Going to get coach
10-20-2008, 02:19
Post: #31
Going to get coach
Thanks Leroy. I hope my luck is better also.
R.E. (Ron) Marabito, Dallas, TX 92WB40 Currently at the airport. --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert wrote: > > Based on my personal research and discussions with BB after this event occurred, the coolant level sensor (installed in the highest point of the radiator coolant) should have sent the engine with a DDEC II into Ramp Mode as all 8v92's with DDEC II were sent out from BB with this pre programmed. High coolant temp may not have worked if the water abruptly dumped into the crankcase but one should also expect high tranny temps in this case also. The sensors on my coach which can only safely be checked by hooking up a tester on the DDL are, coolant level, low oil pressure, high water temperature, and low fuel pressure.I have an optional coolant level module also. According to BB all should give an alarm if working properly and initiate Ramp Mode within 15 seconds of an event occurring outside the pre programmed parameters in the DDEC II. The buzzing when the key is turned on checks the circuits integrity, not the integrety of the sensors themselves. I gotta > get my coach to a shop and get it checked out. I know my coolant level is working because I removed fluid from the tank and checked it. > BB emphatically advised me not to go crossing wires on the various sensors as it could severely damage the DDEC II system. > I hope you have great luck from here on out. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > --- On Sun, 10/19/08, Don Bradner > From: Don Bradner > Subject: Re: [WanderlodgeForum] Re: Going to get coach > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, October 19, 2008, 4:16 PM > > > > > > > > > > > > Correct - the DDECII does not output engine oil temp, or it would be simple to rig an alarm with VMSPC when it reached some temp. > > > > I do have an analog oil temp gauge, but it runs pretty high all of the time - I'm not sure I would notice unless it *really* went high! > > > > On 10/19/2008 at 7:30 PM ronmarabito2002 wrote: > > > > >Only thing I can think of is for the safety sensors to shut it down > > >first. Since the coolant temp did not rise, that sensor didn't do > > >anything. It needs an oil temp sensor, but this model didn't have > > >one. I'm planning to get a hold of Detroit to find out if one can be > > >added. But I think it has to do with the DDEC II > > > > > >R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "Dan Williams" > > >wrote: > > >> > > >> Ron, Is there anything that can be done to the engine to keep this from > > >> happening again? > > >> > > >> Dan, 8v92, Jackson, ms > > >> > > >> > > >> > > >> > > >> > > >> _____ > > >> > > >> From: WanderlodgeForum@ yahoogroups. com > > >> [mailto:WanderlodgeForum@ yahoogroups. com] On Behalf Of ronmarabito2002 > > >> Sent: Sunday, October 19, 2008 11:00 AM > > >> To: WanderlodgeForum@ yahoogroups. com > > >> Subject: [WanderlodgeForum] Going to get coach > > >> > > >> > > >> > > >> Hi to all of you. I paid the bill in Calgary yesterday via direct > > >> wire transfer. The good news is: the exchange rate saved me about > > >> $4,000 dollars, so all is not bad. > > >> > > >> I will fly to Calgary in the morning to pick up the coach. I will > > >> have to button up the bedroom, since they wanted to charge me over > > >> $600 labor to do that. I won't leave Calgary until Tuesday morning. > > >> Plan to stop see a friend in Lewistown, MT hopefully the first night > > >> out. Depends on how I have to run with the re-built engine. I will > > >> take a route back home avoiding as much mountain driving as possible. > > >> > > >> Once back in the US and further south, I should be able to get back > > >> on line using my dish and I can give a report on how the engine is > > >> performing. > > >> > > >> Dick: Sorry to hear about you tranny problems. Hope they are minor. > > >> > > >> R.E. (Ron) Marabito, Dallas, TX 92WB40 > > >> > > > > > > > > > > > >----------- --------- --------- ------- > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > |
10-20-2008, 04:03
Post: #32
Going to get coach
Leroy, I guess the sender at the puke tank is more of a on off
