Continuing Electrical Problems
08-24-2009, 15:29
Well, I have good news and bad news. The good news is I found the problem. We
went for a drive this weekend with the continuing pulsing in the voltage. Then
my girlfriend smelled smoke. A wisp of smoke came up behind the dash. I shut
down the battery and it stopped but not before something fried back there. The
good news? The short apparently burned up what ever was causing the pulsing -
now the Alternator is putting out a consistent 13.6 with no pulsing. The next
trick will be opening up the front and digging in to see what gave up the ghost.
Thank you one and all for all of the suggestions for finding the problem,
Steve
1982 33' FC
Anchorage, AK
--- In WanderlodgeForum@yahoogroups.com, GARY MINKER wrote:
> Everyone learned gets an opinion and I buy in to everything here EXCCEPT the
shorted starter garbage. Starters are dead unless cranking. The block flows
current constantly from the alternator and raw galvanics.
> Nope to the electrical bit
> Gary
> --- On Wed, 8/19/09, Gregory OConnor wrote:
> From: Gregory OConnor
> Subject: [WanderlodgeForum] Re: Continuing Electrical Problems
> Date: Wednesday, August 19, 2009, 11:33 AM
> Â
> Long post with a cut and paste that may shed light on some
issues owners often fail to look at when a minor problem compound the damage. I
am not saying degraded radiator fluid can cause electrical problems, just
saying both 'electrical issues' with 'off-balance radiator fluid' (fluid with
ability to pass current) can leave the bus vulnerable to major engine damage.
After an engine failure I always look for the clues that proceeded the event
like; previous work, ;noises, ;performance, ;temps and conditions in the hopes
to avoid future and explain current damage.
> Reading the article and listening to RonM's clues might shed light on his
Canadian sleeve failure????? ??
> The Basics of Diesel-Engine Coolant
> September 1, 2005
> By Walt Moore, Senior Editor
> Elizabeth Nelson, coolant program manager at Polaris Laboratories, a
fluid-analysis company in Indianapolis, Ind., tells a story that would strike
fear into the heart of any fleet manager. A class-8 on-highway truck seemed in
fine condition when it left the West Coast, but at the end of its 6,000-mile
cross-country run, a cylinder sleeve failed and catastrophic engine failure
resulted. According to Nelson, the cause of the disaster was an electrical short
in the truck's starter.
> "An electrical short in a vehicle takes the path of least resistance to
ground," says Nelson, "and often that's through the cooling system. In this
instance, the electrical current passing through the coolant so quickly depleted
the nitrite additive in the antifreeze, that the sleeves no longer had
protection against cavitation. When coolant analysis shows a rapid depletion of
nitrite, coupled with an increase in nitrates, it's always a red flag for an
electrical short."
> A combustion-gas leak, on the other hand, says Nelson, causes a sharp drop in
pH (usually below 7) and an increase in sulfates. Air leaking into the cooling
system, however, typically results in a lowered pH, she says, (but usually not
below 7.5) and a drop in nitrite level (but not as rapid as with an electrical
problem).
> What's in the radiator?
> Although regular coolant analysis is a good way to keep tabs on the health of
a vehicle's coolant system, coolant analysis is not nearly as popular as oil
analysis. For many equipment owners, truth be told, what goes on in their
machine's cooling system is somewhat of a mystery.
> "Ask most fleet managers about their lube-maintenance programs, and they'll
talk in detail," says Craig Gullett, brand marketing manager for Old World
Industries, a major antifreeze manufacturer. "Ask about their
coolant-maintenance programs, however, and more often than not, answers become
rather uncertain."
> A frequent weak link in coolant maintenance, and the probable cause of many
coolant-related engine problems, says Carmen Ulabarro, coolants market
development specialist for ChevronTexaco, is the lack of understanding about
what coolant is being used in the vehicle â€" and how to maintain that specific
formulation.
> Virtually all heavy-duty antifreeze is roughly 95 percent ethylene glycol and
5 percent water and additives. The stuff that isn't made from ethylene glycol
(only about 1 percent of all antifreeze sold) is made from propylene glycol,
which is less toxic, but also more expensive. "Coolant" is created when glycol
is mixed with various ratios of water. Typical ratios range from 30 to 60
percent glycol.
> Heavy-duty antifreeze formulations differ from one another by virtue of the
additive package blended into the ethylene glycol. Additive packages, of course,
all have the same task, namely to fight rust, scale and corrosion â€" and in
diesel engines, to protect wet cylinder sleeves from cavitation. But the
additive packages among various antifreeze formulations have fundamentally
different chemical fingerprints.
