Definitve answer to Halogen bub size
04-17-2008, 03:12
The fixture was manufactured by C I in Riverside Ca. Model #F33-9102
It takes a 12V-10Watt/T3 Bi-Pin for rv use only. I found the bulbs at a reasonable price at 1000bulbs.com http://www.1000bulbs.com/12-Volt-G4-Base...enon/5987/ These bulbs are round at the end, unlike the T-4 which has a small tip on it. Here is an alternative L.E.D replacement for the halogen, they will fit in the puck and look like a good idea although they are expensive. http://www.prudentrver.com/ledlamps.html Kurt Horvath 95 PT-42 WLWB |
