Chassis heat problems
03-22-2008, 02:45
Post: #41
Hi Don,
I know that you don't want to hear this- but it was the one that you're talking about on the bottom of the water pump that failed on mine. Replacing the innards is a good move- and should solve your problem. Some plumbing supply houses may carry new gates and seals for the valve, but good luck finding a perfect match. Sadly, I do not think that there is any way to replace that valve without having the water pump off- and that is a challenge in itself. Maneuvering a 25 lb chunk of iron with fittings and trying to match up the drive gears was a real PITA. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Back for more. Over the past two days I pulled the two gate valves that I show in the image at > http://www.arcatapet.net/image/heaterplumbing.jpg > > Both looked and operated fine, but I agree a ball valve is much better, so I replaced them. Not a fun job getting things out, as there isn't much room to wrench. Had to drop the air conditioning pump down to have room to turn the right-hand one. > > As I was installing the left ball valve, I happened to notice that there was another valve below the water pump - black with grease, and hard to see - even harder to get to. It wasn't until I came back to your post, Shane, to make this post that I happened to read new meaning into the "I've replaced 2 of the 4 valves with ball valves." I assumed you meant 2 gates, 1 Sporlan, 1 Bosch, which is what I knew I had; now I'm thinking you meant 4 gate valves. Am I missing a 4th gate valve somewhere? > > Anyway, I reached down and spun the handle, and spun the handle some more. No stops, either direction. Sigh. I don't think I could get that valve out without removing the water pump, which I really don't want to tackle. > > So, what I did was to unscrew the top of the valve (a difficult thing in its own right), and replace the handle/stem/gate with the best of the other two. You can see it here after replacement, as well as the handle of the left-side ball valve: http://www.arcatapet.net/image/thirdvalve.jpg > > A picture of the valve stems is here: http://www.arcatapet.net/image/erodedthreads.jpg > > On the left is the other "good" valve, and on the right is the bad one from below the water pump. The threads are just eroded away enough that the gate will slip somewhat freely on the stem. > > Unless I can find another valve to look at, tomorrow will be spent filtering 8 gallons of collected coolant for replacement, then checking for leaks, etc. > > |
03-22-2008, 04:15
Post: #42
If the valve is needed??? what is its purpose????? If it was never
used, why have it repalced only to fail again??? could you not just shell out the guts, braze the stem cap hole shut, screw the stem cap back on, then add one other valve down line in a more accessable spot. Don's going to have to replace it again in 2036 anyway. Cutting the valve apart may help removing it 'piece by piece' then replace it with a thru pipe to a better spot. Or disassemble the new valve to reinstall 'part by part'. Tim alerted me that my mountain bike has two flats... Some repairs dont hold purpose. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Hi Don, > > I know that you don't want to hear this- but it was the one that > you're talking about on the bottom of the water pump that failed on > mine. Replacing the innards is a good move- and should solve your > problem. Some plumbing supply houses may carry new gates and seals for > the valve, but good luck finding a perfect match. Sadly, I do not > think that there is any way to replace that valve without having the > water pump off- and that is a challenge in itself. Maneuvering a 25 lb > chunk of iron with fittings and trying to match up the drive gears was > a real PITA. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > > > > Back for more. Over the past two days I pulled the two gate valves > that I show in the image at > > http://www.arcatapet.net/image/heaterplumbing.jpg > > > > Both looked and operated fine, but I agree a ball valve is much > better, so I replaced them. Not a fun job getting things out, as there > isn't much room to wrench. Had to drop the air conditioning pump down > to have room to turn the right-hand one. > > > > As I was installing the left ball valve, I happened to notice that > there was another valve below the water pump - black with grease, and > hard to see - even harder to get to. It wasn't until I came back to > your post, Shane, to make this post that I happened to read new > meaning into the "I've replaced 2 of the 4 valves with ball valves." I > assumed you meant 2 gates, 1 Sporlan, 1 Bosch, which is what I knew I > had; now I'm thinking you meant 4 gate valves. Am I missing a 4th gate > valve somewhere? > > > > Anyway, I reached down and spun the handle, and spun the handle some > more. No stops, either direction. Sigh. I don't think I could get that > valve out without removing the water pump, which I really don't want > to tackle. > > > > So, what I did was to unscrew the top of the valve (a difficult > thing in its own right), and replace the handle/stem/gate with the > best of the other two. You can see it here after replacement, as well > as the handle of the left-side ball valve: > http://www.arcatapet.net/image/thirdvalve.jpg > > > > A picture of the valve stems is here: > http://www.arcatapet.net/image/erodedthreads.jpg > > > > On the left is the other "good" valve, and on the right is the bad > one from below the water pump. The threads are just eroded away enough > that the gate will slip somewhat freely on the stem. > > > > Unless I can find another valve to look at, tomorrow will be spent > filtering 8 gallons of collected coolant for replacement, then > checking for leaks, etc. > > > > > |
