > board. I think there are 8 or 10. They are for the blinkers and > emergency blinkers. They should be clicking when you turn on your > blinkers, that is a good sign. I spent a bunch of time trying to > figure all this out, including talking to PMMI. They eventually found > a schematic. > > If i remember correctly, there is a front, rear, and side relay for > right and left blinkers. Plus there is another relay that "fires" all > of the relays if you have your emergencies on. > > I would bet (especially since you say you hear clicking) that the > problem isn't in the relays, but I can't help you much beyond here. > My relays were solid after 20 years. If you have a tester, you can > probably see if you are getting 12 volts out of the flashers. It is > probably possible that your relays are clicking, but because you have > a fuse out somewhere, there is not 12 volt input coming into them to > send on to the lights themselves. ...One of the PT guys can probably > help you out here more than me. > > Good luck! > (ps, I drove mine on one trip w/o blinkers. Not recommended, but I > wanted to go bad enough and was just extra careful.) ![]() > > Alan Johnson > 87FC35 > > > --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > > > > We're leaving on a trip tomorrow and when I went to fuel up I notice > > the directionals are not working, and either are the hazard lights. > > The last trip we had taken, there was a random (sounded like a relay > > clicking) noise coming from the center console (where two drawers > > are). Since then, I've had the drawers out and dash out replacing the > > EL inverters. I tried to be very careful putting everything back, not > > to leave any loose or disconnected wires. > > When I put on the directional or hazard switch now, there is a > > distinct click coming from a silver box (roughly 6" x 6" x 1" ) > > mounted right above the top drawer inside the center console. If I am > > reading the drawings correctly it is the PMMI switch relay box, or > > something like that ( I don't remember exactly what the drawing > > said). The drawing also shows a flasher and a fuse. > > So, is the clicking in the box a symptom or the problem? Is the box > > fixable, replaceable? From where? Does anyone know where the flasher > > and fuse physically are? Or basically where do I start with this > > problem??? I'd like to get it fixed before we leave. Thanks. > > > > Tom Sorrentino > > 1987 PT38 > > Bedford Hills, NY > > > |
