5spd surprise
03-24-2006, 05:23
5spd surprise
I'm more confused than ever. There is no doubt I'm feeling 5
engine/tranmission speed transitions. It's possible I'm confusing the lock-up for a shift. There is information in the owners manual on two allison transmissions, a 644 and a 654CR. The 654CR does not have a creeper 1st gear although reverse is way lower on the 54 than the 44. The information shows the 644 locking up at the top of first gear. If I were to make a guess as to which transition was a lock-up, I'd be inclined to think it was the transition at the top of first gear. However, when climbing the 10% grade out of Palo Duro canyon, I kept the shift lever in 1 and I never felt a lock up or shift. Perhaps it does not lock up at the top of first gear if the shift lever is on '1'. I crawled under today to see if I could tell if it was a 644 or 654 since I have pictures of both, but couldn't get a clear enough view to tell. One thing that made me start analyzing what was happening was that when climbing, it would drop from top gear into the next lower gear, I could then move the shifter into 3 and it would hold that gear. However if it shifted down twice from top gear, and then I moved the shifter into '2' it would downshift again into a lower gear. I thought two gears down would be '2' and putting the shifter in '2' would simply hold that gear and stop it from shifting up. Does anyone know the difference between a 643 and a 644., if that is what I have? Top shift at full throttle is around 43 or 44mph. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > You talkin' 653 or 654cr for close ratio? CR takes off in 1st and is a 5 speed. 653 is a 640 with a creeper 1st. 653 takes off in 2nd. Not supposed to upshift a 653 under power from 1st to 2nd. > MH > ----- Original Message ----- > From: rwoodysurplus > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, March 24, 2006 10:25 AM > Subject: [WanderlodgeForum] Re: 5spd surprise > > > i have the 5 spd model in my f-800 with 8.3 c cummins and i have yet > to use the low gear. Its a tractor with a 38' trailer to haul heavy > stuff up to 58,000 but have yet to need the low gear and it has to > be selected to use low..Its not used in the d postion. > > > woody 81 fc looking for 8.3/world series 4000 for my bus~ > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@> wrote: > > > > Jeff, I talked to Lennie my Allison guy and he said the 654CR was > used in concrete trucks, had larger diameter converter 3" longer > input shaft and larger diameter stator support spline. He scratched > his head a little and allowed it might be possible to retro the 643 > input, stator support and converter to use the 5sp. planetary. I > can believe it was done as the engine has been turbo charged, > previous owner living in the mountains might have gotten weary > talking to the joggers on the grades. > > MH > > ----- Original Message ----- > > From: Jeff Miller > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, March 24, 2006 10:02 AM > > Subject: [WanderlodgeForum] Re: 5spd surprise > > > > > > Trust Mike on this one. The MT-643 is the FC transmission > until '87, > > the torque-converter does indeed feel like a shift, should be > around > > 40mph at full throttle. The 654 was used, on the 6V2TA Detroit > in the > > PT, not on the FC. The transmission that would fit your coach in > a 5- > > speed would be the MT-653, which is the MT-643 with a creeper > first > > added, dump-truck tranny. I'm not aware of that transmission > ever > > being installed in an FC nor do I know why you'd need a creeper > gear. > > > > 10mpg is seller's math. You should get around 8, less if you > push it > > hard. I've owned all configurations of diesel FC, never had one > that > > averaged better than 8.5 nor worse than 7.5mpg. If you have the > > original 5.29:1 gearing you're pretty far out of the BSFE curve > > already at 60, running 50-55 gently might give you 9mpg. The NA > has > > to work pretty hard to push an '82 FC35 down the highway, worst > > power/weight ratio FC made and geared for 55mph. On the other > hand, > > 8mpg isn't bad compared to the earlier gas models that weighed > > 10,000lbs less. > > > > Pull the sending unit for the fuel tank, replace it while you're > at > > it, they go bad, then calibrate it for the tank. Sounds like > yours > > was replaced without calibration. The '82 FC35 side-bath should > hold > > 265gallons. > > > > - Jeff Miller > > in Holland, MI > > > > > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > > > > It's possible I'm feeling convertor lock up, but I doubt it. > There > > > are 4 clear upshifts after 1st and 4 clear downshifts from top > gear. > > > Does a lock up convertor unlock under load on a hill, giving > the > > > appearance of a downshift? The amount of rpm difference is > more > > than > > > I would associate