Genset in/out actuator
06-24-2008, 09:18
Hi Steve, good to hear from you. Sorry that I can't help out.Hi to Kathey. Brenda will be flying to Montana in Aug.
Ernie Ekberg 83PT40 Livingston, Montana Gas prices getting you down? Search AOL Autos for fuel-efficient used cars. |
06-24-2008, 11:47
Hey y'all ... Kat & I still have our bird although we still aren't
using 'er (work all the durn time). Of course that means when we do use 'er I've gotta work on 'er ... right?? The worm gear that moves the generator compartment out & in is wore out. Motor still seems to be okay but the worm gear is horrible. It is of the same design as the ones used to position large satellite dishes (y'all remember C band don't you?). Does anyone know a source other than BB to order a replacement unit? Someday I'll share some of my "war stories" re: getting a stuck genset to go back in ... or even better ... getting it out. Steve & Kathy Enfinger Newton, GA '91 WBSA |
06-24-2008, 12:07
Hey Steve,
Why wait for someday? Please feel free to immediately share the story of how you got the stuck genset to go back in with the worm gear not working. You know, just in case some other 91 model owner might be interested. LOL.... and needing to file that for future reference. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX - also not getting much use due to that same durn work reason -- In WanderlodgeForum@yahoogroups.com, "Steve & Kathy Enfinger" > > Hey y'all ... Kat & I still have our bird although we still aren't > using 'er (work all the durn time). Of course that means when we do > use 'er I've gotta work on 'er ... right?? > > The worm gear that moves the generator compartment out & in is wore > out. Motor still seems to be okay but the worm gear is horrible. It is > of the same design as the ones used to position large satellite dishes > (y'all remember C band don't you?). > > Does anyone know a source other than BB to order a replacement unit? > > Someday I'll share some of my "war stories" re: getting a stuck genset > to go back in ... or even better ... getting it out. > > Steve & Kathy Enfinger > Newton, GA > '91 WBSA > |
06-24-2008, 14:00
Steve the device is called a Linear Actuator
You can GOOGLE it or try the link below these guys rebuild them http://www.edriveactuators.com/ Kurt Horvath 95 PT-42 10AC --- In WanderlodgeForum@yahoogroups.com, "Steve & Kathy Enfinger" > > Hey y'all ... Kat & I still have our bird although we still aren't > using 'er (work all the durn time). Of course that means when we do > use 'er I've gotta work on 'er ... right?? > > The worm gear that moves the generator compartment out & in is wore > out. Motor still seems to be okay but the worm gear is horrible. It is > of the same design as the ones used to position large satellite dishes > (y'all remember C band don't you?). > > Does anyone know a source other than BB to order a replacement unit? > > Someday I'll share some of my "war stories" re: getting a stuck genset > to go back in ... or even better ... getting it out. > > Steve & Kathy Enfinger > Newton, GA > '91 WBSA > |
06-24-2008, 22:51
you will probably find that the linear drive onyour coach was made by
warner electric brake now owned by Danaher Motion. Stephen 77fc35 dupreeproducts.com -- In WanderlodgeForum@yahoogroups.com, "bumpersbird" > > > Steve the device is called a Linear Actuator > > You can GOOGLE it or try the link below these guys rebuild them > > http://www.edriveactuators.com/ > > Kurt Horvath > 95 PT-42 > 10AC > > > > --- In WanderlodgeForum@yahoogroups.com, "Steve & Kathy Enfinger" > > > > > Hey y'all ... Kat & I still have our bird although we still aren't > > using 'er (work all the durn time). Of course that means when we do > > use 'er I've gotta work on 'er ... right?? > > > > The worm gear that moves the generator compartment out & in is wore > > out. Motor still seems to be okay but the worm gear is horrible. It > is > > of the same design as the ones used to position large satellite > dishes > > (y'all remember C band don't you?). > > > > Does anyone know a source other than BB to order a replacement unit? > > > > Someday I'll share some of my "war stories" re: getting a stuck > genset > > to go back in ... or even better ... getting it out. > > > > Steve & Kathy Enfinger > > Newton, GA > > '91 WBSA > > > |
