Holding Tank capacities
01-12-2009, 16:52
Hi all,
looking to find out the gray and black water tank capacities on our 74/FC-31. I have found information on FC-77 and 78, but those were all 35 footers. Since we carry 60 gallons of water I'm thinking 40 gallons gray and 30 gallons black. any thoughts on it? thanks as always. Jim Benson 74-FC-31 Mai Tai Fine |
01-12-2009, 18:13
if you have a dump place at home you can use the city meter to calc the
at full capacity. 10 cu feet used =74.81 gallons. each cubic foot is 7.481 gallons. or 1 gallon is .1338 of a cubic foot. the water meter is way accurate and usuly have a drip triangl on the dial to show minor flow passing the meter, helpful to detect a minor leak Gregory 'ofTim&Greg 94ptCa --- In WanderlodgeForum@yahoogroups.com, "Jim Benson" wrote: > > Hi all, > looking to find out the gray and black water tank capacities on our > 74/FC-31. I have found information on FC-77 and 78, but those were all > 35 footers. Since we carry 60 gallons of water I'm thinking 40 gallons > gray and 30 gallons black. > any thoughts on it? > > thanks as always. > > > Jim Benson > 74-FC-31 > Mai Tai Fine > |
01-14-2009, 13:56
If you want to calculate the volume of your gray and black tank one
way to do it is: Bring a hose into your shower. It is nice to have a shut off valve at the end of the hose. Let the water flow. A modest stream is best. Leave your gray tank open to drain. Time exactly the time it takes to fill a five gallon bucket. Be exact. You can now calculate the flow rate in gallons per minute or seconds. (Dump the five gallon bucket in the shower.) Do not shut off the water on the hose or change the flow rate. Now close your gray tank valve. Note the time. Go back to the shower room. As soon as you see the water in the shower floor start to back up, note the time and shut off the water. You now know the flow rate out of the hose in gallons per minute and the number of minutes it took to fill your gray tank. Multiply these two numbers and you will get the volume of your gray tank. You can do the same calculations with your black tank but it's hard to do it without getting some water on the floor of your bathroom. I used two five gallon buckets. One to start the flow of water, once steady I moved the hose to the second bucket that I timed how long it took to fill the five gallon bucket. Then switched back to the first bucket. You then time how long it takes to fill the black tank, multiply the result by the flow rate and you have the volume of your black tank. |
01-14-2009, 14:11
Jim Benson
From some of the looking around I have had time to do,it seems your guess is about correct.
40 gray & 30 black
Fred & Jeanne Hulse
