Location of air tank.
06-14-2005, 02:35
Can someone tell me where the air storage tank is located in a 1994
WB? I was told I should drain every year.
Thanks
Nelson SLinkman 1994wb
06-14-2005, 14:26
--- In WanderlodgeForum@yahoogroups.com, "nslinkman"
> Thanks
Nelson: Under your coach, get directly beneath the air dryer and
look up. You will see two tanks that have manual valves on them and you
can reach up and drain them. Then crawl forward towards the front of
the coach about 4 feet and look up next to where the fuel tank starts,
you will see another air tank that runs cross ways. You will be unable
to reach this tank but there should be a copper line running from the
drain on the tank to a valve that you can reach, just follow the line
from the bottom of the tank. Bpb 93pt--Illinois
06-15-2005, 01:19
Thanks Bob for the information. Could you also tell me
where the air dryer is located. I have never been
underneath the coach.
> located in a 1994
> > Thanks
> the air dryer and
> fuel tank starts,
> You will be unable
> running from the
__________________________________
Discover Yahoo!
Find restaurants, movies, travel and more fun for the weekend. Check it out!
http://discover.yahoo.com/weekend.html
06-15-2005, 03:17
Nelson: The air dryer is located directly infront of the drive axle
gear section . If you still can't find it, start the coach and set the
brake's crawl under it and wait for the dryer to discharge, there will
be do doubt where it's located when this happen's. (just kidding)..Bob
93pt illinois