switch. you can remove the two wires and test for continuity at ideal condition?? One other area of issue is the overbuilt cooling system integrity. the hoses are all top of the line major buck multiply material and even the puketank is high quality stainless steel. If the radiator cap is the only place to relieve over heat coolant pressure the line to the tank and the cap have to do their job when called for. If the cap wont open and the line is not of a larg enough id (CurtS coolant filter??) the next week link could be a minor compramised liner seal. Even the high fail hose to the aircompressor ages to handel more pressure untill it cracks from an external flex. then there is the dynamic that while overheating you are puking into the p tank and sending a signal to the coolant level modual that all is well with coolant level. Ross, if I has a $9,000 generator in my boat, there would be no room for the ores Greg94ptCa --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Your line of thinking is parallel to mine except the prints for my coolant level sensor show the switch open. If the drawing is for normal conditions including full water in the puke tank then presumably the sender closes forming a circuit in abnormal conditions ie. low coolant.????Then the module sends a prompt to the DDEC II to go to ramp mode and cut off impulses to 4 of the EUI's. Presumably, it also disables the cruise enable also. It seems if the switch is normally open, if circuit wires were shorted or the module was shorted internally the indication prior to start would be "do not start" and a stop engine light, but I do not have enough schematics or books on the DDEC II to figure it out. What do you think? > I want to completely understand this system if possible. Maybe someone else understands the thing. I have gotten this far by studying my master coach prints, the generic systems in the DD manual, an overall generic DDEC II schematic and talking to Glen Rogers at BB. He was on the line when my coach was built. > The coolant module is in the lower load center in the front of the coach. It has 5 wires and is a DDEC system. Ignition hot, ground all the way to the batteries, (this ground is tied into the ATEC trans system and the cruise enable also), data wire to the ECM and two wires to the sensor. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > --- On Sun, 10/19/08, Gregory OConnor > From: Gregory OConnor > Subject: [WanderlodgeForum] Re: Going to get coach > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, October 19, 2008, 9:10 PM > > > > > > > > > > > > included in the coolant level warning there is a sensor/sender with two wires, on puke tank a seperate module unit with five wires, some place?' and wires' . > If the sender makes contact to complete a ground to prove proper coolant level, a short in the sender or module or wires could cause a false OK to operate signal. > Â If the sender loosing contact and not delivering continious ground is the signal that puts the bus in ramp mode ( 4 cylinder power) then the ground to the module could be disconnected. > if you remember back to a 94pt post about loosing one of two DDec computer 12v+power links from the battery to the Ddec and the post claimed that it was the power to 1/2 the cylinders. Ikinda think half the power is a wierd way to wire 1/2 a computer and always wondered why his bus would run on 4 cyls. Â Â since ramp mode is 4 cylinders, may have been the ground in the battery area (where the coolant module gets its ground) that when cleaned up( in the blind search for a fix), finaly kept the bus out of ramp???????? > > Greg94ptCa > > --- In WanderlodgeForum@ yahoogroups. com, Leroy Eckert > > > > Based on my personal research and discussions with BB after this event occurred, the coolant level sensor (installed in the highest point of the radiator coolant) should have sent the engine with a DDEC II into Ramp Mode as all 8v92's with DDEC II were sent out from BB with this pre programmed. High coolant temp may not have worked if the water abruptly dumped into the crankcase but one should also expect high tranny temps in this case also. The sensors on my coach which can only safely be checked by hooking up a tester on the DDL are, coolant level, low oil pressure, high water temperature, and low fuel pressure.I have an optional coolant level module also. According to BB all should give an alarm if working properly and initiate Ramp Mode within 15 seconds of an event occurring outside the pre programmed