Holding tanks frozen. Now what?
01-11-2009, 12:44
I live in it part of the time. If you're familiar with the term "man
cave", it's easy to understand. ![]() -Ryan '86 PT-40 8V92 On 1/4/09, Leroy Eckert > > Ryan, are you living in the coach this winter? Or is it parked in the yard? > My coach has tank heaters which I never turn on because I have had a bad experience > with heat strips. It gets very cold here in the mountains so I simply empty the tanks > during the winter. I still get quiet time in the coach while parked in the driveway. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > |
01-11-2009, 13:01
Hey Ryan, I live in my PT40 part of each week too when I'm in Billings. Coldest temps so far (Dec) this winter was 34 below. I have an air hook up to clear my water system in about 2 minutes. I use my on board water tank for water source & unhook the hose after each fill. Rock salt in the holding tanks too. Last year, I pulled all of the copper pipe & old heat tapes out & replaced with PEX. So far, no freeze ups this winter. I have one of the constant hot water circulating pumps that I may add to the water system if I get tired of draining the water system each week. It does work thanks to the PEX & the fact that I do drain the system at about -15 or colder. Terry Neal 82PT40 6V92TA 73FC31 6V53T Bozeman, Montana Ryan Wright wrote:
