3208 Cat engine
10-27-2008, 08:53
3208 Cat engine
I own aBB motorhome with a 3208 Cat Turbo.
Couple of questions:
Has anyone put on a bypass filter? If so what type, kind?
I have read a lotabout synthetic oils, is it really worth the cost?
Also, any preference as to type?
Thanks in advance Bill 84 FC 35 SB "$quanderlodge"Terrace, B.C. Canada Instant message from any web browser! Try the new Yahoo! Canada Messenger for the Web BETA |
10-27-2008, 12:16
3208 Cat engine
--- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs
> > I own a BB motorhome with a 3208 Cat Turbo. > > Couple of questions: > Has anyone put on a bypass filter? If so what type, kind? > > I have read a lot about synthetic oils, is it really worth the cost? > Also, any preference as to type? > > Thanks in advance Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > Bill, I have a 3208 TA cat in my 89 SP. Do not know why you would want a bypass filter with two full flow filters on the engine now. I have over 150,000 miles and 4000 hours on my engine with no repair other than a valve adjustment and a new seal on the injector pump. In my opinion, synthetic oils are great if you have an engine that operates at high oil temperatures (250 deg. F or higer -- ie race engines). Do not feel in my case that the extra expense is worth it in the Bird. I am sure you will find others with differing opinions however. Jim Brookshire 1989 SP-36 Saluda, NC PS I was an attendee of RIV in Branson who thought it a success considering the current economic climate for RV manufactures. I don't think we would have had 60 coaches at Perry if the rally had to pay the total cost. __________________________________________________________________ > Instant Messaging, free SMS, sharing photos and more... Try the new Yahoo! Canada Messenger at http://ca.beta.messenger.yahoo.com/ > |
10-27-2008, 16:45
3208 Cat engine
Bill,
No bypass filter, but the PO put in Delvac synthetic, the bus came with a 5 gal can of it so I continued the use... Runs a little cooler and does not use any or burn any... HTH Sea Ya Larry NYC 84 35FCSB 'Pura Vida' From: Wilhelmus Schreurs To: Diesel RV Sent: Monday, October 27, 2008 3:53:12 PM Subject: [WanderlodgeForum] 3208 Cat engine I own aBB motorhome with a 3208 Cat Turbo.
10-28-2008, 01:57
3208 Cat engine
Cat has recommended 15-40 for years. texaco ursa, delo 400 or shell rotella T are fine for this older engine
RE -------------- Original message from "agitator19" |