with a lock up. There is paperwork in the > owner's > > > manual indicating it it an MT 654CR transmission, which is a 5 > > spd. I > > > haven't crawled underneath to confirm yet. Where is the model > > number > > > on the transmission? > > > > > > Kerry > > > 82 FC 35 > > > Denver > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > > > <MHOHNSTEIN@> wrote: > > > > > > > > You are feeling the converter lock, it's not a gear change. > You > > > have a 643, 4 speed with lock up, you will get about 7/8 mpg > and > > > that's the way it is. Don't believe the gages, they are > indicators > > > and not to be taken literally. > > > > Let mine get down to indicated quarter tank once and it took > 145 > > > gallons, 150 tank, rear bath floor plan. > > > > MH > > > > ----- Original Message ----- > > > > From: davidkerryedwards > > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Thursday, March 23, 2006 11:21 PM > > > > Subject: [WanderlodgeForum] 5spd surprise > > > > > > > > > > > > Took my Bird for it's first cruise from Denver to Amarillo > to > > visit > > > > Palo Duro Canyon and Alibates Flint Quarries. After first > > thinking I > > > > was just losing my mind and not paying close enough > attention to > > > > shifting patterns as we climbed hills, I carefully counted > the > > shifts. > > > > It has a 5 spd transmission and not a 4 spd. What a > pleaant > > > > surprise. The Allison 5 spd has a lockup torque convertor > > which means > > > > the previous owners insistence that it got a steady 10mpg > is > > > > believable. This means that not only does it have a new > motor, > > it has > > > > a new transmission. Discovering this made up for the fact > that > > > > Amarillo had record low temperatures and snow during our > visit. > > > > Fuel gauge is reading way past full. Is this typical? It > > seems to be > > > > working, just that full is past full, and even past the > little > > button > > > > below the 'F'. If it does this, does 'E' still mean empty > or > > is empty > > > > now 1/2? > > > > > > > > Kerry > > > > 82 FC 35 > > > > Denver > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge > Automotive > > > maintenance > > > > Recreational vehicle dealer Used recreational > vehicles > > > Automotive radiators > > > > > > > > > > > > > > > --------------------------------------------------------------- > ----- > > ---------- > > > > YAHOO! GROUPS LINKS > > > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > > > b.. To unsubscribe from this group, send an email to: > > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! > Terms > > of > > > Service. > > > > > > > > > > > > > > > --------------------------------------------------------------- > ----- > > ---------- > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive > maintenance > > Recreational vehicle dealer Used recreational vehicles > Automotive radiators > > > > > > ------------------------------------------------------------------- > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > ------------------------------------------------------------------- > ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been removed] > |
03-24-2006, 05:48
5spd surprise
-mine is mt
-- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > You talkin' 653 or 654cr for close ratio? CR takes off in 1st and is a 5 speed. 653 is a 640 with a creeper 1st. 653 takes off in 2nd. Not supposed to upshift a 653 under power from 1st to 2nd. > MH > ----- Original Message ----- > From: rwoodysurplus > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, March 24, 2006 10:25 AM > Subject: [WanderlodgeForum] Re: 5spd surprise > > > i have the 5 spd model in my f-800 with 8.3 c cummins and i have yet > to use the low gear. Its a tractor with a 38' trailer to haul heavy > stuff up to 58,000 but have yet to need the low gear and it has to > be selected to use low..Its not used in the d postion. > > > woody 81 fc looking for 8.3/world series 4000 for my bus~ > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@> wrote: > > > > Jeff, I talked to Lennie my Allison guy and he said the 654CR was > used in concrete trucks, had larger diameter converter 3" longer > input shaft and larger diameter stator support spline. He scratched > his head a little and allowed it might be possible to retro the 643 > input, stator support and converter to use the 5sp. planetary. I > can believe it was done as the engine has been turbo charged, > previous owner living in the mountains might have gotten weary > talking to the joggers on the grades. > > MH > > ----- Original Message ----- > > From: Jeff Miller > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, March 24, 2006 10:02 AM > > Subject: [WanderlodgeForum] Re: 5spd surprise > > > > > > Trust Mike on this one. The MT-643 is the FC transmission > until '87, > > the torque-converter does indeed feel