Musical horn module
02-17-2009, 05:15
Musical horn module
It might not be the fuse or the module. Check the speakers on the roof. They're out in the weather and take a terrible environmental beating. The P.O. of my coach replaced the speakers (with a pair from Radio Shack) -- he said the horn wasn't working when he got the coach.
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Feb 17, 2009, at 6:37 AM, Ron Thompson wrote:
02-17-2009, 05:31
Musical horn module
The front load center is covered by a _fiberglas_ panel and held in place with a couple dozen screws. Danger -- the "screws" are not screws, but are 1/4 turn spring loaded connecters. Turning them with a power screw driver can/will break them, causing a headache to replace same. (Please don't ask how I happen to know this.) To unlock the fasteners, push in and turn counter clockwise, then release. It should pop out about 1/3 inch, but will not fall out (unless the fastener is partially broken).
When you remove the cover, be sure to take care in handling it -- it's not that heavy, but it is awkward to work with. A breezy day is not a good day to fuss with it. Dropping it can chip the paint on the edge. Check the quality of the insulating rubber strip around the perimeter. It's intended to eliminate/reduce water entry during rainy travel. I found it necessary to remove the old and apply a fresh strip obtained from a hardware store.
I made a list of all the fuses and relays in the front load center that I could identify (from the wiring diagrams I have) that you can download from -- file is second from the bottom titled "LOAD_CENTER-FRT_95WL42.pdf" A '95 'bird also has a load center in the rear closet, street side. There is also a "stealth" load center _behind_ the overhead cabinets at the front of the coach above the windshield (inside). The interior backs of the cabinets are removable -- and there are a bunch of fuses, etc. My spouse had managed to blow the fuse for the power passenger seat by twiddling several of the power controls at the same time. I spent weeks trying to trace the power source and only discovered it when I replaced my 'flying saucer' TV antenna and had to poke behind the cabinets for some of the wires -- and (lo, and behold) there was a whole 'nother power center with the blown fuse serving the passenger seat... Sorry, I have never been able to make similar lists of fuses/relays for the overhead or rear power center -- but I've found that 95% of the fuse/electrical issues end up in the front center. =============================================== Pete Masterson, Author of Book Design and Production: A Guide for Authors and Publishers "Aeonix1@Mac.com" Aeonix Publishing Group http://www.aeonix.com =============================================== On Feb 17, 2009, at 7:05 AM, Ron Thompson wrote:
02-17-2009, 08:19
Musical horn module
02-17-2009, 08:21
Musical horn module
02-18-2009, 03:33
Musical horn module
I believe Kurt Horvath has copied all his prints on a CD and has it available for sale.
He has a 95 and would be more like your needs.
Fred & Jeanne Hulse
02-18-2009, 06:21
Musical horn module
02-18-2009, 17:15
Musical horn module
In order to check the roof top speakers out: Disconnect (cut) the
speaker wire on the roof and put a 1.5 volt, D or C cell across the wires. You should hear a crackle. If you do not, it's time for a new speaker. Incidentally, I purchased my two speakers from PMMI. They gave me a great price and they happened to be color coordinated with my roof as an added bonus. Also, it is great fun to have your horn programmed with tunes that suit you. Several years ago it cost $125. I had fun selecting the tunes and the cows seem to enjoy the tunes I play for them. It's a nice diversion. Eric Perplies 96 42 WBWL currently in Fredericksburg, TX |
02-22-2009, 03:08
Musical horn module
