New member questions
04-04-2006, 01:28
A dirty fuel filter can cut into your power. Replace it to test. Same with the
air filter. These buses are low on power and I'm not familiar enough with your route to know if your experience was normal. I was down to about 28mph climbing Raton Pass a few weeks ago but that is that about 9000 ft so there's a lot less power at that altitude. I have the 210 hp NA with an aftermarket turbo. You may be in a situation in which the gear ratio in your bus is taller because of the turbo but the 15 hp difference that the turbo makes is not enough to deal with the taller gears. More experienced voices need to address that. Kerry 82 FC 35 Denver [Non-text portions of this message have been removed] |
04-04-2006, 03:33
Kerry, et. al.,
Something I am familiar with is getting more performance out of the older engines. Best bang for the buck, and simple also, is to add propane injection. It acts as a catalyst allowing more of the diesel to burn, giving you more power. I have used it on Detroits and Cummins, don't see why it won't work on Cat's also. Best and cheapest system I have found is the Bull Dog System <http://www.bullydog.com>. What you need is the "High output" kit. You may have to talk to Mike, the inventor of the system. The salesmen don't know the High output exists and think the system doesn't work on large engines. It was originally designed for the P/U trucks and that is the majority of their business. The last coach we had propane on, we had to be careful about over running cars on the hills. I would put one on my new coach except that it has enough power for the weight. George Lowry '06 Alpine Apex - Formerly '95 WBDA 4203 Spearfish, SD - Leaving Las Vegas heading for Norcal in the rain. -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Edwards, Kerry Sent: Tuesday, April 04, 2006 6:29 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] New member questions A dirty fuel filter can cut into your power. Replace it to test. Same with the air filter. These buses are low on power and I'm not familiar enough with your route to know if your experience was normal. I was down to about 28mph climbing Raton Pass a few weeks ago but that is that about 9000 ft so there's a lot less power at that altitude. I have the 210 hp NA with an aftermarket turbo. You may be in a situation in which the gear ratio in your bus is taller because of the turbo but the 15 hp difference that the turbo makes is not enough to deal with the taller gears. More experienced voices need to address that. Kerry 82 FC 35 Denver [Non-text portions of this message have been removed] Yahoo! Groups Links -- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.385 / Virus Database: 268.3.5/300 - Release Date: 4/3/2006 |
04-04-2006, 06:38
I must comment here, tried propane with my truck. 3208 375 hp marine arrangement
with 400 hp radiator/charge aircooler. Georges pal Pius at Bell turbo turned me on to a good Cat turbo charger and that helped my boost a good bit, however it doesn't get over 16 #s. That's OK as I have a little trouble keeping the pipe boots from blowing off. The propane system I used is made by a guy from MI and it responds to turbo boost, more boost more propane. Only thing I noticed is the tank ran out pretty fast, (80 gal.) can't say I was aware of more grunt when I was in the Rockies. Certainly not a night and day difference. I'm not throwing rocks at the theory but I wouldn't expect much improvement, the FC is way too heavy for the 3208, needs 400hp something to move along like most people would like. You start turning up the power in a none cooled diesel you will blow holes in the pistons and lose head gaskets. Been there and done all that with 3208s. Best thing is to maximize the air to the intake and make sure the throttle is opening ALL the way. It's pretty common for FCs to have throttle opening problems. Sometimes the trans cable will keep the throttle from full travel, had that problem with my FC and it took a few times under the cover to get it all sorted out, but I saw a major difference once I got it right. The lever on the pump needs to be fully opened, that last little bit of opening makes an amazing difference. As you have a 225 hp a 250 intake is a good bit larger both in flange opening and port runner size, I got a couple of 250 intakes around. 200 bucks. I used a air cleaner off a '88 Top Kick with a turbo 3208, much less restrictive that the square box thing BB used. Mike Hohnstein Germantown, WI 83FC35 83 Ford Toter home ----- Original Message ----- From: George Lowry To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, April 04, 2006 10:33 AM Subject: RE: [WanderlodgeForum] New member questions Kerry, et. al., Something I am familiar with is getting more performance out of the older engines. Best bang for the buck, and simple also, is to add propane injection. It acts as a catalyst allowing more of the diesel to burn, giving you more power. I have used it on Detroits and Cummins, don't see why it won't work on Cat's also. Best and cheapest system I have found is the Bull Dog System <http://www.bullydog.com>. What you need is the "High output" kit. You may have to talk to Mike, the inventor of the system. The salesmen don't know the High output exists and think the system doesn't work on large engines. It was originally designed for the P/U trucks and that is the majority of their business. The last coach we had propane on, we had to be careful about over running cars on the hills. I would put one on my new coach except that it has enough power for the weight. George Lowry '06 Alpine Apex - Formerly '95 WBDA 4203 Spearfish, SD - Leaving Las Vegas heading for Norcal in the rain. -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Edwards, Kerry Sent: Tuesday, April 04, 2006 6:29 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] New member questions A dirty fuel filter can cut into your power. Replace it to test. Same with the air filter. These buses are low on power and I'm not familiar enough with your route to know if your experience was normal. I was down to about 28mph climbing Raton Pass a few weeks ago but that is that about 9000 ft so there's a lot less power at that altitude. I have the 210 hp NA with an aftermarket turbo. You may be in a situation in which the gear ratio in your bus is taller because of the turbo but the 15 hp difference that the turbo makes is not enough to deal with the taller gears. More experienced voices need to address that. Kerry 82 FC 35 Denver [Non-text portions of this message have been removed] Yahoo! Groups Links -- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.385 / Virus Database: 268.3.5/300 - Release Date: 4/3/2006 ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-05-2006, 08:09
George,
How about reposting this under a more appropriate subject heading so one can find it in the forum library. Howard truitt Camilla, Ga. 86 8V92 PT40 ----- Original Message ----- From: George Lowry To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, April 04, 2006 11:33 AM Subject: RE: [WanderlodgeForum] New member questions Kerry, et. al., Something I am familiar with is getting more performance out of the older engines. Best bang for the buck, and simple also, is to add propane injection. It acts as a catalyst allowing more of the diesel to burn, giving you more power. I have used it on Detroits and Cummins, don't see why it won't work on Cat's also. Best and cheapest system I have found is the Bull Dog System <http://www.bullydog.com>. What you need is the "High output" kit. You may have to talk to Mike, the inventor of the system. The salesmen don't know the High output exists and think the system doesn't work on large engines. It was originally designed for the P/U trucks and that is the majority of their business. The last coach we had propane on, we had to be careful about over running cars on the hills. I would put one on my new coach except that it has enough power for the weight. George Lowry '06 Alpine Apex - Formerly '95 WBDA 4203 Spearfish, SD - Leaving Las Vegas heading for Norcal in the rain. -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Edwards, Kerry Sent: Tuesday, April 04, 2006 6:29 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] New member questions A dirty fuel filter can cut into your power. Replace it to test. Same with the air filter. These buses are low on power and I'm not familiar enough with your route to know if your experience was normal. I was down to about 28mph climbing Raton Pass a few weeks ago but that is that about 9000 ft so there's a lot less power at that altitude. I have the 210 hp NA with an aftermarket turbo. You may be in a situation in which the gear ratio in your bus is taller because of the turbo but the 15 hp difference that the turbo makes is not enough to deal with the taller gears. More experienced voices need to address that. Kerry 82 FC 35 Denver [Non-text portions of this message have been removed] Yahoo! Groups Links -- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.385 / Virus Database: 268.3.5/300 - Release Date: 4/3/2006 ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