> Until maybe 15 years ago, heavy-duty engines typically were filled with
"conventional" antifreeze, identified by the American Society for Testing and
Materials (ASTM) standard D-4985. This antifreeze, however, which is still in
prevalent use today, can't be used in diesel engines without first treating it
with a "supplemental coolant additive" (SCA) that contains nitrite for
protecting wet sleeves. The required initial treatment is an approximate
3-percent concentration of SCA (one pint per four gallons of cooling-system
capacity).
> Today, the preferred conventional antifreeze for diesel engines is "fully
formulated," identified as ASTM D-6210 or RP-329 by the Technology & Maintenance
Council (TMC). This antifreeze is sold with an SCA package already blended in,
typically including nitrate to protect iron and steel, tolyltriazole to protect
copper and brass, borate or phosphate to buffer acids (formed as glycol breaks
down), silicate to protect aluminum and nitrite (sometimes accompanied by
molybdate) to form a cavitation-resistan t barrier on sleeves.
> These additives are depleted as the coolant works and ages, however, and must
be replenished periodically with an SCA package. Especially critical is the
renewal of an adequate nitrite level. But you must be careful here, because too
much nitrite may cause solder corrosion, and excess accumulation of other
additives causes "total dissolved solids" (TDS) to increase, possibly
jeopardizing cooling efficiency and resulting in passage-clogging dropout.
Cautious maintenance guidelines may suggest replacing fully formulated
conventional coolant at two-year intervals to avoid TDS problems.
> To simplify maintenance, the antifreeze industry developed "extended-life
coolants" (ELC), which are formulations typically advertised with a service life
of 600,000 miles or 12,000 hours. These formulations, originally at least,
replaced the additive package used in fully formulated conventional antifreeze
with "organic-acid inhibitors," designed to protect metal parts by forming a
thin protective skin against destructive forces in the coolant.
> These "organic-acid- technology" (or OAT) antifreezes use the base or
neutralized version of organic (carbon-containing) acids, typically (but not
always) the carboxylate acids of 2-ethyl hexanoic acid (2-EH) and/or sebacic
acid. Most heavy-duty carboxylate formulations, however, also contain some of
the additives used in fully formulated conventional antifreeze, namely nitrite
and molybdate, and sometimes silicate. OAT formulations that include nitrite
sometimes are called nitrited-organic- acid-technology antifreeze, or simply a
NOAT.
> According to some antifreeze experts, anytime you add inorganic inhibitors
(like nitrite) to an organic-acid- based formulation, you have created a hybrid,
or a Hybrid OAT, or a HOAT. Others say, though, that a hybrid is technically a
product characterized by the use of non-carboxylate acids, such as benzoate,
from benzoic acid, another organic acid.
> Maintenance
> To ChevronTexaco' s Ulabarro's point, the start of good coolant maintenance
begins with knowing which antifreeze formulation is in your machine's radiator.
> Most NOAT formulations, for example, require the addition of an "extender" at
300,000 miles or 6,000 hours to replenish nitrite, which is used up at a far
slower rate in an extended-life coolant than in a fully formulated conventional.
Important to note here, perhaps, is that European engine manufacturers are
evaluating â€" maybe even leaning toward â€" the use of carboxylate- based
extended-life coolants without nitrite.
> Don't buy into the philosophy, however, that extended-life coolant needs no
regular maintenance. The experts recommend inspecting it at the vehicle's
regular maintenance intervals to make sure it's clear (no rust), that the color
is right (not mixed with another antifreeze type) and that it has sufficient
freeze/boil protection, best determined by using a refractometer.
> Maintenance guidelines for cooling systems with fully formulated conventional
antifreeze typically include periodic testing of SCA levels and appropriate
adjustment, as well as periodic draining, flushing and refilling the system to
avoid, as already noted, an excess of dissolved solids.
> You can test the additive concentration of fully formulated conventional
coolant by supplying samples to a fluids-analysis laboratory. Or, you can do the
testing yourself by using paper test strips, which are chemically sensitive and
change color to indicate freeze/boil point (glycol content), nitrite (or
nitrite/molybdate) levels and, in some instances, pH.
> When the addition of an SCA is indicated, keep in mind that two major types of
SCA are available, one with a nitrite/borate formulation, the other with a
nitrite/molybdate/ phosphate formulation. It's probably best not to mix them,
and it's best to use a test strip designed for the specific formulation. Those
in the know say to be careful about buying bargain-priced SCA formulations,
which may be inferior. Look for a stated compliance with an ASTM standard on the
package, likely D-5752, to ensure that you're buying a quality product.
