How many floors / levels does my black tank have?
05-13-2005, 15:09
Jim. Thanks for your reply. I don't have a high pressure device. What
brand/type do you recommend and where can I buy one? Henry@... 1979
FC 35, McAllen, Tx
Date: Fri, 13 May 2005 11:26:21 -0700
Subject: Re: How many floors/levels does my black tank have?
Henry Claeys wrote:
>> 1) I suspect that my black tank has a problem because I discovered,
>> after 3 weeks of use, that the drain valve was not closing completely.
>> (2) What confuses me is, even after apparently emptying the black
>> system, I still see water when I look down the hole through the
>> commode. Why is there water in the tank below the commode even after
>> emptying the black tank? I never used to notice the water until I
>> discovered the above described drain problem. Thanks.
>> Henry@... 1979 FC 35, McAllen, Tx
You've got something seriously funky going on in there. Somebody's been
eating at Taco Bell too much and it's formed a "clump" of yucko.
I'd hit it with a high-pressure garden hose spray down the toilet, try
and blast it out.
Jim
(no rig yet but SOON!)
05-13-2005, 15:16
Henry do yourself a favor and do this. Put a 1/2 cup of detergent in your
black water tank with about 15 gallons or so of water.. Add a couple of big
bags of ice cubes and take a 1/2 drive and then fill the tank and
dump. Clean tank
tom
1982 FC35
Vernon Center,NY
>one? Henry@... 1979 FC 35, McAllen, Tx
> From: Jim March
>and blast it out.
>Jim
>Yahoo! Groups Links
anderlodgeForum/
Wanderl\
05-13-2005, 23:48
i forgot to mention that i've used the cheapo (less than $100) power washers
from home depot,they work fine..randydupree93wb
Sent: Friday, May 13, 2005 11:09 PM
Subject: [WanderlodgeForum] How many floors / levels does my black tank have?
FC 35, McAllen, Tx
and blast it out.
Jim
Yahoo! Groups Links
05-14-2005, 12:53
Tom. Your idea sounds great provided the valve will close enough to hold 15 or
so gallons. I thought the valve was an all or nothing type thing meaning that
it either works, or it doesn't, but to my surprise it seems to hold some water.
Can you explain why/how it could behave that way and what to do to fix? Thanks
for your advice. Henry@... 1979 FC/SB 35, McAllen, Tx
Date: Fri, 13 May 2005 23:16:13 -0400
Subject: Re: How many floors / levels does my black tank have?
dump. Clean tank
tom
1982 FC35
Vernon Center,NY
05-14-2005, 13:27
Henry you probably have the Dupree manual valve on your black water tank.
if its not filled yet, take the two screws out of the housing just below
the handle and remove the guts. Lube it up good with silicon grease and put
it back together.
Tom
1982 FC35
Vernon Center,NY
>15 or so gallons. I thought the valve was an all or nothing type thing
>meaning that it either works, or it doesn't, but to my surprise it seems
>to hold some water. Can you explain why/how it could behave that way and
>what to do to fix? Thanks for your advice. Henry@... 1979
> From: Tom Warner
>dump. Clean tank
>tom
>1982 FC35
>Vernon Center,NY
05-14-2005, 14:02
silicon spray works best...randydupree93wb
Sent: Saturday, May 14, 2005 9:27 PM
Subject: Re: [WanderlodgeForum] How many floors / Levels does my black tank
have?
it back together.
Tom
1982 FC35
Vernon Center,NY
> From: Tom Warner
>dump. Clean tank
>tom
>1982 FC35
>Vernon Center,NY
Yahoo! Groups Links