like a shift, should be > around > > 40mph at full throttle. The 654 was used, on the 6V2TA Detroit > in the > > PT, not on the FC. The transmission that would fit your coach in > a 5- > > speed would be the MT-653, which is the MT-643 with a creeper > first > > added, dump-truck tranny. I'm not aware of that transmission > ever > > being installed in an FC nor do I know why you'd need a creeper > gear. > > > > 10mpg is seller's math. You should get around 8, less if you > push it > > hard. I've owned all configurations of diesel FC, never had one > that > > averaged better than 8.5 nor worse than 7.5mpg. If you have the > > original 5.29:1 gearing you're pretty far out of the BSFE curve > > already at 60, running 50-55 gently might give you 9mpg. The NA > has > > to work pretty hard to push an '82 FC35 down the highway, worst > > power/weight ratio FC made and geared for 55mph. On the other > hand, > > 8mpg isn't bad compared to the earlier gas models that weighed > > 10,000lbs less. > > > > Pull the sending unit for the fuel tank, replace it while you're > at > > it, they go bad, then calibrate it for the tank. Sounds like > yours > > was replaced without calibration. The '82 FC35 side-bath should > hold > > 265gallons. > > > > - Jeff Miller > > in Holland, MI > > > > > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > > > > It's possible I'm feeling convertor lock up, but I doubt it. > There > > > are 4 clear upshifts after 1st and 4 clear downshifts from top > gear. > > > Does a lock up convertor unlock under load on a hill, giving > the > > > appearance of a downshift? The amount of rpm difference is > more > > than > > > I would associate with a lock up. There is paperwork in the > owner's > > > manual indicating it it an MT 654CR transmission, which is a 5 > > spd. I > > > haven't crawled underneath to confirm yet. Where is the model > > number > > > on the transmission? > > > > > > Kerry > > > 82 FC 35 > > > Denver > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > > > <MHOHNSTEIN@> wrote: > > > > > > > > You are feeling the converter lock, it's not a gear change. > You > > > have a 643, 4 speed with lock up, you will get about 7/8 mpg > and > > > that's the way it is. Don't believe the gages, they are > indicators > > > and not to be taken literally. > > > > Let mine get down to indicated quarter tank once and it took > 145 > > > gallons, 150 tank, rear bath floor plan. > > > > MH > > > > ----- Original Message ----- > > > > From: davidkerryedwards > > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Thursday, March 23, 2006 11:21 PM > > > > Subject: [WanderlodgeForum] 5spd surprise > > > > > > > > > > > > Took my Bird for it's first cruise from Denver to Amarillo > to > > visit > > > > Palo Duro Canyon and Alibates Flint Quarries. After first > > thinking I > > > > was just losing my mind and not paying close enough > attention to > > > > shifting patterns as we climbed hills, I carefully counted > the > > shifts. > > > > It has a 5 spd transmission and not a 4 spd. What a > pleaant > > > > surprise. The Allison 5 spd has a lockup torque convertor > > which means > > > > the previous owners insistence that it got a steady 10mpg > is > > > > believable. This means that not only does it have a new > motor, > > it has > > > > a new transmission. Discovering this made up for the fact > that > > > > Amarillo had record low temperatures and snow during our > visit. > > > > Fuel gauge is reading way past full. Is this typical? It > > seems to be > > > > working, just that full is past full, and even past the > little > > button > > > > below the 'F'. If it does this, does 'E' still mean empty > or > > is empty > > > > now 1/2? > > > > > > > > Kerry > > > > 82 FC 35 > > > > Denver > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge > Automotive > > > maintenance > > > > Recreational vehicle dealer Used recreational > vehicles > > > Automotive radiators > > > > > > > > > > > > > > > ----------------------------------------------------------- ---- > ----- > > ---------- > > > > YAHOO! GROUPS LINKS > > > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > > > b.. To unsubscribe from this group, send an email to: > > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! > Terms > > of > > > Service. > > > > > > > > > > > > > > > ----------------------------------------------------------- ---- > ----- > > ---------- > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive > maintenance > > Recreational vehicle dealer Used recreational vehicles > Automotive radiators > > > > > > --------------------------------------------------------------- ---- > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > --------------------------------------------------------------- ---- > ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > |
03-24-2006, 06:39
5spd surprise
No problem.
