Heater part
12-10-2009, 02:22
Post: #21
Heater part
Chuck: What was your temp. set at? Was it automatic or manual?
--- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" wrote:
> Besides the current draw of the heater you need to know the cutoff
> temperature. I was lucky, the switch used in our heaters was the same one
> used to protect most electric dryers so it was available and cheap ($6.50)
> locally at Appliance parts.
> - Chuck Wheeler-
> 1982 FC 31SB Fort Worth TX
> _____
> [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of David Ward
> Sent: Wednesday, December 09, 2009 8:33 PM
> Subject: Re: [WanderlodgeForum] Re: Heater part
> Ron,
> I would think that given the wattage of the heater somebody like Grainger or
> Johnstone Supply should be able to come up with a high limit switch for it.
> Dave Ward
> 80FC31SB
> Mesa, AZ
> --- On Thu, 12/10/09, ronmarabito2002 wrote:
> From: ronmarabito2002
> Subject: [WanderlodgeForum] Re: Heater part
> Date: Thursday, December 10, 2009, 2:26 AM
> They are not interested in selling anything for the old models. They only
> want to sell you a new heater unit complete. All I need is a less than $10
> part and I intend to find it somewhere.
> Thanks for your response.
> --- In WanderlodgeForum@ yahoogroups. com, "marvjeanm380"
> > Ron:
> > Cadet is located in Vancouver, WA. Their main part supplier is Reliable
> Parts. They have a location in the Portland, OR area that I have bought
> from. Their number is Sales: (503) 239-6050. Give them a call and they will
> either sell you a part or can provide you with a current model electric
> heater. I bought one for a project and it was suprisingly cheap.
> > Marv
> > 2004 M380
> > Ocean Shores, WA
> > --- In WanderlodgeForum@ yahoogroups. com, "ronmarabito2002" > > wrote:
> > > No temperature stamped on this one. Only markings are TOD-1-B1-B
> > > --- In WanderlodgeForum@ yahoogroups.. com, "Chuck Wheeler"
> > > > Ron, if you look closely you should see a temperature stamped in it.
> This
> > > > is the cutoff temperature that protects from overheating. They are
> > > > available locally here from Granger, although I get most of my parts
> from
> > > > Appliance parts Co in Richland hills.
> > > > - Chuck Wheeler-
> > > > _____
> > > > From: WanderlodgeForum@ yahoogroups. com
> > > > [mailto:WanderlodgeForum@ yahoogroups. com] On Behalf Of
> ronmarabito2002
> > > > Sent: Wednesday, December 09, 2009 11:21 AM
> > > > To: WanderlodgeForum@ yahoogroups. com
> > > > Yes Curt. How do we determine the correct size?
> > > > yahoogroups. com, Curt Sprenger wrote:
> > > > > Ron,
> > > > > Look like this?
> > > > > http://www.thermodi
> > > > <http://www.thermodi
> <http://www.thermodisc.com/productdetail.asp?ProductID=1> sc.com/productde
> tail.asp? ProductID= 1>
> > > > sc.com/productdetai l.asp?ProductID= 1
> > > > > the site has lots of them.
> > > > > Curt Sprenger
> > > > > 1987 PT38 8V92 "MacAttack Racing"
> > > > > Anaheim Hills, CA
> > > > > On Wed, Dec 9, 2009 at 9:07 AM, ronmarabito2002
> > > > > > Studying this closer, it is probably a heat sensor or
> thermocouple.
> > > > > > --- In WanderlodgeForum@ > ups.com>
> > > > yahoogroups. com,
> > > > > > "ronmarabito2002" wrote:
> > > > > > > Hi all: Does anyone have a source for the round disc resistor or
> > > > > > capacitor that mounts in the top of the Bathroom Electric Heater
> for a
> > > > > > 92WB40. Mine has disintegrated and can't get heat.
> > > > > > > It has TOD 1-B1-B stamped on it.
