Expansion tank for primus heat
03-07-2010, 03:45
one of my expansion tanks recently started leaking, my tanks are the one inlet
and one outlet type, Dupree has the the one inlet with two outlets, after many phone calls I found 2 at Bleakley in Ga. they have one more in stock, contact Hank @ 478-6273700 Lee Brown 94 WLWB40 |
03-07-2010, 05:22
I hope you checked the price before you ordered. When I checked with them some months ago, they were expensive!!
Rick Davis
1993 WBSA
Loudon, TN
From: dreamcatcher7300 <bat73@...> To: WanderlodgeForum@yahoogroups.com Sent: Sun, March 7, 2010 10:45:53 AM Subject: [WanderlodgeForum] Expansion tank for primus heat one of my expansion tanks recently started leaking, my tanks are the one inlet and one outlet type, Dupree has the the one inlet with two outlets, after many phone calls I found 2 at Bleakley in Ga. they have one more in stock, contact Hank @ 478-6273700 Lee Brown 94 WLWB40 |
03-07-2010, 05:38
--- In WanderlodgeForum@yahoogroups.com, Rick Davis
> > I hope you checked the price before you ordered.Ã When I checked with them some months ago, they were expensive!! > > Rick Davis > 1993 WBSA > Loudon, TN > > they were $75.00 ea, don't see that I had any other choice Lee Brown, 94WLWB40 > > > ________________________________ > From: dreamcatcher7300 <bat73@...> > To: WanderlodgeForum@yahoogroups.com > Sent: Sun, March 7, 2010 10:45:53 AM > Subject: [WanderlodgeForum] Expansion tank for primus heat > > Ã > one of my expansion tanks recently started leaking, my tanks are the one inlet and one outlet type, Dupree has the the one inlet with two outlets, after many phone calls I found 2 at Bleakley in Ga. they have one more in stock, contact Hank @ 478-6273700 Lee Brown 94 WLWB40 > |
03-07-2010, 08:15
If you prep the tank properly you can repair it with that hot black radiator
repair compound. I have replaced both of mine long ago but did repair one just for drill. I still have it and it works fine. Keeping it as a spare. --- In WanderlodgeForum@yahoogroups.com, Rick Davis > > I hope you checked the price before you ordered.Ã When I checked with them some months ago, they were expensive!! > > Rick Davis > 1993 WBSA > Loudon, TN > > > > > ________________________________ > From: dreamcatcher7300 <bat73@...> > To: WanderlodgeForum@yahoogroups.com > Sent: Sun, March 7, 2010 10:45:53 AM > Subject: [WanderlodgeForum] Expansion tank for primus heat > > Ã > one of my expansion tanks recently started leaking, my tanks are the one inlet and one outlet type, Dupree has the the one inlet with two outlets, after many phone calls I found 2 at Bleakley in Ga. they have one more in stock, contact Hank @ 478-6273700 Lee Brown 94 WLWB40 > |
03-07-2010, 12:56
Lee
I changed mine to a stainless steel tank when I converted to Webasto, kind of high priced but has greater capacity than the plastic ones. See this link to Canton Racing http://www.cantonracingproducts.com/cgi-...80-20\ 2 Steve Quandt 1993 PT-40 Iron Mountain, MI Winter Marblefalls, TX --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@...> wrote: > > one of my expansion tanks recently started leaking, my tanks are the one inlet and one outlet type, Dupree has the the one inlet with two outlets, after many phone calls I found 2 at Bleakley in Ga. they have one more in stock, contact Hank @ 478-6273700 Lee Brown 94 WLWB40 > |
03-07-2010, 13:05
I'm going to make one of those with a sight guage in it so I can look between the engine cover louvers and see the level. I have started shopping around for a Webasto system, even though I am going to fix my Primus one more time. Thinking of going to a standard 12 VDC coolant pump for some of the new cars - about $80.00 on e-bay rated for constant service.
From: SteveQ To: WanderlodgeForum@yahoogroups.com Sent: Sun, March 7, 2010 6:56:44 PM Subject: [WanderlodgeForum] Re: Expansion tank for primus heat Lee I changed mine to a stainless steel tank when I converted to Webasto, kind of high priced but has greater capacity than the plastic ones. See this link to Canton Racing http://www.cantonra cingproducts. com/cgi-bin/ commerce. cgi?preadd= action&key= 80-202 Steve Quandt 1993 PT-40 Iron Mountain, MI Winter Marblefalls, TX --- In "WanderlodgeForum%40yahoogroups.com", "dreamcatcher7300" <bat73@...> wrote: > > one of my expansion tanks recently started leaking, my tanks are the one inlet and one outlet type, Dupree has the the one inlet with two outlets, after many phone calls I found 2 at Bleakley in Ga. they have one more in stock, contact Hank @ 478-6273700 Lee Brown 94 WLWB40 > |
03-07-2010, 14:34
How can you access the take to remove it? My tank has a minor Bill 1983 PT 35 PC FL From: WanderlodgeForum@yahoogroups.com Lee I changed mine to a stainless steel tank when I converted to Webasto, kind of high priced but has greater capacity than the plastic ones. See this link to Canton Racing http://www.cantonracingproducts.com/cgi-...key=80-202 Steve Quandt 1993 PT-40 Iron Mountain, MI Winter Marblefalls, TX --- In "WanderlodgeForum%40yahoogroups.com", "dreamcatcher7300" <bat73@...> wrote: > > one of my expansion tanks recently started leaking, my tanks are the one inlet and one outlet type, Dupree has the the one inlet with two outlets, after many phone calls I found 2 at Bleakley in Ga. they have one more in stock, contact Hank @ 478-6273700 Lee Brown 94 WLWB40 > |