The MT-643, standard WLFC transmission, has four gears. The shift goes like this: 1/2, lockup, 2/3, 3/4. My speed reference might be a little off for the 5.29:1 gears, it has been a while since I always sent my 5.29 gears to the junkyard, but I believe it locks the torque converter when in second gear around 37mph at full throttle, will drop back out of lockup about the same speed at full throttle. Select second at a stop, you will feel the 1/2 shift, then the lockup. This should tell you conclusively that with two shifts in the second gear position you are feeling the lockup. As said before, the true 5-speed (the 654cr) is in the PT models with the 6-cylinder DD engine, the MT-643 in your bird is maxed-out at 250hp. A five-speed is not necessary IMO on the 3208, it has a good useable RPM range to 3000rpm (Na and ATAAC, 2800rpm for Ta), it just needs more power and taller gears for highway work above 55 or 60mph. The DD 2-stroke engines really needed the 5-speed more as they're only a 2100rpm engine with a fairly narrow power band. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > I'm more confused than ever. There is no doubt I'm feeling 5 > engine/tranmission speed transitions. It's possible I'm confusing the > lock-up for a shift. There is information in the owners manual on two > allison transmissions, a 644 and a 654CR. The 654CR does not have a > creeper 1st gear although reverse is way lower on the 54 than the 44. > The information shows the 644 locking up at the top of first gear. If > I were to make a guess as to which transition was a lock-up, I'd be > inclined to think it was the transition at the top of first gear. > However, when climbing the 10% grade out of Palo Duro canyon, I kept > the shift lever in 1 and I never felt a lock up or shift. Perhaps it > does not lock up at the top of first gear if the shift lever is on '1'. > I crawled under today to see if I could tell if it was a 644 or 654 > since I have pictures of both, but couldn't get a clear enough view to > tell. > One thing that made me start analyzing what was happening was that > when climbing, it would drop from top gear into the next lower gear, I > could then move the shifter into 3 and it would hold that gear. > However if it shifted down twice from top gear, and then I moved the > shifter into '2' it would downshift again into a lower gear. I > thought two gears down would be '2' and putting the shifter in '2' > would simply hold that gear and stop it from shifting up. > Does anyone know the difference between a 643 and a 644., if that is > what I have? Top shift at full throttle is around 43 or 44mph. > > Kerry > 82 FC 35 > Denver |
03-24-2006, 08:08
5spd surprise
Thanks. I will try that and report back. It may be a few days before
I have it out on the road again. Does it also shift down the same way? 2--lockup, then 2 unlocked? That would explain the double shift down I was feeling in second. There's still the info on the 644 and 654CR in the owner's handbook. It looks like it was added at the same time as the info on the new CAT engine was added. The rear end may also have been changed. It was running about 2620 rpm's at 64mph which seems a little low if the rear end is still the 5.29. There's Rockwell gear brochures in the owners handbook also. Kerry 82 FC 35 Denver -- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > No problem. > > The MT-643, standard WLFC transmission, has four gears. The shift > goes like this: 1/2, lockup, 2/3, 3/4. > > My speed reference might be a little off for the 5.29:1 gears, it has > been a while since I always sent my 5.29 gears to the junkyard, but I > believe it locks the torque converter when in second gear around > 37mph at full throttle, will drop back out of lockup about the same > speed at full throttle. Select second at a stop, you will feel the > 1/2 shift, then the lockup. This should tell you conclusively that > with two shifts in the second gear position you are feeling the > lockup. > > As said before, the true 5-speed (the 654cr) is in the PT models with > the 6-cylinder DD engine, the MT-643 in your bird is maxed-out at > 250hp. > > A five-speed is not necessary IMO on the 3208, it has a good useable > RPM range to 3000rpm (Na and ATAAC, 2800rpm for Ta), it just needs > more power and taller gears for highway work above 55 or 60mph. The > DD 2-stroke engines really needed the 5-speed more as they're only a > 2100rpm engine with a fairly narrow power band. > > - Jeff Miller > in Holland, MI |
