Help with 3 roof airs not working
06-12-2005, 09:34
Hello,
I would appreciate some help with my roof air units. None of the units
will turn on. No fans or signs of any life. I checked the output
voltage at the three AC circuit breakers and they are outputing 115
VAC. I checked the input voltage at the center roof AC unit and it has
no AC input. I purchase a complete set of drawings from BB but there is
no AC wiring diagram of any kind.
Thank you,
Andy
88 WB40 Silver edition
06-12-2005, 09:39
there are 3 switchs in the drivers area that control the power to the ac
units,somewhere to the left of the driver,maybe on the bottom of the upper
cabinets. have you checked those?randydupree93wb
Sent: Sunday, June 12, 2005 5:34 PM
Subject: [WanderlodgeForum] Help with 3 roof airs not working
Hello,
Thank you,
Andy
Yahoo! Groups Links
06-12-2005, 14:35
The A/Cs need the three switches turned on as Randy mentioned, and
the units should be controlled by the wall thermostats (individually).
- Jeff Miller
--- In WanderlodgeForum@yahoogroups.com, randydupree
the ac units,somewhere to the left of the driver,maybe on the bottom
of the upper cabinets. have you checked those?randydupree93wb
> From: awojteczko
> Hello,
units
115
it has
there is
> Thank you,
> Andy
> Yahoo! Groups Links
Service.
