need photo Onan DKD in a 87 to 89 FC
11-09-2007, 11:12
I just finished removing my genset, insulating the compartment and
overhauling the complete cooling system. This was a big job. I took photos of everything so I wouild be able to reinstall all the components. But I have run into a snag. I did not take any pics of the genset before I started. I am having a problem with the small tank for the rad. It hinges down but when I swing it up it hits the new insulation. I also do not rememeber what holds the tank in the up position. Once I have cleaned up my shop I will post a file and some photos of this job. Bruce 1988 FC35 |
11-09-2007, 12:37
Bruce,
Do you need some pics of the tank, I can send some off to you in the morning if you do. Robert Britton 87FC Hollister, California --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > I just finished removing my genset, insulating the compartment and > overhauling the complete cooling system. This was a big job. I took > photos of everything so I wouild be able to reinstall all the > components. But I have run into a snag. I did not take any pics of the > genset before I started. I am having a problem with the small tank for > the rad. It hinges down but when I swing it up it hits the new > insulation. I also do not rememeber what holds the tank in the up > position. Once I have cleaned up my shop I will post a file and some > photos of this job. > > Bruce > 1988 FC35 > |
11-09-2007, 12:54
Hi Robert:
Yes I need a shot of that tank and how it is attached to the " hinged plate" I also would like to know what holds the whole thing ( plate and tank) from moving. There is an angle bracket that attaches to the inside top of the compartment but I dont know what purpose it serves. Thank You for the reply. Bruce 1988FC35 |
11-09-2007, 13:35
I'll take a look at it and send some pics. e-mail your contact info
to...robertbritton@... Robert Britton 87FC Hollister, California --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Hi Robert: > > Yes I need a shot of that tank and how it is attached to the " hinged > plate" I also would like to know what holds the whole thing ( plate and > tank) from moving. There is an angle bracket that attaches to the > inside top of the compartment but I dont know what purpose it > serves. Thank You for the reply. > > Bruce > 1988FC35 > |
11-09-2007, 14:23
Bruce, Since you are now experienced want to give me a hand, I need
to do mine. Want to share any little tricks you learned, what was the total time on the job? Did you drop the whole unit out or did you tilt it by loosing the two outside bolts. Please share yuor experiences with me. john@... 812-282-7253 John 88FC35 Louisville, KY --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Hi Robert: > > Yes I need a shot of that tank and how it is attached to the " hinged > plate" I also would like to know what holds the whole thing ( plate and > tank) from moving. There is an angle bracket that attaches to the > inside top of the compartment but I dont know what purpose it > serves. Thank You for the reply. > > Bruce > 1988FC35 > |
11-09-2007, 15:15
Hi John:
Have you read Bill Pape's excellent file on doing this job? Are you mechanical? Do you like being dirty? Will your wife let you into the house covered with soot from the foam. Do you have a good selection of tools? Mostly what this job requires is perseverance. I will post an article on my experience with some part #'s and sources for parts. Be prepared to spend a lot of time . Are you retired? Are you doing this outside. I would definitely NOT recommend that you try to reinsulate with the gennie in place. Are you going to remove the rad and fan? When I took the rad out it was probably the dirtiest rad I have ever seen. Lots of " slime". Unless yours has been done it will need a recore. Be prepared to spend at least $1000 for insulation, fans, motors, hoses, etc. Watch for my " story" in the next few days. Bruce 1988 FC35 |
11-09-2007, 15:20
I almost forgot : I posted a Before and After photo in the photo
section titled: Onan Cooling System Repair. Bruce 1988 FC35 |
