Hydraulic generator slide help
11-03-2007, 07:19
Hi folks,
I'm trying to fix my generator slide. I had a guy look at it yesterday who knows more about hydraulics than I do. The pump works and pressurizes the hose, but there is apparently a solenoid that is not energizing (my slide is tied into my HWH system, I think). Is there a fuse, or something, that might control this solenoid? What is supposed to trigger the solenoid? I need to climb under there, find the solenoid and check to see if it's even getting power, but I wanted to throw this out first in case someone had any ideas for me. -Ryan '86 PT-40 8V92 |
11-03-2007, 13:49
Ryan,
Check the generator slide in/out switch. I believe HGH once told me that there are 2 seperate power inputs, and both have to engage. One sends power to the pump solonoid, and the other actuates the slide. Don't hesitate to call HGH, very helpful techs there! (563)724-3396 or (800)321-3494 http://www.hwhcorp.com/ Michael Kramer 1986 PT40 8V92 San Diego, CA --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Hi folks, > > I'm trying to fix my generator slide. I had a guy look at it yesterday > who knows more about hydraulics than I do. The pump works and > pressurizes the hose, but there is apparently a solenoid that is not > energizing (my slide is tied into my HWH system, I think). Is there a > fuse, or something, that might control this solenoid? What is supposed > to trigger the solenoid? > > I need to climb under there, find the solenoid and check to see if > it's even getting power, but I wanted to throw this out first in case > someone had any ideas for me. > > -Ryan > '86 PT-40 8V92 > |