12-10-2009, 03:48
Post: #22
Heater part
If I understand correctly we are talking
about the safety cutoff switch. They are not adjustable. You select one with
the correct cutoff temperature.
- Chuck
Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of ronmarabito2002
Sent: Thursday, December 10, 2009
8:23 AM
Heater part
manual?
TX
92WB40
--- In "WanderlodgeForum%40yahoogroups.com",
> - Chuck Wheeler-
TX
> _____
> From: "WanderlodgeForum%40yahoogroups.com"
> [mailto:"WanderlodgeForum%40yahoogroups.com"]
> Ron,
or
it.
> Dave Ward
> 80FC31SB
> Mesa, AZ
> --- On Thu, 12/10/09, ronmarabito2002 ...> wrote:
> From: ronmarabito2002 ...>
TX
92WB40
> > Ron:
WA
Reliable
OR
will
> > Marv
> > 2004 M380
> > Ocean Shores, WA
"ronmarabito2002"
TX
92WB40
Wheeler"
stamped in it.
> This
They are
my parts
> from
hills.
> > > > - Chuck Wheeler-
> > > > 1982 FC 31SB Fort
Worth
TX
> > > > _____
Of
> ronmarabito2002
TX
92WB40
> > > > --- In WanderlodgeForum@ ups.com>
> > > > > Ron,
> > > > > Look like this?
> > > > > http://www.thermodi
sc.com/productde
> > > > > Curt Sprenger
> > > > > Anaheim Hills,
CA
sensor or
> thermocouple.
92WB40
> > > > > > --- In WanderlodgeForum@ Forum%40yahoogro
> ups.com>
> > > > yahoogroups. com ps.com>,
> > > > > > "ronmarabito2002"
Electric Heater
> for a
heat.
92WB40
12-10-2009, 12:33
Post: #23
Heater part
Ron, the book for my Primus says that they are 140 degree sensors, and will allow the toe kick fans to come on after the fluid gets to that temp.But in replacing one recently Bleakleyput in one rated at 110 degrees.
Rick Davis
1993 WBSA
Loudon, TN
Sent: Thu, December 10, 2009 10:48:57 AM
Subject: RE: [WanderlodgeForum] Re: Heater part
If I understand correctly we are talking about the safety cutoff switch. They are not adjustable. You select one with the correct cutoff temperature.
- Chuck Wheeler-
From: WanderlodgeForum@ yahoogroups. com [mailto: WanderlodgeForum@ yahoogroups. com ] On Behalf Of ronmarabito2002
Sent: Thursday, December 10, 2009 8:23 AM
R.E. (Ron) Marabito, Dallas , TX 92WB40
> - Chuck Wheeler-
> _____
> [mailto:"WanderlodgeForum%40yahoogroups.com"] On Behalf Of David Ward
> Ron,
> Dave Ward
> 80FC31SB
> Mesa , AZ
> > Ron:
> > Cadet is located in Vancouver , WA . Their main part supplier is Reliable
> Parts.
They have a location in the Portland , OR area that I have bought
> > Marv
> > 2004 M380
> > Ocean Shores , WA
> > > --- In WanderlodgeForum@ yahoogroups. . com, "Chuck Wheeler"
This
> from
> > > > - Chuck Wheeler-
> > > > _____
> > > > [mailto:Wanderlodge Forum@ yahoogroups. com] On Behalf Of
> ronmarabito2002
> > > > > Ron,
> > > > > Look like this?
> > > > > http://www.thermodi
> <http://www.thermodi sc.com/productde tail.asp? ProductID= 1> sc.com/productde
> > > > > Curt Sprenger
> > > > > Anaheim Hills , CA
> thermocouple.
> > > > yahoogroups. comps.com>,
> for a
92WB40
12-11-2009, 05:45
Post: #24
Heater part
Not the heaters that I am talking about. I am referring to the under dash and
bathroom electric heaters. No connection to Primus.
allow the toe kick fans to come on after the fluid gets to that temp.  But in
replacing one recently Bleakley put in one rated at 110 degrees.