> Some users of fully formulated conventional antifreeze, however, employ a
coolant filter charged with an SCA package. This filter/additive assembly is
designed to release metered amounts of additives over time and, thus, to
maintain optimum levels. As long as testing indicates proper additive levels,
and provided that top-up is done with a 50/50 mix of the correct antifreeze and
deionized water, the assumption is that fully formulated conventional coolant
can last far longer than the often-prescribed interval of two years.
> On the other hand, says ChevronTexaco' s Ulabarro, some users of fully
formulated conventional antifreeze drain and replace coolant every year, but do
not test or add SCA packages between those service intervals, thinking that
nothing will go wrong in that short time. But, depending on the specific
formulation of the antifreeze and on top-up practices, says Ulabarro, critical
additives could be depleted in as little as 1,000 hours, potentially leaving the
engine virtually unprotected for a long time.
> In the everyday world, of course, fully formulated conventional and
organic-acid antifreezes are sometimes inadvertently mixed in cooling systems.
The primary concern about a mixed system is that the distinctively different
additive packages in the two formulations will be diluted to the point that
neither has the power to afford adequate protection. You're best off, say the
experts, to pick an antifreeze type, take all practical safeguards to avoid
mixing it with other types, and conscientiously follow the maintenance strategy
recommended for the chosen antifreeze.
> Coolant Analysis
> Given the changing chemistry of coolants and the increased demand placed on
cooling systems by today's engines, Bryan Debshaw, CEO of Polaris Laboratories,
believes that coolant analysis will become an increasingly important tool in
preventive-maintena nce programs. Coolant analysis not only determines coolant
condition, he says, but also identifies other vehicle problems that can show up
in the cooling system. Coolant-analysis programs typically are available in
various levels (and costs), depending on the number of parameters checked.
> A primary cause of wet-sleeve damage is cavitation, but other causes are
prevalent: these sleeves have been attacked by 1) stray electrical current going
to ground through the coolant; 2) calcium and magnesium scale that impedes heat
transfer and is caused by water with minerals (the sleeve "blues" at 600F); and
3) chloride (in the water), which "decarbonizes" iron until it is like sand,
says Elizabeth Nelson of Polaris Laboratories
> Quick Tip
> Using tap water in your vehicle's cooling system can undermine your best
efforts at good maintenance if it creates rust, scale and corrosion. Premixed
coolant, with 50 percent demineralized water, avoids these problems. So does
deionized water. Talk to your local water-conditioner expert about a
deionization unit. We found a local supplier who would install a "mixed bed"
unit for around $200, then switch tanks as needed for $80 or $90. Typical tank
life is 1,500 to 2,500 gallons of treated water.
> If you use paper test strips to check the condition of fully formulated
conventional antifreeze, make sure the strips are fresh and designed for the
type of coolant being tested. Remember that freeze-point readings may be
unreliable if glycol levels are above 60 percent.
> Wet-Sleeve Cavitation
> In a wet-sleeve cooling system, antifreeze additives create a barrier between
the engine's sleeves and the small bubbles that form in the coolant next to the
sleeves, the result of pressure differentials. When the normal vibration of the
sleeves causes the bubbles to implode, they do so with great violence and can
create tiny cavities in the surface of unprotected sleeves. Left unchecked, this
"cavitation" process (a leading cause of engine failure) can create holes in the
sleeves and allow coolant to leak into the cylinder. Fully formulated
conventional antifreeze uses nitrite, which coats the sleeves, to protect
against cavitation. Organic-acid- technology antifreeze uses chemicals that
plate sleeves with a thin protective layer, but these formulations also may
contain nitrite.
> Illustration adapted from Baldwin Filter graphic.
> Conversion Possibilities
> Manufacturers of at least three brands of organic-acid- technology antifreeze
have programs for converting cooling systems from fully formulated conventional
coolant to an organic-acid- type coolant, without draining and refilling the
system. Reduced maintenance is cited as the primary benefit of conversion.
> ChevronTexaco' s Fleet Fix Conversion, Shell's Extended-Life Coolant
Conversion, and Old World Industries' Final Charge Converter can be used to make
the conversion, but the existing coolant must meet specific parameters before
conversion can proceed. (Old World Industries' Final Charge antifreeze is a
non-carboxylate organic-acid- based product that contains no nitrite.)