03-22-2008, 04:55
Post: #43
I suspect that valve on the bottom of the water pump takes the highest heat and
flow, which may explain why it erodes faster. Particularly if there is one exit and two returns. I'm still not clear about whether I should be looking for a fourth gate valve? Unless I ever have to remove the water pump for some other reason, I don't think that valve will get replaced. I will keep the other decent core for potential repair in a few years - if push comes to shove I will do what Greg said, gut the valve, and put another immediately downstream. Not necessary to do any major work to gut it, just remove the gate from the stem and discard, then replace the stem. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 3/22/2008 at 1:45 PM sfedeli3 wrote: >Hi Don, > > I know that you don't want to hear this- but it was the one that >you're talking about on the bottom of the water pump that failed on >mine. Replacing the innards is a good move- and should solve your >problem. Some plumbing supply houses may carry new gates and seals for >the valve, but good luck finding a perfect match. Sadly, I do not >think that there is any way to replace that valve without having the >water pump off- and that is a challenge in itself. Maneuvering a 25 lb >chunk of iron with fittings and trying to match up the drive gears was >a real PITA. > >Shane Fedeli >85PT40 >Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > >> >> Back for more. Over the past two days I pulled the two gate valves >that I show in the image at >> http://www.arcatapet.net/image/heaterplumbing.jpg >> >> Both looked and operated fine, but I agree a ball valve is much >better, so I replaced them. Not a fun job getting things out, as there >isn't much room to wrench. Had to drop the air conditioning pump down >to have room to turn the right-hand one. >> >> As I was installing the left ball valve, I happened to notice that >there was another valve below the water pump - black with grease, and >hard to see - even harder to get to. It wasn't until I came back to >your post, Shane, to make this post that I happened to read new >meaning into the "I've replaced 2 of the 4 valves with ball valves." I >assumed you meant 2 gates, 1 Sporlan, 1 Bosch, which is what I knew I >had; now I'm thinking you meant 4 gate valves. Am I missing a 4th gate >valve somewhere? >> >> Anyway, I reached down and spun the handle, and spun the handle some >more. No stops, either direction. Sigh. I don't think I could get that >valve out without removing the water pump, which I really don't want >to tackle. >> >> So, what I did was to unscrew the top of the valve (a difficult >thing in its own right), and replace the handle/stem/gate with the >best of the other two. You can see it here after replacement, as well >as the handle of the left-side ball valve: >http://www.arcatapet.net/image/thirdvalve.jpg >> >> A picture of the valve stems is here: >http://www.arcatapet.net/image/erodedthreads.jpg >> >> On the left is the other "good" valve, and on the right is the bad >one from below the water pump. The threads are just eroded away enough >that the gate will slip somewhat freely on the stem. >> >> Unless I can find another valve to look at, tomorrow will be spent >filtering 8 gallons of collected coolant for replacement, then >checking for leaks, etc. >> >> > > >------------------------------------ > >Yahoo! Groups Links > > > |
03-22-2008, 06:46
Post: #44
Never mind - I found a fourth gate valve. This one is down below the right side
of the Sporlan valve, after the water heater circuit returns. Another hard location, and it is bad. I think I can do the same replacement of the handle/stem/gate that I did on the other one. On 3/22/2008 at 8:55 AM Don Bradner wrote: >I suspect that valve on the bottom of the water pump takes the highest >heat and flow, which may explain why it erodes faster. Particularly if >there is one exit and two returns. I'm still not clear about whether I >should be looking for a fourth gate valve? > >Unless I ever have to remove the water pump for some other reason, I don't >think that valve will get replaced. I will keep the other decent core for >potential repair in a few years - if push comes to shove I will do what >Greg said, gut the valve, and put another immediately downstream. Not >necessary to do any major work to gut