Dually Valve Stems
12-19-2007, 22:48
Dually Valve Stems
In a couple of hours I am having new custom dually valve stems with
stabilizers installed on the coach. These should allow for quality application of the pressure pro senders on my coach. I purchased part number kit DL4AAOS. It includes, 2#VH51010, 2#TV513 and 2#H2225 for old style Alcoa wheels. I will let you know how it goes. http://www.borgtiresupply.com 1-800-300-2674 Tujunga, CA Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion |
12-20-2007, 03:26
Dually Valve Stems
Leroy,
Keep us posted. I tried valve extentions and extention supports, for Accuride rims. I was not satisfied. The rubber supports were loose and smaller than the rim holes. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Leroy A. Eckert" > > In a couple of hours I am having new custom dually valve stems with > stabilizers installed on the coach. These should allow for quality > application of the pressure pro senders on my coach. I purchased part > number kit DL4AAOS. It includes, 2#VH51010, 2#TV513 and 2#H2225 for > old style Alcoa wheels. I will let you know how it goes. > http://www.borgtiresupply.com 1-800-300-2674 Tujunga, CA > > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > |
12-20-2007, 04:37
Dually Valve Stems
Bill, got them installed in about an hour. They fit as advertised. I think I
will order two more rubber grommets. I installed the rubber grommets on the inside dual but think I want to double up just because. It's probably overkill and not needed because everything is tight. No more leaky extensions and busted knuckles, I hope. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion pattypape Leroy, Keep us posted. I tried valve extentions and extention supports, for Accuride rims. I was not satisfied. The rubber supports were loose and smaller than the rim holes. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Leroy A. Eckert" > > In a couple of hours I am having new custom dually valve stems with > stabilizers installed on the coach. These should allow for quality > application of the pressure pro senders on my coach. I purchased part > number kit DL4AAOS. It includes, 2#VH51010, 2#TV513 and 2#H2225 for > old style Alcoa wheels. I will let you know how it goes. > http://www.borgtiresupply.com 1-800-300-2674 Tujunga, CA > > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > --------------------------------- Never miss a thing. Make Yahoo your homepage. [Non-text portions of this message have been removed] |
12-20-2007, 06:12
Dually Valve Stems
Leroy,
I put the same ones on my tires and so for have worked great. Howard T., Camilla, Ga. 86 PT40 ----- Original Message ----- From: Leroy A. Eckert To: WanderlodgeForum@yahoogroups.com Sent: Thursday, December 20, 2007 5:48 AM Subject: [WanderlodgeForum] Dually Valve Stems In a couple of hours I am having new custom dually valve stems with stabilizers installed on the coach. These should allow for quality application of the pressure pro senders on my coach. I purchased part number kit DL4AAOS. It includes, 2#VH51010, 2#TV513 and 2#H2225 for old style Alcoa wheels. I will let you know how it goes. http://www.borgtiresupply.com 1-800-300-2674 Tujunga, CA Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.486 / Virus Database: 269.17.4/1188 - Release Date: 12/17/2007 2:13 PM [Non-text portions of this message have been removed] |
12-20-2007, 07:42
Dually Valve Stems
Howard,
Did you install the grommet on the inside or outside dual wheel? It's good to know yours are working fine. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion Bone chilling rain and cold for a FL boy "Howard O. Truitt" Leroy, I put the same ones on my tires and so for have worked great. Howard T., Camilla, Ga. 86 PT40 ----- Original Message ----- From: Leroy A. Eckert To: WanderlodgeForum@yahoogroups.com Sent: Thursday, December 20, 2007 5:48 AM Subject: [WanderlodgeForum] Dually Valve Stems In a couple of hours I am having new custom dually valve stems with stabilizers installed on the coach. These should allow for quality application of the pressure pro senders on my coach. I purchased part number kit DL4AAOS. It includes, 2#VH51010, 2#TV513 and 2#H2225 for old style Alcoa wheels. I will let you know how it goes. http://www.borgtiresupply.com 1-800-300-2674 Tujunga, CA Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion ---------------------------------------------------------- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.486 / Virus Database: 269.17.4/1188 - Release Date: 12/17/2007 2:13 PM [Non-text portions of this message have been removed] --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. [Non-text portions of this message have been removed] |
12-20-2007, 09:31
Dually Valve Stems
Leroy
On the outside Howard ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Thursday, December 20, 2007 2:42 PM Subject: Re: [WanderlodgeForum] Dually Valve Stems Howard, Did you install the grommet on the inside or outside dual wheel? It's good to know yours are working fine. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion Bone chilling rain and cold for a FL boy "Howard O. Truitt" I put the same ones on my tires and so for have worked great. Howard T., Camilla, Ga. 86 PT40 ----- Original Message ----- From: Leroy A. Eckert To: WanderlodgeForum@yahoogroups.com Sent: Thursday, December 20, 2007 5:48 AM Subject: [WanderlodgeForum] Dually Valve Stems In a couple of hours I am having new custom dually valve stems with stabilizers installed on the coach. These should allow for quality application of the pressure pro senders on my coach. I purchased part number kit DL4AAOS. It includes, 2#VH51010, 2#TV513 and 2#H2225 for old style Alcoa wheels. I will let you know how it goes. http://www.borgtiresupply.com 1-800-300-2674 Tujunga, CA Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion ---------------------------------------------------------- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.486 / Virus Database: 269.17.4/1188 - Release Date: 12/17/2007 2:13 PM [Non-text portions of this message have been removed] --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.486 / Virus Database: 269.17.4/1188 - Release Date: 12/17/2007 2:13 PM [Non-text portions of this message have been removed] |
