The Fun Begins, Or my first day with our New to us Wanderlodge
10-15-2008, 17:19
Well I can finially say that I am not just a dreamer, but an OWNER.
Monday we went and looked at a "1982 WONDERLODGE" turned out to be a 83 Wanderlodge. on the first inspection, lots of things didn't work. Would not air up, constant low air alarm, huge oil leak, genset would not go back in, and several other things. Went down there with the intent to buy on the spot. It was a 3.5 hour drive each way and didn't want to make that trip anymort than we had to. After crawing around the coach for a couple of hours and messing with the air, it was still hoplessly sitting low. Came back home with hopes dashed somewhat. Thought about it all the way home and most of the next day. Then made a phone call to the owner and discussed condition, after some back and forth we agreed on a very reduced price. Tue got ready for a trip with jacks, blocks, bars, chains, wrenches, and most every other tool I could think of. Today was the day for the adventure. My father volunteered to go with me, he was a commercial truck driver so he had a ton more experience than I do with air systems. Long story short, after messing with it for about 30 min we had her up on air. Still had an alarm that would sound for awhile then go off. Looked like pressure was just about 100 lbs and holding steady. We took a good look around, secured the genset with a strap. and hit the road. Traveled about 20 min and stopped for fuel, guage said 1/2 of tank but had no idea if it was true or not. Put $100.00 in it and $50.00 in the dodge and kept heading north. Had my GPS with me so I checked the speedo and it was very close. Temp stayed between 185- 195, oil pressure was 75 lbs at cruising and 50 @ idle. Had a 4 hour drive, everything worked great. The 3208 sung the whole way. Didn't touch anything except the basics, didn't want to turn something on and loose all of my air. The air stayed real steady, but did have an alarm from time to time. Think I have at least one leak. So tomorrow (thur) will will start making a list of things to fix. At that point we will try to put them in order of importance, (air being rite up on the top). Mechanicly it seams very sound. Ran great, had great presure, and temp was fine. Think after I get the air taken care of, I will take it in for a oil change and radiator flush. Overall very happy, had a nice 4 hour drive with our "new" bird. lost all of the white knuckles after about 20 min. The more I drove it the more I could tell what it was going to do with big bump. Overall a very smooth ride, easy to controll and very confortable. More to come Looking for suggestions on best way to troubleshoot the air system, Will have to rebuild the generator tray, (it took a big hit to the door). Have seen a couple that have been modified with the radiator flat. Will look more into that. Know I need to do the relays for the dash lights. Somethings need fixed now some will wait. I look forward to attacking each one. And the musical horn does work.............. got a smile out of my brother on that one.... Thanks Gang. John & Pong |
10-16-2008, 00:29
John,
Welcome to the ownership crowd! Thanks for the first day report. Luckily, it was fairly uneventful. May all your trips be like that. Now,....... let the fun begin! Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX P.S. Don't forget to sign your location so your new Bird family can find you to help and invite you to local rallies. --- In WanderlodgeForum@yahoogroups.com, "jcpryn" > > Well I can finially say that I am not just a dreamer, but an OWNER. > > Monday we went and looked at a "1982 WONDERLODGE" turned out to be a > 83 Wanderlodge. > > on the first inspection, lots of things didn't work. Would not air > up, constant low air alarm, huge oil leak, genset would not go back > in, and several other things. > > Went down there with the intent to buy on the spot. It was a 3.5 > hour drive each way and didn't want to make that trip anymort than we > had to. After crawing around the coach for a couple of hours and > messing with the air, it was still hoplessly sitting low. Came back > home with hopes dashed somewhat. > > Thought about it all the way home and most of the next day. Then > made a phone call to the owner and discussed condition, after some > back and forth we agreed on a very reduced price. > > Tue got ready for a trip with jacks, blocks, bars, chains, wrenches, > and most every other tool I could think of. > > Today was the day for the adventure. > My father volunteered to go with me, he was a commercial truck > driver so he had a ton more experience than I do with air systems. > Long story short, after messing with it for about 30 min we had her > up on air. Still had an alarm that would sound for awhile then go > off. Looked like pressure was just about 100 lbs and holding steady. > We took a good look around, secured the genset with a strap. and hit > the road. Traveled about 20 min and stopped for fuel, guage said 1/2 > of tank but had no idea if it was true or not. Put $100.00 in it and > $50.00 in the dodge and kept heading north. Had my GPS with me so I > checked the speedo and it was very close. Temp stayed between 185- > 195, oil pressure was 75 lbs at cruising and 50 @ idle. > > Had a 4 hour drive, everything worked great. The 3208 sung the whole > way. Didn't touch anything except the basics, didn't want to turn > something on and loose all of my air. The air stayed real steady, > but did have an alarm from time to time. Think I have at least one > leak. > > So tomorrow (thur) will will start making a list of things to fix. > At that point we will try to put them in order of importance, (air > being rite up on the top). Mechanicly it seams very sound. Ran > great, had great presure, and temp was fine. Think after I get the > air taken care of, I will take it in for a oil change and radiator > flush. > > > Overall very happy, had a nice 4 hour drive with our "new" bird. > lost all of the white knuckles after about 20 min. The more I drove > it the more I could tell what it was going to do with big bump. > Overall a very smooth ride, easy to controll and very confortable. > > More to come > > Looking for suggestions on best way to troubleshoot the air system, > Will have to rebuild the generator tray, (it took a big hit to the > door). Have seen a couple that have been modified with the radiator > flat. Will look more into that. > > Know I need to do the relays for the dash lights. > > Somethings need fixed now some will wait. I look forward to > attacking each one. > > And the musical horn does work.............. got a smile out of my > brother on that one.... > > > > Thanks Gang. > > John & Pong > |
10-16-2008, 04:46
Hola John & Pong,
We just bought our 84FC35 in the beginning of Sept. and have had plenty of adventure so far too. Every valve that had anything to do with some liquid leaked. The generator has only worked a half a dozen days in 6 weeks. We've been stuck in Walmarts with one leveler stuck down and state parks with the generator tray out. Driven 5 hours with some warning buzzer we couldn't identify going on an off. Still can't get the forward heater working. Purrrra vida! The musical horn works. However everywhere we go people look and smile. Maybe it's all worth it. Join the FC group for the specific photos, files,etc. http://autos.groups.yahoo.com/group/FC_Wanderlodge/ See ya on down the road, GPSGary & Hippieforever |
10-16-2008, 06:09
>> GPSGary & Hippieforever > Have you played with the gate valve that controls the flow of coolant to that front heater? kerry 82 FC 35 Denver |
10-16-2008, 08:34
I can't get either front heater working but I'm still working on the
generator and slide. Finally found a place that would order me the generator slide microswitch. Nice people they had to order 5 so if anyone needs one I can have them ship you one. Regards, GPSGary --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > Still can't get the forward heater working. > >> GPSGary & Hippieforever > > > > Have you played with the gate valve that controls the flow of coolant > to that front heater? > > kerry > 82 FC 35 > Denver > |
