"TO tow or not to tow, that is the question"
05-20-2009, 06:30
Post: #41
I'm not sure but I believe that the older Jepps need to have the optional Qaudra "something" option on the 4 wheel drive to have it 4 down.
Scooter 2000LX To: WanderlodgeForum@yahoogroups.com From: nytexcel@... Date: Wed, 20 May 2009 03:46:19 +0000 Subject: [WanderlodgeForum] Re: "TO tow or not to tow, that is the question" wow, I really had no idea it was so complicated to tow a car. I just knew I wanted to be able to back up. In about 1980 I had a '76 Ranchero that the shifter broke on. I was too broke (or lazy) to fix it, and so I just left in drive for about six months or so. I would start it with my foot on the brake and drive it, making sure I didn't pull into anywhere I'd have to back out of. I remember how I could sometimes pull into some parking spots, and then when I wanted to leave I would start it, lunge forward while turning off the engine, and it would bounce off the parking block and roll back enough (while turning a little) to then re-start it and pull away. I was unemployed at the time. I now wonder if that caused deep-scarring traumatic issues that are affecting my desire to keep my back up otions? \/\/\â¦Fred ____________ Fred & Wendy Bellows Queen Creek, AZ (so.east Phx) '90 SP36 "Maunder Maximum" photos of coach and upgrades current location |
05-20-2009, 08:49
Post: #42
Tommy,
Thanks for the good info. I'll look at Craiglist and eBay and see wazzup! Rich --- In WanderlodgeForum@yahoogroups.com, "tommy.rountree" > > > > Tommy, > > > > > > Thanks for the info. Why do you have to stop and crank it up,etc., every > > > 6-8 hours? > > > > > > Rich > > > Rich: I believe someone has answered, but according to my 2001 CRV Owner's Manual, it must be done to circulate the fluids in the tranny. > > Not much of a inconvenience - we usually stop every 200 miles or so anyway to losen up "old bones". I check tires, my Allison tranny fluid and let the dog pee. Just get in the little bugger crank it up let it run for 2-3 minutes, then go through the shifting sequence: P,R,N,D,2,1 then back to D, then to N, shut the engine down and turn the ignition key to ACC and drive away. > > Local paper last sunday listed a bunch of Honda CRVs 1999-2003, most under $5,000.00. > > Tommy > |
