trip odometer
07-25-2007, 08:08
trip odometer
Is there a source for the trip odometer? My coach has one above the drivers
window. Teleflex number is 52545, BB doesn't have one in stock. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WLWB41 [Non-text portions of this message have been removed] |
07-25-2007, 09:15
trip odometer
Fred, I would start here:
Joe Federsel Technical Support Teleflex Marine Sarasota, FL 941-907-1000 techsupport@... If the meter is like the gauges the number may have been changed. Mr. Federsel should be able to give you the info. He will not sell direct but should be able to give you a #pn and tell you where to buy. I got what I needed from West Marine special order. When you find the info please post it and we will see if Mike B will add it to the Teleflex chart I put together for the files. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Fred Hulse To: Wanderlodge@yahoogroups.com ; wanderlodgeforum@yahoogroups.com Sent: Wednesday, July 25, 2007 3:08 PM Subject: [WanderlodgeForum] trip odometer Is there a source for the trip odometer? My coach has one above the drivers window. Teleflex number is 52545, BB doesn't have one in stock. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WLWB41 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
07-25-2007, 14:24
trip odometer
Thank you Leroy.
07-25-2007, 14:56
trip odometer
Since you mention the trip odometer, perhaps someone could explain
how it works. I notice that mine 'clicks' a new tenth of a mile even when I'm not moving. It seems to have a mind of its own and never seems to match the miles on the odometer inside the speedometer. (I also note that a fast idle speed will often show 5 mph on the speedometer, even when I'm parked.) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jul 25, 2007, at 2:15 PM, Leroy Eckert wrote: > Fred, I would start here: > Joe Federsel > Technical Support > Teleflex Marine > Sarasota, FL > 941-907-1000 > techsupport@... <snip> [Non-text portions of this message have been removed] |
07-25-2007, 15:23
trip odometer
Well, I do not know how the trip meter works or where it gets its data. I do
know that mine does not spool up on its own and is more accurate than the odometer. I have checked both against the GPS and have found the following over a short trip. GPS miles-471 Trip meter-473 Odometer-481 The ole bus doesn't have as many miles as stated. I believe the GPS. I do not have the speedometer problem either. Wish I knew how to help. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, July 25, 2007 9:56 PM Subject: Re: [WanderlodgeForum] trip odometer Since you mention the trip odometer, perhaps someone could explain how it works. I notice that mine 'clicks' a new tenth of a mile even when I'm not moving. It seems to have a mind of its own and never seems to match the miles on the odometer inside the speedometer. (I also note that a fast idle speed will often show 5 mph on the speedometer, even when I'm parked.) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jul 25, 2007, at 2:15 PM, Leroy Eckert wrote: > Fred, I would start here: > Joe Federsel > Technical Support > Teleflex Marine > Sarasota, FL > 941-907-1000 > techsupport@... <snip> [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
07-27-2007, 15:33
trip odometer
Below is the reply from Teleflex regarding the trip odometer I was looking for.
Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WLWB41 --------------------------------------------------------------------------------\ ---------------------------------- Hello Fred, this item is discontinued and never replaced. Sorry! Joe Federsel Technical Support Teleflex Marine Sarasota Florida 941/907-1000 941/907-1020 Fax techsupport@... -------------------------------------------------------------------------------- From: Fred Hulse [mailto:fhulse@...] Sent: Wednesday, July 25, 2007 10:29 PM To: Techsupport Subject: Teleflex trip odometer Hi Joe I am looking for a trip odometer Blue Bird used as original equipment in my 97 Wanderlodge. They (Blue Bird) said the part # is 52545 but dont't stock it. Can you refer me to a distributor that will supply this to me? Thanks in advance. Fred Hulse Morristown Arizona 1997 Wanderlodge WLWB41 [Non-text portions of this message have been removed] |
