					Water heater drain valve 90 SP36
					08-04-2008, 08:39
					Last week I asked about a possible water heater replacement
			because of a leak. Well the leak was a bad fitting but now after cleaning the crap out of the drain valve, it leaks and I can't find a replacement. It is 1/4" npt with a tubing flange on the bottom. Chuck Harrison Akron, Ohio 90 SP36  |
