WHY,WHY,WHY,WHY
06-16-2005, 13:58
WHY,WHY,WHY,WHY
CAN'T SOME LEARN TO POST INSTEAD OF "REPY"!!!
IT IS AGONIZING TO READ/SORT THRU REPLIES 10 TO 20 TIMES EVERY DAY! CALL IT WHAT YOU WILL,COURTESY,COMMOM SENSE,???? I'M GLAD TO HELP ANYWAY I CAN,BUT IT'S "GIVE+TAKE" THING FOR IT TO HAPPEN! STEVE ODLE, BUYING AN 82FC33 |
06-16-2005, 14:21
WHY,WHY,WHY,WHY
Please use lower case. Upper case is considered shouting.
Thanks. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "Howard Roark" <sbodle@m...> wrote: > CAN'T SOME LEARN TO POST INSTEAD OF "REPY"!!! > IT IS AGONIZING TO READ/SORT THRU REPLIES 10 TO 20 TIMES > EVERY DAY! > CALL IT WHAT YOU WILL,COURTESY,COMMOM SENSE,???? > I'M GLAD TO HELP ANYWAY I CAN,BUT IT'S "GIVE+TAKE" > THING FOR IT TO HAPPEN! > STEVE ODLE, BUYING AN 82FC33 |
06-16-2005, 15:15
WHY,WHY,WHY,WHY
Mr. Odle,
Thanks so much for your FIRST post EVER to this forum. Not only was your knowledge of posting received well but was also extremely beneficial to the enlightenment of this reader. I certainly understand now without doubt your intent. Please BARK up another tree as it is apparent that you have nothing to GIVE others as well. Bob Janes, Greenville (exclamation points, caps, question marks, and extra periods omitted by intent) --- In WanderlodgeForum@yahoogroups.com, "Howard Roark" <sbodle@m...> wrote: > CAN'T SOME LEARN TO POST INSTEAD OF "REPY"!!! > IT IS AGONIZING TO READ/SORT THRU REPLIES 10 TO 20 TIMES > EVERY DAY! > CALL IT WHAT YOU WILL,COURTESY,COMMOM SENSE,???? > I'M GLAD TO HELP ANYWAY I CAN,BUT IT'S "GIVE+TAKE" > THING FOR IT TO HAPPEN! > STEVE ODLE, BUYING AN 82FC33 |
06-17-2005, 00:30
WHY,WHY,WHY,WHY
I have no idea what you are trying to say or what you are recommending.
Reply is the correct method when the subject is the same, or in response to, the original post. Post is for new subjects. Cap locks is considered rude, by the way. Dan --- In WanderlodgeForum@yahoogroups.com, "Howard Roark" <sbodle@m...> wrote: > CAN'T SOME LEARN TO POST INSTEAD OF "REPY"!!! > IT IS AGONIZING TO READ/SORT THRU REPLIES 10 TO 20 TIMES > EVERY DAY! > CALL IT WHAT YOU WILL,COURTESY,COMMOM SENSE,???? > I'M GLAD TO HELP ANYWAY I CAN,BUT IT'S "GIVE+TAKE" > THING FOR IT TO HAPPEN! > STEVE ODLE, BUYING AN 82FC33 |