> Rick Davis
> 1993 WBSA
> Loudon, TN
> From: Chuck Wheeler
> Â
> If I understand correctly we are talking about the safety cutoff switch.Â
> Â
> - Chuck Wheeler-
> From:WanderlodgeForum@ yahoogroups. com [mailto: WanderlodgeForum@
> Â
> Â
> --- In WanderlodgeForum@ yahoogroups. com, "Chuck Wheeler"
> > - Chuck Wheeler-
> > _____
> > [mailto:WanderlodgeForum@ yahoogroups. com] On Behalf Of David Ward
> > Ron,
> > Dave Ward
> > 80FC31SB
> > Mesa , AZ
> > wrote:
> > > Ron:
> > Parts. They have a location in the Portland , OR area that I have bought
> > > Marv
> > > 2004 M380
> > > Ocean Shores , WA
> > > --- In WanderlodgeForum@ yahoogroups. com, "ronmarabito2002" > > > wrote:
> > This
> > from
> > > > > - Chuck Wheeler-
> > > > > _____
> > ronmarabito2002
> > > > > > Ron,
> > > > > > Look like this?
> > > > > > http://www.thermodi
sc.com/productde
> > > > > > Curt Sprenger
> > > > > > Anaheim Hills , CA
> > thermocouple.
> > > > > > > --- In WanderlodgeForum@ > > ups.com>
> > > > > yahoogroups. com,
> > for a
12-11-2009, 14:51
Post: #25
Heater part
The snap disk on one of my heaters went bad and the FO replaced it with a piece
of wire.
I thought it might be important, called Cadet and found they don't sell this as
a spare part. So I bought a new heater for $100+ and guess what? When the new
heater came, it doesn't have this overtemp snap disk any more, just a wire
running along where the disk was.
So obviously, Cadet doesn't think it is important any more either.
MoreyZ
99LXi41' FL
12-11-2009, 15:58
Post: #26
Heater part
If you really study it I bet you will find
that it has one of the overtemp switches that will not reset to replace the
snap disk switch. They are a little inline device. Cadet in wall
electric heaters were subject to a recall in the early 2000s due to overheating
and causing fires.
- Chuck Wheeler-
WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of morey
Sent: Friday, December 11, 2009
8:52 PM
To:
Heater part
replaced it with a piece of wire.
MoreyZ
99LXi41' FL
12-12-2009, 14:40
Post: #27
Heater part
Morey,
The Cadet heaters in my '99 LXi were recalled in 2000 because they had a
overheat shutoff that had a reset button on the front. The new ones have this
thermal safety reset on the inside. It seems that people were resetting the
thermal cut off device without cleaning the dust out of the inside which, in
most all cases, was the cause of the cut off activating in the first place. The
new position forces you to open the heater to reset it and their thinking is; as
long as you have to open it to reset it, you will clean it at the same time.
Other than the position of the thermal protection device, they were identical so
I saved the old ones for more parts that I never needed!
I believe that you will find a different type of thermal cutoff in your new
heater. I don't believe Cadet makes a built in toe space heater without such a
device.
Rich D. '99LXi43' CT
piece of wire.
as a spare part. So I bought a new heater for $100+ and guess what? When the
new heater came, it doesn't have this overtemp snap disk any more, just a wire
> MoreyZ
> 99LXi41' FL
12-12-2009, 15:08
Post: #28
Heater part
Rich,
I wonder if they will still replace my other heater. The new heater
instructions did say that the heater should be cleaned out every 6 months. I'll
get in touch with them on Monday and let everyone know.
Thanks,
MoreyZ
99LXi41' FL
12-14-2009, 11:28
Post: #29
Heater part
Very interesting Morey. I might try this on mine and see if the wall thermostat
handles it O.K. by itself.
piece of wire.
> MoreyZ
> 99LXi41' FL
