Bathroom electricity heater
03-29-2006, 02:36
Bob, I took mine out and cleaned it real good. There is an adjusting alan
screw that you can turn to make it stay on. Ernie-83pt40 in Texas [Non-text portions of this message have been removed] |
03-29-2006, 05:33
My electricity heater in the bath room nolonger works.Iam looking for
a replacmrnt.Does any boady know where i could get one for a 1985 PT. Bob Loomas 1985 PT 36 |
03-29-2006, 06:00
Hi Robert,
Try here if you can't find one locally. http://www.cadetco.com/ Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "robertnloomas" > > My electricity heater in the bath room nolonger works.Iam looking for > a replacmrnt.Does any boady know where i could get one for a 1985 > PT. > Bob Loomas 1985 PT 36 > |
03-29-2006, 08:24
Bob, depending on what is wrong with the heater, there is a reset on the
back I believe. Ralph At 06:33 PM 3/29/2006 +0000, you wrote: >My electricity heater in the bath room nolonger works.Iam looking for >a replacmrnt.Does any boady know where i could get one for a 1985 >PT. > Bob Loomas 1985 PT 36 > > > > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm |
03-29-2006, 08:57
---I want to think you all for your help.
I have not pulled the unit out yet.Ill chech it out in a couple of weeks.At the present time the unit will not come on so i was just thinking the worst. Bob Loomas 1985 PT 36 In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Bob, depending on what is wrong with the heater, there is a reset on the > back I believe. > > Ralph > > At 06:33 PM 3/29/2006 +0000, you wrote: > >My electricity heater in the bath room nolonger works.Iam looking for > >a replacmrnt.Does any boady know where i could get one for a 1985 > >PT. > > Bob Loomas 1985 PT 36 > > > > > > > > > > > > > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > |
03-29-2006, 13:06
Don't pull the heater yet. As Ralph mentioned, there is a reset
button, you'll need to poke a small screwdriver through the reset- button hole in the front panel. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Bob, depending on what is wrong with the heater, there is a reset on the > back I believe. > > Ralph > > At 06:33 PM 3/29/2006 +0000, you wrote: > >My electricity heater in the bath room nolonger works.Iam looking for > >a replacmrnt.Does any boady know where i could get one for a 1985 > >PT. > > Bob Loomas 1985 PT 36 > > > > > > > > > > > > > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > |
03-29-2006, 14:31
If you find the reset button tripped and the heater works after a
reset, be sure to find out why it tripped. The newer models have an internal reset that forces one to open the heater to reset it. This usually leads to observing the cause of the tripping; a buildup of dust and lint inside the heater. Constant resetting without eliminating the cause can be a fire hazard. My heaters were recalled and changed to identical units with a reset that is not accessible from the exterior for the reason stated above. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > Don't pull the heater yet. As Ralph mentioned, there is a reset > button, you'll need to poke a small screwdriver through the reset- > button hole in the front panel. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Bob, depending on what is wrong with the heater, there is a reset > on the > > back I believe. > > > > Ralph > > > > At 06:33 PM 3/29/2006 +0000, you wrote: > > >My electricity heater in the bath room nolonger works.Iam looking > for > > >a replacmrnt.Does any boady know where i could get one for a 1985 > > >PT. > > > Bob Loomas 1985 PT 36 > > > > > > > > > > > > > > > > > > > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > |
03-29-2006, 15:22
--- In WanderlodgeForum@yahoogroups.com, "g_man1146"
wrote: Sure hope it is only a reset.If it is ill remove the heater and give it a good cleaning. Thanks to all. Bob Loomas 1985 PT 36 > > > > > > > > |
03-29-2006, 17:19
Bob, on the 94 PT you have to turn on the Dash AC switch for the rear
with the heater turned on for it to work. I guess it is a way for the driver to turn the heater off from the cockpit. Gregory O'Connor 94PT 40--- In WanderlodgeForum@yahoogroups.com, "robertnloomas" > > --- In WanderlodgeForum@yahoogroups.com, "g_man1146" > wrote: > > Sure hope it is only a reset.If it is ill remove the heater and give > it a good cleaning. > Thanks to all. > Bob Loomas 1985 PT 36 > > > > > > > > > > > > > > |
03-29-2006, 23:29
> Sure hope it is only a reset.If it is ill remove the heater and give > it a good cleaning. > Thanks to all. > Bob Loomas 1985 PT 36 Bob, my heater would only come on for a short period of time thenn cut off. At one of our lone star rallies, someone was taking theirs apart and found that allen screw. It made a difference in the length of time the heater stayed on. Ernie-83pt40 in texas > > > > > > > > > > > > > > |
