Refurbishing the Interior on Old Bird
02-21-2009, 16:36
It seems the former owner of our 1973 Bird papered the wall area behind
the dinette, and the wall next to the sink. We have the paper off, but there is some type of thin white paint on the wall. What can we use to remove this that will not affect the "Natural Wood" factory finish? Paint Thinner, Alchol, Acatone, or Laquer thinner come too mind... What to use that will not dissolve the factory finish?? Sanding will work, but it is very slow, and there is the danger that it will gouge the finish. Has anyone covered these areas with anything that looks good, and if so, what? Jack Smith 1973FC31 SoCal |
02-21-2009, 16:50
may be it is wallpaper adhesive and commercial wall paper remover may
work???? when I paint or paper over a stain or gloss, some times it is necessary to use a good sealer/primer or roll on a thin mix of elmers glue. it could be that they primed it?????? Greg of Tim&Greg 94ptCa --- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith" > > It seems the former owner of our 1973 Bird papered the wall area behind > the dinette, and the wall next to the sink. We have the paper off, but > there is some type of thin white paint on the wall. What can we use to > remove this that will not affect the "Natural Wood" factory finish? > Paint Thinner, Alchol, Acatone, or Laquer thinner come too mind... > What to use that will not dissolve the factory finish?? > Sanding will work, but it is very slow, and there is the danger that it > will gouge the finish. > Has anyone covered these areas with anything that looks good, and if > so, what? > Jack Smith > 1973FC31 > SoCal > |
02-21-2009, 17:52
--- In WanderlodgeForum@yahoogroups.com, "timvasqz"
> > may be it is wallpaper adhesive and commercial wall paper remover may > work???? when I paint or paper over a stain or gloss, some times it > is necessary to use a good sealer/primer or roll on a thin mix of > elmers glue. it could be that they primed it?????? > Greg of Tim&Greg > 94ptCa > > > --- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith" > > > > > It seems the former owner of our 1973 Bird papered the wall area > behind > > the dinette, and the wall next to the sink. We have the paper off, > but > > there is some type of thin white paint on the wall. What can we > use to > > remove this that will not affect the "Natural Wood" factory > finish? > > Paint Thinner, Alchol, Acatone, or Laquer thinner come too mind... > > What to use that will not dissolve the factory finish?? > > Sanding will work, but it is very slow, and there is the danger > that it > > will gouge the finish. > > Has anyone covered these areas with anything that looks good, and > if > > so, what? > > Jack Smith > > 1973FC31 > > SoCal > > Dick do you have a spot where you could test a product to see if would help remove that white paint? A friend of mine used some ovencleaner but sparingly and with lots of fresh air in the general area. Like I said you could just test an area that would not show and this might be the trick. Be sure to wear gloves and have a fan on. Jon > |
02-21-2009, 17:54
--- In WanderlodgeForum@yahoogroups.com, "Jon"
> > --- In WanderlodgeForum@yahoogroups.com, "timvasqz" > > > > may be it is wallpaper adhesive and commercial wall paper remover > may > > work???? when I paint or paper over a stain or gloss, some times it > > is necessary to use a good sealer/primer or roll on a thin mix of > > elmers glue. it could be that they primed it?????? > > Greg of Tim&Greg > > 94ptCa > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith" > > > > > > > > It seems the former owner of our 1973 Bird papered the wall area > > behind > > > the dinette, and the wall next to the sink. We have the paper > off, > > but > > > there is some type of thin white paint on the wall. What can we > > use to > > > remove this that will not affect the "Natural Wood" factory > > finish? > > > Paint Thinner, Alchol, Acatone, or Laquer thinner come too mind... > > > What to use that will not dissolve the factory finish?? > > > Sanding will work, but it is very slow, and there is the danger > > that it > > > will gouge the finish. > > > Has anyone covered these areas with anything that looks good, and > > if > > > so, what? > > > Jack Smith > > > 1973FC31 > > > SoCal > > > > > > Dick do you have a spot where you could test a product to see if > would help remove that white paint? A friend of mine used some > ovencleaner but sparingly and with lots of fresh air in the general > area. Like I said you could just test an area that would not show > and this might be the trick. Be sure to wear gloves and have a fan > on. Jon > > Oh yes maybe a set of clear plastic safety gogles? \\ Jon Rebel Bird > |
02-21-2009, 18:09
> > --- In WanderlodgeForum@yahoogroups.com, "Jon" > > > > --- In WanderlodgeForum@yahoogroups.com, "timvasqz" > > > > > > may be it is wallpaper adhesive and commercial wall paper remover > > may > > > work???? when I paint or paper over a stain or gloss, some times > it > > > is necessary to use a good sealer/primer or roll on a thin mix > of > > > elmers glue. it could be that they primed it?????? > > > Greg of Tim&Greg > > > 94ptCa > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith" > > > > > > > > > > > It seems the former owner of our 1973 Bird papered the wall > area > > > behind > > > > the dinette, and the wall next to the sink. We have the paper > > off, > > > but > > > > there is some type of thin white paint on the wall. What can > we > > > use to > > > > remove this that will not affect the "Natural Wood" factory > > > finish? > > > > Paint Thinner, Alchol, Acatone, or Laquer thinner come too > mind... > > > > What to use that will not dissolve the factory finish?? > > > > Sanding will work, but it is very slow, and there is the danger > > > that it > > > > will gouge the finish. > > > > Has anyone covered these areas with anything that looks good, > and > > > if > > > > so, what? > > > > Jack Smith > > > > 1973FC31 > > > > SoCal > > > > > > > > > > Dick do you have a spot where you could test a product to see > if > > would help remove that white paint? A friend of mine used some > > ovencleaner but sparingly and with lots of fresh air in the general > > area. Like I said you could just test an area that would not show > > and this might be the trick. Be sure to wear gloves and have a fan > > on. Jon > > > > > Oh yes maybe a set of clear plastic safety gogles? \\ > Jon > Rebel Bird I just goggled "Removal of glue from wall papered walls? Here is the answer:http://www.google.com/search? source=ig&hl=en&rlz=&q=What+can+I+use+to+remove+wall+paper+glue% 3F&btnG=Google+Search&aq=f > > > |
02-22-2009, 01:29
02-23-2009, 08:47
Jack, MaybeGoo Gonewill work. I use the spray bottle to remove the sticky glue left after I remove a label from a plastic/glass bottle that I want to store something else in. I think the thick gel works better, but you get more coverage from the spray gel, as it is thinner. Good Luck, George Burke 1977 FC31 Charlotte
On Sun, Feb 22, 2009 at 8:29 AM, Ernie Ekberg <"ernietex@yahoo.com"> wrote:
