Egg shells and Dupree Valves (was: B lack Water Tank Valve)
03-30-2006, 10:33
Folks,
The LXi is blessed (or cursed) with a garbage disposal.
For those who don't know, the galley sink drains into
the black water tank. Egg shells and Dupree valves don't
get along! My Dupree valve paddle is all chewed up
and won't seal the black water tank. I'm in Phoenix AZ.
Anyone know where I can get a new paddle ASAP?
TIA,
David Brady
'02 LXi, Smokey
Va
Jeff Miller wrote:
> Remove the two screws (with an empty and rinsed tank), pull the valve
> cartrige out of the housing. If the seal looks damaged/worn, we have
> plenty of replacement paddles. If not, check the housing where the seal
> slides in, could be something lodged in there. Should take around 5-10
> minutes to check. The word "inlet" should face the tank.
> Waterproof grease will help it to work easier and longer. Lube the O-
> ring to make re-installation easier.
> - Jeff Miller
> Dupree Products Inc.
> American Made,
> in Holland, MI
> --- In WanderlodgeForum@yahoogroups.com, David Brady wrote:
>> Folks,
>> I have a leaky black water tank Dupree valve. After a day of
>> traveling about a cup of fluid seeps past the seals - not
>> a total failure. Is there any maintenance I can do to
>> try to get a better seal. Is there a rebuild kit available,
>> or do I replace the entire valve.
>> Thanks,
>> David Brady
>> '02 LXi, Smokey,
>> Va
> Yahoo! Groups Links
03-30-2006, 10:51
Email Jeff Miller at
<synrgdsl@...>
and you can have one in no time.
John Suter
--- David Brady wrote:
> Folks,
> disposal.
> into
> don't
> AZ.
> TIA,
> David Brady
> '02 LXi, Smokey
> Va
> tank.
> longer. Lube the O-
> > - Jeff Miller
> > American Made,
> > in Holland, MI
> Brady wrote:
> >> Folks,
> After a day of
> seals - not
> do to
> available,
> >> Thanks,
> >> David Brady
> >> '02 LXi, Smokey,
> >> Va
> > Yahoo! Groups Links
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam
protection around
http://mail.yahoo.com
Do You Yahoo!?
03-30-2006, 13:54
Dave Brady
I only have a fairly good used paddle,
I live up by Wickenburg,but am going to Glendale in the morning.
Call me @ 928-684-0451
Fred Hulse
> [Original Message]
> From: David Brady
> To:
> Date: 3/30/2006 4:35:27 PM
> Subject: [WanderlodgeForum] Egg shells and Dupree Valves (was: B lack
Water Tank Valve)
> Folks,
> TIA,
> David Brady
> '02 LXi, Smokey
> Va
> > - Jeff Miller
> > American Made,
> > in Holland, MI
> >> Folks,
> >> Thanks,
> >> David Brady
> >> '02 LXi, Smokey,
> >> Va
> > Yahoo! Groups Links
> Yahoo! Groups Links
03-31-2006, 04:52
Thanks Fred for the generosity, but Jeff's got me covered.
Thanks again,
David Brady
'02 LXi, Smokey,
Va
fhulse@... wrote:
> Dave Brady
> Fred Hulse
>> [Original Message]
>> From: David Brady
>> To:
> Water Tank Valve)
>> Folks,
>> TIA,
>> David Brady
>> '02 LXi, Smokey
>> Va
>>> - Jeff Miller
>>> American Made,
>>> in Holland, MI
>>>> Folks,
>>>> Thanks,
>>>> David Brady
>>>> '02 LXi, Smokey,
>>>> Va
>>> Yahoo! Groups Links
>> Yahoo! Groups Links
> Yahoo! Groups Links
04-02-2006, 07:01
A general comment about eggshells and garbage disposers. Don not do
it. The disposer takes care of the shells. As David mentioned,
down the line is where the problem lies. They tend to get caught on
rough spots in the line and build up a blockage. I am not surprised
about chewing up valve seals.
Tom McCarthy
> Folks,
> TIA,
> David Brady
> '02 LXi, Smokey
> Va
valve
have
the seal
around 5-10
the O-
> > - Jeff Miller
> > American Made,
> > in Holland, MI
> >> Folks,
> >> Thanks,
> >> David Brady
> >> '02 LXi, Smokey,
> >> Va
> > Yahoo! Groups Links