parameters in the DDEC II. The buzzing when the key is turned on checks the circuits integrity, not the integrety of the sensors themselves. I gotta > > get my coach to a shop and get it checked out. I know my coolant level is working because I removed fluid from the tank and checked it. > > BB emphatically advised me not to go crossing wires on the various sensors as it could severely damage the DDEC II system. > > I hope you have great luck from here on out. > > Leroy Eckert > > 1990 WB-40 Smoke N Mirrors > > Dahlonega, GA > > Royale Conversion > > > > --- On Sun, 10/19/08, Don Bradner bluethunder@ ... wrote: > > From: Don Bradner bluethunder@ ... > > Subject: Re: [WanderlodgeForum] Re: Going to get coach > > To: WanderlodgeForum@ yahoogroups. com > > Date: Sunday, October 19, 2008, 4:16 PM > > > > > > > > > > > > > > > > > > > > > > > > Correct - the DDECII does not output engine oil temp, or it would be simple to rig an alarm with VMSPC when it reached some temp. > > > > > > > > I do have an analog oil temp gauge, but it runs pretty high all of the time - I'm not sure I would notice unless it *really* went high! > > > > > > > > On 10/19/2008 at 7:30 PM ronmarabito2002 wrote: > > > > > > > > >Only thing I can think of is for the safety sensors to shut it down > > > > >first. Since the coolant temp did not rise, that sensor didn't do > > > > >anything. It needs an oil temp sensor, but this model didn't have > > > > >one. I'm planning to get a hold of Detroit to find out if one can be > > > > >added. But I think it has to do with the DDEC II > > > > > > > > > >R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "Dan Williams" danusa@ > > > > >wrote: > > > > >> > > > > >> Ron, Is there anything that can be done to the engine to keep this from > > > > >> happening again? > > > > >> > > > > >> Dan, 8v92, Jackson, ms > > > > >> > > > > >> > > > > >> > > > > >> > > > > >> > > > > >> _____ > > > > >> > > > > >> From: WanderlodgeForum@ yahoogroups. com > > > > >> [mailto:Wanderlodge Forum@ yahoogroups. com] On Behalf Of ronmarabito2002 > > > > >> Sent: Sunday, October 19, 2008 11:00 AM > > > > >> To: WanderlodgeForum@ yahoogroups. com > > > > >> Subject: [WanderlodgeForum] Going to get coach > > > > >> > > > > >> > > > > >> > > > > >> Hi to all of you. I paid the bill in Calgary yesterday via direct > > > > >> wire transfer. The good news is: the exchange rate saved me about > > > > >> $4,000 dollars, so all is not bad. > > > > >> > > > > >> I will fly to Calgary in the morning to pick up the coach. I will > > > > >> have to button up the bedroom, since they wanted to charge me over > > > > >> $600 labor to do that. I won't leave Calgary until Tuesday morning. > > > > >> Plan to stop see a friend in Lewistown, MT hopefully the first night > > > > >> out. Depends on how I have to run with the re-built engine. I will > > > > >> take a route back home avoiding as much mountain driving as possible. > > > > >> > > > > >> Once back in the US and further south, I should be able to get back > > > > >> on line using my dish and I can give a report on how the engine is > > > > >> performing. > > > > >> > > > > >> Dick: Sorry to hear about you tranny problems. Hope they are minor. > > > > >> > > > > >> R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > >> > > > > > > > > > > > > > > > > > > > >----------- --------- --------- ------- > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ____________ _________ _________ _________ _________ __ > > Do You Yahoo!? > > Tired of spam? Yahoo! Mail has the best spam protection around > > http://mail. yahoo.com > > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > |
10-20-2008, 04:45
Post: #33
Going to get coach
10-20-2008, 06:43
Post: #34
Going to get coach