> By contrast, Penray, a maker of antifreeze additives, promotes a
"Fill-for-Life" strategy, which is aimed at converting nitrited-organic-
acid-technology coolants to fully formulated conventional coolant. Penray's
conversion strategy employs its Need-Release Filter, which uses
corrosion-sensitive barriers for the timed release of SCA charges.
> Electrical Grounds and Aeration
> Maintaining electrical grounds is an essential aspect of cooling-system
maintenance, because stray electrical currents can cause problems in cooling
systems. Regularly check ground connections for the batteries and starter, and
be careful to properly ground any add-on accessories.
> On the other hand, aeration in a cooling system can cause problems that are
sometimes blamed on stray currents. Periodically inspect the cooling system for
air leaks from loose clamps, bad hoses and bad pressure cap.--- In
WanderlodgeForum@ yahoogroups. com, "Gregory OConnor" wrote:
> > It is important to keep a check on your radiator fluid condition when there
is electrical problems. more so in a wet sleeve like a 8v92. as far as the
problem goes one idea is to disable a block of fuses at a time and find the
block that doesnt show the pulse. One other thing to do is see if it does this
while the engine is not on but key is on. then a bunch of conditions to clue the
fault
> > Greg 94ptca
> > --- In WanderlodgeForum@ yahoogroups. com, "Steve Hinds"
> > > I have been having electrical problems for a bit over a year now. New
batteries and a trip to Trailercraft to track things down didn't fix the
problem. I found out that the converter/charger was not producing enough
voltage (10.6) and replaced it with a new smart charter. I also bought a
voltage meter which shows current voltage being produced. While driving, the
voltage has been surging from around 12.5 to 13.9 volts, cycling between the
two. As this happens, the tachometer drops, lights pulse. Typical cycle is 5
to 7 seconds. Any ideas for chasing down the problem will be appreciated.
> > > Steve Hinds
> > > '82 FC
08-24-2009, 16:53
windshield wiper motor?
Greg of Tim&Greg
94ptCa--- In WanderlodgeForum@yahoogroups.com, "twin_beech"
We went for a drive this weekend with the continuing pulsing in the voltage.
Then my girlfriend smelled smoke. A wisp of smoke came up behind the dash. I
shut down the battery and it stopped but not before something fried back there.
The good news? The short apparently burned up what ever was causing the pulsing
- now the Alternator is putting out a consistent 13.6 with no pulsing. The next
> Steve
> 1982 33' FC
> Anchorage, AK
> > Gary
> > Â
> > September 1, 2005
electrical short."
in pH (usually below 7) and an increase in sulfates. Air leaking into the
cooling system, however, typically results in a lowered pH, she says, (but
usually not below 7.5) and a drop in nitrite level (but not as rapid as with an
electrical problem).
of a vehicle's coolant system, coolant analysis is not nearly as popular as oil
rather uncertain."
formulation.
and 5 percent water and additives. The stuff that isn't made from ethylene
glycol (only about 1 percent of all antifreeze sold) is made from propylene
glycol, which is less toxic, but also more expensive. "Coolant" is created when
glycol is mixed with various ratios of water. Typical ratios range from 30 to 60
percent glycol.
capacity).
must be replenished periodically with an SCA package. Especially critical is the
NOAT.
> > Maintenance
at 300,000 miles or 6,000 hours to replenish nitrite, which is used up at a far
conventional antifreeze typically include periodic testing of SCA levels and
appropriate adjustment, as well as periodic draining, flushing and refilling the
system to avoid, as already noted, an excess of dissolved solids.
of SCA are available, one with a nitrite/borate formulation, the other with a
> > Coolant Analysis
> > Quick Tip
between the engine's sleeves and the small bubbles that form in the coolant next
to the sleeves, the result of pressure differentials. When the normal vibration
of the sleeves causes the bubbles to implode, they do so with great violence and
can create tiny cavities in the surface of unprotected sleeves. Left unchecked,
this "cavitation" process (a leading cause of engine failure) can create holes
in the sleeves and allow coolant to leak into the cylinder. Fully formulated
contain nitrite.
antifreeze have programs for converting cooling systems from fully formulated
conventional coolant to an organic-acid- type coolant, without draining and
refilling the system. Reduced maintenance is cited as the primary benefit of
conversion.
there is electrical problems. more so in a wet sleeve like a 8v92. as far as
the problem goes one idea is to disable a block of fuses at a time and find the
fault
> > > Greg 94ptca
> > > > Steve Hinds
> > > > '82 FC