03-24-2006, 09:11
5spd surprise
That's a little low for the 5.29, but about right. It is too high RPM
for any other gearing, likely the speedo or tach are not 100% accurate. Yes it downshifts in the same sequence, down into 2nd, then out of overdrive, then down to 1st. Climbing grades will never in my experience overheat the transmission no matter how hard you try, as long as the torque converter is in lockup. Once you drop out of lockup, the transmission starts to generate lots of heat, and that heat also goes into the radiator and drives the engine temp up. Keep that in mind when climbing as the '82 didn't normally come with a transmission temperature gauge, something worth adding. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > Thanks. I will try that and report back. It may be a few days before > I have it out on the road again. Does it also shift down the same > way? 2--lockup, then 2 unlocked? That would explain the double shift > down I was feeling in second. > There's still the info on the 644 and 654CR in the owner's handbook. > It looks like it was added at the same time as the info on the new CAT > engine was added. > The rear end may also have been changed. It was running about 2620 > rpm's at 64mph which seems a little low if the rear end is still the > 5.29. There's Rockwell gear brochures in the owners handbook also. > > Kerry > 82 FC 35 > Denver > > -- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > wrote: > > > > No problem. > > > > The MT-643, standard WLFC transmission, has four gears. The shift > > goes like this: 1/2, lockup, 2/3, 3/4. > > > > My speed reference might be a little off for the 5.29:1 gears, it has > > been a while since I always sent my 5.29 gears to the junkyard, but I > > believe it locks the torque converter when in second gear around > > 37mph at full throttle, will drop back out of lockup about the same > > speed at full throttle. Select second at a stop, you will feel the > > 1/2 shift, then the lockup. This should tell you conclusively that > > with two shifts in the second gear position you are feeling the > > lockup. > > > > As said before, the true 5-speed (the 654cr) is in the PT models with > > the 6-cylinder DD engine, the MT-643 in your bird is maxed-out at > > 250hp. > > > > A five-speed is not necessary IMO on the 3208, it has a good useable > > RPM range to 3000rpm (Na and ATAAC, 2800rpm for Ta), it just needs > > more power and taller gears for highway work above 55 or 60mph. The > > DD 2-stroke engines really needed the 5-speed more as they're only a > > 2100rpm engine with a fairly narrow power band. > > > > - Jeff Miller > > in Holland, MI > |
03-24-2006, 09:42
5spd surprise
Precisely what I noticed. Temperature starting going up when it did
the double downshift in second. Is there any way to hold it in lockup in second gear on a grade? What inspires it to come out of lockup? Rpm's? Does it stay locked up in second if it automatically downshifts to second while in drive, and then shifts out of lockup if you manually shift it down to second? I was surprised that there was no transmission temperature gauge and was thinking of adding one. Where do most people install the sender? Kerry --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > That's a little low for the 5.29, but about right. It is too high RPM > for any other gearing, likely the speedo or tach are not 100% > accurate. > > Yes it downshifts in the same sequence, down into 2nd, then out of > overdrive, then down to 1st. > > Climbing grades will never in my experience overheat the transmission > no matter how hard you try, as long as the torque converter is in > lockup. Once you drop out of lockup, the transmission starts to > generate lots of heat, and that heat also goes into the radiator and > drives the engine temp up. Keep that in mind when climbing as the '82 > didn't normally come with a transmission temperature gauge, something > worth adding. > > - Jeff Miller > in Holland, MI > > > |
03-24-2006, 15:52
5spd surprise
Kerry, Randy sells all his birds with a full tank too.
Greg --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > Yes, I was going to do that eventually. What happened was the > previous owner told me the tank was full, |
User(s) browsing this thread: 12 Guest(s)