Greg, Leroy I had a bad sender at the puke tank this Steve Quandt 1993 PT-40 Iron Mountain, MI From: WanderlodgeForum@yahoogroups.com Leroy, I guess the sender at the puke tank is more of a on off switch. you can remove the two wires and test for continuity at ideal condition?? One other area of issue is the overbuilt cooling system integrity. the hoses are all top of the line major buck multiply material and even the puketank is high quality stainless steel. If the radiator cap is the only place to relieve over heat coolant pressure the line to the tank and the cap have to do their job when called for. If the cap wont open and the line is not of a larg enough id (CurtS coolant filter??) the next week link could be a minor compramised liner seal. Even the high fail hose to the aircompressor ages to handel more pressure untill it cracks from an external flex. then there is the dynamic that while overheating you are puking into the p tank and sending a signal to the coolant level modual that all is well with coolant level. Ross, if I has a $9,000 generator in my boat, there would be no room for the ores Greg94ptCa --- In "WanderlodgeForum%40yahoogroups.com", Leroy Eckert > > Your line of thinking is parallel to mine except the prints for my coolant level sensor show the switch open. If the drawing is for normal conditions including full water in the puke tank then presumably the sender closes forming a circuit in abnormal conditions ie. low coolant.???? DDEC II to go to ramp mode and cut off impulses to 4 of the EUI's. Presumably, it also disables the cruise enable also. It seems if the switch is normally open, if circuit wires were shorted or the module was shorted internally the indication prior to start would be "do not start" and a stop engine light, but I do not have enough schematics or books on the DDEC II to figure it out. What do you think? > I want to completely understand this system if possible. Maybe someone else understands the thing. I have gotten this far by studying my master coach prints, the generic systems in the DD manual, an overall generic DDEC II schematic and talking to Glen Rogers at BB. He was on the line when my coach was built. > The coolant module is in the lower load center in the front of the coach. It has 5 wires and is a DDEC system. Ignition hot, ground all the way to the batteries, (this ground is tied into the ATEC trans system and the cruise enable also), data wire to the ECM and two wires to the sensor. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > > Royale Conversion > > --- On Sun, 10/19/08, Gregory OConnor > From: Gregory OConnor > Subject: [WanderlodgeForum] Re: Going to get coach > To: "WanderlodgeForum%40yahoogroups.com" > Date: Sunday, October 19, 2008, 9:10 PM > > > > > > > > > > > > included in the coolant level warning there is a sensor/sender with two wires, on puke tank a seperate module unit with five wires, some place?' and wires' . > If the sender makes contactto complete a ground to prove proper coolant level, a short in the sender or module or wires could cause a false OK to operate signal. > If the sender loosing contact and not delivering continious ground is the signal that puts the bus in ramp mode ( 4 cylinder power) then the ground to the module could be disconnected. > if you remember back toa 94pt postabout loosing one of two DDec computer 12v+powerlinks from the battery to the Ddec and the post claimed that it was the power to 1/2 the cylinders. Ikinda think half the power is a wierd way to wire 1/2 a computer and always wondered why his bus would run on 4 cyls. since ramp mode is 4 cylinders, may have been the ground in the battery area (where the coolant module gets its ground) that when cleaned up( in the blind search for a fix), finaly kept the bus out of ramp???????? > > Greg94ptCa > > --- In WanderlodgeForum@ yahoogroups. com, Leroy Eckert > > > > Based on my personal research and discussions with BB after this event occurred, the coolant level sensor (installed in the highest point of the radiator coolant) should have sent the engine with a DDEC II into Ramp Mode as all 8v92's with DDEC II were sent out from BB with this pre programmed. High coolant temp may not have worked if the water abruptly dumped into the crankcase but one should also expect high tranny temps in this case also. The sensors on my coach which can only safely be checked by hooking up a tester on the DDL are, coolant level, low oil pressure, high water temperature, and low fuel pressure.I have an optional coolant level module also. According to BB all should give an alarm if working properly and initiate Ramp Mode within 15 seconds of an event occurring outside the pre programmed parameters in the DDEC II. The buzzing when the key is turned on checks the circuits integrity, not the integrety of the sensors themselves. I gotta > > get my coach to a shop and get it checked out. I know my coolant level is working because I removed fluid from the tank and checked it. > > BB emphatically advised