it, just remove the gate from the >stem and discard, then replace the stem. > >Don Bradner >90 PT40 "Blue Thunder" >Eureka, CA > >On 3/22/2008 at 1:45 PM sfedeli3 wrote: > >>Hi Don, >> >> I know that you don't want to hear this- but it was the one that >>you're talking about on the bottom of the water pump that failed on >>mine. Replacing the innards is a good move- and should solve your >>problem. Some plumbing supply houses may carry new gates and seals for >>the valve, but good luck finding a perfect match. Sadly, I do not >>think that there is any way to replace that valve without having the >>water pump off- and that is a challenge in itself. Maneuvering a 25 lb >>chunk of iron with fittings and trying to match up the drive gears was >>a real PITA. >> >>Shane Fedeli >>85PT40 >>Hershey, PA >> >> --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" >> >>> >>> Back for more. Over the past two days I pulled the two gate valves >>that I show in the image at >>> http://www.arcatapet.net/image/heaterplumbing.jpg >>> >>> Both looked and operated fine, but I agree a ball valve is much >>better, so I replaced them. Not a fun job getting things out, as there >>isn't much room to wrench. Had to drop the air conditioning pump down >>to have room to turn the right-hand one. >>> >>> As I was installing the left ball valve, I happened to notice that >>there was another valve below the water pump - black with grease, and >>hard to see - even harder to get to. It wasn't until I came back to >>your post, Shane, to make this post that I happened to read new >>meaning into the "I've replaced 2 of the 4 valves with ball valves." I >>assumed you meant 2 gates, 1 Sporlan, 1 Bosch, which is what I knew I >>had; now I'm thinking you meant 4 gate valves. Am I missing a 4th gate >>valve somewhere? >>> >>> Anyway, I reached down and spun the handle, and spun the handle some >>more. No stops, either direction. Sigh. I don't think I could get that >>valve out without removing the water pump, which I really don't want >>to tackle. >>> >>> So, what I did was to unscrew the top of the valve (a difficult >>thing in its own right), and replace the handle/stem/gate with the >>best of the other two. You can see it here after replacement, as well >>as the handle of the left-side ball valve: >>http://www.arcatapet.net/image/thirdvalve.jpg >>> >>> A picture of the valve stems is here: >>http://www.arcatapet.net/image/erodedthreads.jpg >>> >>> On the left is the other "good" valve, and on the right is the bad >>one from below the water pump. The threads are just eroded away enough >>that the gate will slip somewhat freely on the stem. >>> >>> Unless I can find another valve to look at, tomorrow will be spent >>filtering 8 gallons of collected coolant for replacement, then >>checking for leaks, etc. >>> >>> >> >> >>------------------------------------ >> >>Yahoo! Groups Links >> >> >> > > > >------------------------------------ > >Yahoo! Groups Links > > > |
03-22-2008, 07:00
Post: #45
Don,
On mine, there are 4 gate valves for the chassis heater circuits and a 5th for the loop to the water heater. -Shane --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Never mind - I found a fourth gate valve. This one is down below the right side of the Sporlan valve, after the water heater circuit returns. Another hard location, and it is bad. I think I can do the same replacement of the handle/stem/gate that I did on the other one. > > On 3/22/2008 at 8:55 AM Don Bradner wrote: > > >I suspect that valve on the bottom of the water pump takes the highest > >heat and flow, which may explain why it erodes faster. Particularly if > >there is one exit and two returns. I'm still not clear about whether I > >should be looking for a fourth gate valve? > > > >Unless I ever have to remove the water pump for some other reason, I don't > >think that valve will get replaced. I will keep the other decent core for > >potential repair in a few years - if push comes to shove I will do what > >Greg said, gut the valve, and put another immediately downstream. Not > >necessary to do any major work to gut it, just remove the gate from the > >stem and discard, then replace the stem. > > > >Don Bradner > >90 PT40 "Blue Thunder" > >Eureka, CA > > > >On 3/22/2008 at 1:45 PM sfedeli3 wrote: > > > >>Hi Don, > >> > >> I know that you don't want to hear this- but it was the one that > >>you're talking about on the bottom of the water pump that failed on > >>mine. Replacing the innards is a good move- and should solve your > >>problem. Some plumbing supply houses may carry new gates and seals for > >>the valve, but good luck finding a perfect match. Sadly, I do not > >>think that there is any way to replace that valve without having the > >>water pump off- and that is a challenge in itself. Maneuvering a 25 lb > >>chunk of iron with fittings and trying to match up the drive gears was > >>a real PITA. > >> > >>Shane Fedeli > >>85PT40 > >>Hershey, PA > >> |
03-22-2008, 08:08
Post: #46
I cannot find a fifth valve. Do you have a Sporlan in the circuit back there
