1977FC steering wheel
08-08-2007, 02:45
They say there is no stuoid question! How in the heck does the
steering wheel come off my 77FC? Nothing seems to turn or unlock...it has a little bluebird in the middle where the horn is. Thanks for any info....jim |
08-08-2007, 03:10
Jim,
The white cap (horn button) comes off by pushing down on it then twisting. You will need to select the off position for the horn switch. When that comes off you will find a large nut that needs to be removed (1'' or larger) then you will need a puller of sorts to dislodge the steering wheel from the shaft. Steve Anderson 79 FC 35 Poulsbo, Wa In a message dated 8/8/2007 8:42:14 AM Pacific Daylight Time, jimbojcs@... writes: They say there is no stuoid question! How in the heck does the steering wheel come off my 77FC? Nothing seems to turn or unlock...it has a little bluebird in the middle where the horn is. Thanks for any info....jim ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
08-08-2007, 06:47
--- In WanderlodgeForum@yahoogroups.com, "jimbojcs"
> > They say there is no stuoid question! How in the heck does the > steering wheel come off my 77FC? Nothing seems to turn or unlock...it > has a little bluebird in the middle where the horn is. Thanks for any > info....jim > Jim, *carefuly*remove the center [horn button]. A wire is attached to the underside of the button, you will see a large nut inside the steering wheel. It takes a deepwell-socket to reach it. Don't remember the size off hand. Get that not off, then us a small puller to pull the wheel off. Unless yous is different than my '85. Harold Prescott '85 FC35 Northern California |