me not to go crossing wires on the various sensors as it could severely damage the DDEC II system. > > I hope you have great luck from here on out. > > Leroy Eckert > > 1990 WB-40 Smoke N Mirrors > > > > Royale Conversion > > > > --- On Sun, 10/19/08, Don Bradner bluethunder@ ... wrote: > > From: Don Bradner bluethunder@ ... > > Subject: Re: [WanderlodgeForum] Re: Going to get coach > > To: WanderlodgeForum@ yahoogroups. com > > Date: Sunday, October 19, 2008, 4:16 PM > > > > > > > > > > > > > > > > > > > > > > > > Correct - the DDECII does not output engine oil temp, or it would be simple to rig an alarm with VMSPC when it reached some temp. > > > > > > > > I do have an analog oil temp gauge, but it runs pretty high all of the time - I'm not sure I would notice unless it *really* went high! > > > > > > > > On 10/19/2008 at 7:30 PM ronmarabito2002 wrote: > > > > > > > > >Only thing I can think of is for the safety sensors to shut it down > > > > >first. Since the coolant temp did not rise, that sensor didn't do > > > > >anything. It needs an oil temp sensor, but this model didn't have > > > > >one. I'm planning to get a hold of can be > > > > >added. But I think it has to do with the DDEC II > > > > > > > > > >R.E. (Ron) Marabito, > > > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "Dan Williams" danusa@ > > > > >wrote: > > > > >> > > > > >> Ron, Is there anything that can be done to the engine to keep this from > > > > >> happening again? > > > > >> > > > > >> Dan, 8v92, ms > > > > >> > > > > >> > > > > >> > > > > >> > > > > >> > > > > >> _____ > > > > >> > > > > >> From: WanderlodgeForum@ yahoogroups. com > > > > >> [mailto:Wanderlodge Forum@ yahoogroups. com] On Behalf Of ronmarabito2002 > > > > >> Sent: Sunday, October 19, 2008 11:00 AM > > > > >> To: WanderlodgeForum@ yahoogroups. com > > > > >> Subject: [WanderlodgeForum] Going to get coach > > > > >> > > > > >> > > > > >> > > > > >> Hi to all of you. I paid the bill in direct > > > > >> wire transfer. The good news is: the exchange rate saved me about > > > > >> $4,000 dollars, so all is not bad. > > > > >> > > > > >> I will fly to in the morning to pick up the coach. I will > > > > >> have to button up the bedroom, since they wanted to charge me over > > > > >> $600 labor to do that. I won't leave morning. > > > > >> Plan to stop see a friend in hopefully the first night > > > > >> out. Depends on how I have to run with the re-built engine. I will > > > > >> take a route back home avoiding as much mountain driving as possible. > > > > >> > > > > >> Once back in the able to get back > > > > >> on line using my dish and I can give a report on how the engine is > > > > >> performing. > > > > >> > > > > >> Dick: Sorry to hear about you tranny problems. Hope they are minor. > > > > >> > > > > >> R.E. (Ron) Marabito, > > > > >> > > > > > > > > > > > > > > > > > > > >----------- --------- --------- ------- > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ____________ _________ _________ _________ _________ __ > > Do You Yahoo!? > > Tired of spam? Yahoo! Mail has the best spam protection around > > http://mail. yahoo.com > > > > > > > > > > > > > > > > > > > > > > > > > > > ____________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail. > |
10-20-2008, 07:59
Post: #35
Going to get coach
Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
10-20-2008, 14:19
Post: #36
Going to get coach
When you get antifreeze in oil it will look milky in color. I don't
think I would want to taste either. Craig Hovda 90WLWB Bigfork Mt --- In WanderlodgeForum@yahoogroups.com, Wallace Craig > > Not to make too fine a point of it, but I said taste sweet, not smell. But then who the hell would want to taste that hot mess?? lol > > > Wallace Craig > 95 WLWB 42 > Azle, Texas > > --- On Sun, 10/19/08, erniecarpet@... > > From: erniecarpet@... > Subject: Re: [WanderlodgeForum] Re: Going to get coach > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, October 19, 2008, 7:52 PM > > > > Wallace, when Brenda and I arrived right behind you and witnessed the gooey mess coming from your engine and all over you Durango, I don't recall anything smelling sweet. As I recall, it was a light brown in color. > > Ernie Ekberg > 83PT40 > Weatherford, Texas > > > > > > New MapQuest Local shows what's happening at your destination. Dining, Movies, Events, News & more. Try it out! > |