like I do? If not, perhaps it is the fifth valve. The fourth valve turned out not to be bad. The only thing I can surmise is that it was closed, and I just didn't turn enough times to hit the open stop. Good thing, because it is a different valve body; not a lot of difference, but the gate would not fit from one of the others. Way back in this thread Ron Marabito asked if I had checked the gate valves because they were notorious for working themselves closed. I replied that they were opened, and wire-tied open. Of course at that time I thought I was only talking about two valves. The third and fourth were not tied open. Now they are. On 3/22/2008 at 6:00 PM sfedeli3 wrote: >Don, > > On mine, there are 4 gate valves for the chassis heater circuits and >a 5th for the loop to the water heater. > >-Shane > >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > >> >> Never mind - I found a fourth gate valve. This one is down below the >right side of the Sporlan valve, after the water heater circuit >returns. Another hard location, and it is bad. I think I can do the >same replacement of the handle/stem/gate that I did on the other one. >> >> On 3/22/2008 at 8:55 AM Don Bradner wrote: >> >> >I suspect that valve on the bottom of the water pump takes the highest >> >heat and flow, which may explain why it erodes faster. Particularly if >> >there is one exit and two returns. I'm still not clear about whether I >> >should be looking for a fourth gate valve? >> > >> >Unless I ever have to remove the water pump for some other reason, >I don't >> >think that valve will get replaced. I will keep the other decent >core for >> >potential repair in a few years - if push comes to shove I will do what >> >Greg said, gut the valve, and put another immediately downstream. Not >> >necessary to do any major work to gut it, just remove the gate from the >> >stem and discard, then replace the stem. >> > >> >Don Bradner >> >90 PT40 "Blue Thunder" >> >Eureka, CA >> > >> >On 3/22/2008 at 1:45 PM sfedeli3 wrote: >> > >> >>Hi Don, >> >> >> >> I know that you don't want to hear this- but it was the one that >> >>you're talking about on the bottom of the water pump that failed on >> >>mine. Replacing the innards is a good move- and should solve your >> >>problem. Some plumbing supply houses may carry new gates and seals for >> >>the valve, but good luck finding a perfect match. Sadly, I do not >> >>think that there is any way to replace that valve without having the >> >>water pump off- and that is a challenge in itself. Maneuvering a 25 lb >> >>chunk of iron with fittings and trying to match up the drive gears was >> >>a real PITA. >> >> >> >>Shane Fedeli >> >>85PT40 >> >>Hershey, PA >> >> > > > >------------------------------------ > >Yahoo! Groups Links > > > |
03-22-2008, 08:08
Post: #47
In a message dated 3/22/2008 12:01:05 P.M. Central Standard Time, sfedeli3@... writes:
On mine, there are 4 gate valves for the chassis heater circuits and I always knew about 4 valves, but I wonder if the PO of your coach, installed the 5th valve.
Ernie Ekberg 83PT40 Livingston, Montana Weatherford, Tx Create a Home Theater Like the Pros. Watch the video on AOL Home. |
03-22-2008, 10:12
Post: #48
Four on the floor and a fifth under the seat?
![]() Dick Gideon --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > I cannot find a fifth valve. Do you have a Sporlan in the circuit back there like I do? If not, perhaps it is the fifth valve. > > The fourth valve turned out not to be bad. The only thing I can surmise is that it was closed, and I just didn't turn enough times to hit the open stop. Good thing, because it is a different valve body; not a lot of difference, but the gate would not fit from one of the others. > > Way back in this thread Ron Marabito asked if I had checked the gate valves because they were notorious for working themselves closed. I replied that they were opened, and wire-tied open. Of course at that time I thought I was only talking about two valves. The third and fourth were not tied open. Now they are. > > On 3/22/2008 at 6:00 PM sfedeli3 wrote: > > >Don, > > > > On mine, there are 4 gate valves for the chassis heater circuits and > >a 5th for the loop to the water heater. > > > >-Shane > > > >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > > >> > >> Never mind - I found a fourth gate valve. This one is down below the > >right side of the Sporlan valve, after the water heater circuit > >returns. Another hard location, and it is bad. I think I can do the > >same replacement of the handle/stem/gate that I did on the other one. > >> > >> On 3/22/2008 at 8:55 AM Don Bradner wrote: > >> > >> >I suspect that valve on the bottom of the water pump takes the highest > >> >heat and flow, which may explain why it erodes faster. Particularly if > >> >there is one exit and two returns. I'm still not clear about whether I > >> >should be looking for a fourth gate valve? > >> > > >> >Unless I ever have to remove the water pump for some other reason, > >I don't > >> >think that valve will get replaced. I will keep the