In-Motion Satellite Question
07-18-2007, 15:57
We are thinking of installing in-motion Satellite on a "soon-to-be
ours" 1986 PT-40. I know there have been a lot of discussions on the pros and cons from my initial readings. I would be interested on any suggestions anyone might have on the following: 1) Are you happy with in-motion? 2) What Brand would you recommend? 3) Do you have HDTV and does it work well over in-motion? 4) How difficult is Satellite mounting on the aluminum decking? 5) Is there an optimum location to mount on the PT40? Thanks in advance for any comments. Glenn |
07-19-2007, 01:25
Glenn,
I have the Motosat T2 Automotion in-motion tv turner and love it. The nice thing about this setup, you can tell the dish what satelite you want to point the unit towards. So it will work with direct tv or dish network or both if you have to have both. Sorry only one satelitte at a time. It does not do HDTV because it only has one LNB. But if you are travelling for long distances, it helps to keep your co- pilots occupied and not back seat driving if you know what I mean. LOL Installation is very easy and I believe I took more time trying to decide where to mount. Mine is mounted mid-bus because that was all the room I had left. If I were you, I would mount either in the front of the bus or rear. So when you pull into your pad hopefully the end that the dish is located on will be sticking up from under the canapy of trees. I have a Motosat Datastorm with TV attachment so if the T2 does not get signal, I switch to the Datastorm. Most time I have clear path between the two. End the end, if I don't, my datastorm will have clear path out to high speed internet. Al Johnson '96 BMC B100 Datastorm Certified Installer Mandeville, Louisiana --- In WanderlodgeForum@yahoogroups.com, "ragster_ga" wrote: > > We are thinking of installing in-motion Satellite on a "soon-to-be > ours" 1986 PT-40. I know there have been a lot of discussions on the > pros and cons from my initial readings. I would be interested on any > suggestions anyone might have on the following: > 1) Are you happy with in-motion? > 2) What Brand would you recommend? > 3) Do you have HDTV and does it work well over in-motion? > 4) How difficult is Satellite mounting on the aluminum decking? > 5) Is there an optimum location to mount on the PT40? > > Thanks in advance for any comments. > > Glenn > |
07-19-2007, 03:51
Glenn,
I have KVH L3 in-motion and love it. I also use DirecTV which automatically selects the satelite. I do not have HDTV yet. If you get it, report on your findings for the rest of us. Mounting appeared to be fairly easy (AMEX). I did have to sign the credit slip. Location, location, location. Pick the spot where it has the most clearance from other devices mounted on the roof. It is a line of sight system that can be easily blocked by buildings, trees, overpasses, Rotton Rob walking on your roof while you teenage son is trying to watch TV and heavy rain. Where ever you choose, be assured the next spot you park will have one tree directly blocking your reception. Try moving forward or back to get a clear signal. Tom "TTS" McCarthy 95 PT42 Poway, CA --- In WanderlodgeForum@yahoogroups.com, "ragster_ga" wrote: > > We are thinking of installing in-motion Satellite on a "soon-to-be > ours" 1986 PT-40. I know there have been a lot of discussions on the > pros and cons from my initial readings. I would be interested on any > suggestions anyone might have on the following: > 1) Are you happy with in-motion? > 2) What Brand would you recommend? > 3) Do you have HDTV and does it work well over in-motion? > 4) How difficult is Satellite mounting on the aluminum decking? > 5) Is there an optimum location to mount on the PT40? > > Thanks in advance for any comments. > > Glenn > |
