Governor
02-27-2008, 10:59
Governor
Dennis,
I had to replace my governor a few years ago, and had the same problem locating it. I finally had to take it to a real shop, and they found the governor, and said it was almost impossible to get to (apparently on a frame rail above the transmission???). They suggested that it be replumbed to a more accessible location....I agreed. They replumbed it to the engine compartment bulkhead, curb side, near the battery charger compartment. Left the old one in place, but not hooked up. Maybe something you could consider......
Best of luck.
Kevin McKeown
Yorba Linda, CA
1986 38' PT Delicious ideas to please the pickiest eaters. Watch the video on AOL Living. |
02-27-2008, 11:26
Governor
Hi all. Om a 1983 PT35 I am looking for the air system governor and
for the life of me, I can't seem to locate it. I had understood that it is inside the frame rail but it doesn't seem to be there. Help!! Dennis Davis 1983 PT35 LOONEYBIN Las Vegas, NV |
02-27-2008, 12:18
Governor
The govenor is mounted directly on the compressor.
Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "ddavisbluebird" > > Hi all. Om a 1983 PT35 I am looking for the air system governor and > for the life of me, I can't seem to locate it. I had understood that > it is inside the frame rail but it doesn't seem to be there. Help!! > Dennis Davis > 1983 PT35 LOONEYBIN > Las Vegas, NV > |
02-27-2008, 13:22
Governor
Not familiar with your 83 PT,
But the governor could be on the compressor or on the frame rail inside. Could be any where between the compressor and the air dryer. search for several lines of small copper tubing, follow the air lines, It looks like this; http://www.bendixvrc.com/itemDisplay.asp...entID=2694 Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "ddavisbluebird" > > Hi all. Om a 1983 PT35 I am looking for the air system governor and > for the life of me, I can't seem to locate it. I had understood that > it is inside the frame rail but it doesn't seem to be there. Help!! > Dennis Davis > 1983 PT35 LOONEYBIN > Las Vegas, NV > |
02-27-2008, 20:56
Governor
Gardner,
You have a FC...are you sure the governor is located the same place as on his PT? Mine wasn't. Hate to see him go on a hunt when there's no chance of catching anything!!
FWIW>>>>
Kevin Mc
YL CA
86 38 pt Delicious ideas to please the pickiest eaters. Watch the video on AOL Living. |
02-28-2008, 01:17
Governor
The governor is located on the back of the compressor it is round about 3 inchs lonG. has a screw off cover for adjust on the right side (looking from flywheel end of engine)
-------------- Original message from "Gardner Yeaw" |
02-28-2008, 10:38
Governor
Kevin,
Aparently I am mistaken. The PT's may have a 'remote mount' governor as explained to me by John Finn on another forum. P.S. I still like your coach, but it is over my price range. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > Gardner, > > You have a FC...are you sure the governor is located the same place as on > his PT? Mine wasn't. Hate to see him go on a hunt when there's no chance of > catching anything!! > > FWIW>>>> > > Kevin Mc > YL CA > 86 38 pt > > > > **************Ideas to please picky eaters. Watch video on AOL Living. > (http://living.aol.com/video/how-to-pleas...er/rachel- campos-duffy/ > 2050827?NCID=aolcmp00300000002598) > |
02-28-2008, 10:48
Governor
I've dropped the price 10K...but haven't advertised it yet.
Kevin Mc
YL CA
86 38 PT (For Sale, but now cheaper!) Delicious ideas to please the pickiest eaters. Watch the video on AOL Living. |
02-29-2008, 05:01
Governor
Hello Dennis:
On my PT, the governor is located on the right (passenger side) top (upper) inside rail, behind the Tag Axel, and aprox 2 feet from the compressor, (and above the transmission). Mine was partially hidden behind a clump of wiring bundles/ hoses, but I could see two of the air lines dropping down to connect to it. As always, yours may be in a completely different locationâ¦, but remember to be safe while under there! Hope this helps, Michael Kramer 86 PT-40 8V92 San Diego, CA --- In WanderlodgeForum@yahoogroups.com, "ddavisbluebird" > > Hi all. Om a 1983 PT35 I am looking for the air system governor and > for the life of me, I can't seem to locate it. I had understood that > it is inside the frame rail but it doesn't seem to be there. Help!! > Dennis Davis > 1983 PT35 LOONEYBIN > Las Vegas, NV > |