other decent > >core for > >> >potential repair in a few years - if push comes to shove I will do what > >> >Greg said, gut the valve, and put another immediately downstream. Not > >> >necessary to do any major work to gut it, just remove the gate from the > >> >stem and discard, then replace the stem. > >> > > >> >Don Bradner > >> >90 PT40 "Blue Thunder" > >> >Eureka, CA > >> > > >> >On 3/22/2008 at 1:45 PM sfedeli3 wrote: > >> > > >> >>Hi Don, > >> >> > >> >> I know that you don't want to hear this- but it was the one that > >> >>you're talking about on the bottom of the water pump that failed on > >> >>mine. Replacing the innards is a good move- and should solve your > >> >>problem. Some plumbing supply houses may carry new gates and seals for > >> >>the valve, but good luck finding a perfect match. Sadly, I do not > >> >>think that there is any way to replace that valve without having the > >> >>water pump off- and that is a challenge in itself. Maneuvering a 25 lb > >> >>chunk of iron with fittings and trying to match up the drive gears was > >> >>a real PITA. > >> >> > >> >>Shane Fedeli > >> >>85PT40 > >> >>Hershey, PA > >> >> > > > > > > > >------------------------------------ > > > >Yahoo! Groups Links > > > > > > > |
03-22-2008, 11:38
Post: #49
Success! After cleaning things up, filtering/replacing the captured coolant,
plus buying more, then warming the engine up, I have heat again. For those who wondered whether heat requires the thermostat on the engine to be open, it doesn't. Well before the gauge hit 100 I had noticeable warmth, and by the time it was around 120 it could be categorized as hot air. When checking under the front end for leaks where I removed and re-installed the Bosch valve there was a discernible rush of fluid as the timer cycled. My best guess is that the problem was the fourth valve vibrating closed, but the failing third valve certainly needed to be fixed. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 3/22/2008 at 12:08 PM Don Bradner wrote: >I cannot find a fifth valve. Do you have a Sporlan in the circuit back >there like I do? If not, perhaps it is the fifth valve. > >The fourth valve turned out not to be bad. The only thing I can surmise is >that it was closed, and I just didn't turn enough times to hit the open >stop. Good thing, because it is a different valve body; not a lot of >difference, but the gate would not fit from one of the others. > >Way back in this thread Ron Marabito asked if I had checked the gate >valves because they were notorious for working themselves closed. I >replied that they were opened, and wire-tied open. Of course at that time >I thought I was only talking about two valves. The third and fourth were >not tied open. Now they are. > >On 3/22/2008 at 6:00 PM sfedeli3 wrote: > >>Don, >> >> On mine, there are 4 gate valves for the chassis heater circuits and >>a 5th for the loop to the water heater. >> >>-Shane >> >>--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" >> >>> >>> Never mind - I found a fourth gate valve. This one is down below the >>right side of the Sporlan valve, after the water heater circuit >>returns. Another hard location, and it is bad. I think I can do the >>same replacement of the handle/stem/gate that I did on the other one. >>> >>> On 3/22/2008 at 8:55 AM Don Bradner wrote: >>> >>> >I suspect that valve on the bottom of the water pump takes the highest >>> >heat and flow, which may explain why it erodes faster. Particularly if >>> >there is one exit and two returns. I'm still not clear about whether I >>> >should be looking for a fourth gate valve? >>> > >>> >Unless I ever have to remove the water pump for some other reason, >>I don't >>> >think that valve will get replaced. I will keep the other decent >>core for >>> >potential repair in a few years - if push comes to shove I will do what >>> >Greg said, gut the valve, and put another immediately downstream. Not >>> >necessary to do any major work to gut it, just remove the gate from the >>> >stem and discard, then replace the stem. >>> > >>> >Don Bradner >>> >90 PT40 "Blue Thunder" >>> >Eureka, CA >>> > >>> >On 3/22/2008 at 1:45 PM sfedeli3 wrote: >>> > >>> >>Hi Don, >>> >> >>> >> I know that you don't want to hear this- but it was the one that >>> >>you're talking about on the bottom of the water pump that failed on >>> >>mine. Replacing the innards is a good move- and should solve your >>> >>problem. Some plumbing supply houses may carry new gates and seals for >>> >>the valve, but good luck finding a perfect match. Sadly, I do not >>> >>think that there is any way to replace that valve without having the >>> >>water pump off- and that is a challenge in itself. Maneuvering a 25 lb >>> >>chunk of iron with fittings and trying to match up the drive gears was >>> >>a real PITA. >>> >> >>> >>Shane Fedeli >>> >>85PT40 >>> >>Hershey, PA >>> >> >> >> >> >>------------------------------------ >> >>Yahoo! Groups Links >> >> >> > > > >------------------------------------ > >Yahoo! Groups Links > > > Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
