Thin lites
04-08-2006, 08:50
Thin lites
I have removed my bath thin lite and was going to replace the ballast.
Low and behold there is a circuit board on the back of that thing. That is the culprit that is fried. Anyone replace this circuit board? why would there be a circuit board on a flourescent fixture? Inquiring non electrical mind wants to know. Ernie-83pt40 in Louisiana |
04-08-2006, 12:04
Thin lites
Those lights are actually 110V florescent lights. The circuit board is
the inverter. I have replaced those. They run about $35 ea. After the Zab Juda/Mayweather fight, I'll see if I can find where to buy and the part#. Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > I have removed my bath thin lite and was going to replace the ballast. > Low and behold there is a circuit board on the back of that thing. That > is the culprit that is fried. Anyone replace this circuit board? why > would there be a circuit board on a flourescent fixture? Inquiring non > electrical mind wants to know. Ernie-83pt40 in Louisiana > |
04-08-2006, 12:14
Thin lites
Contact Stephen Birtles. He most likely has what you need or can get
them for you. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Jay Darst wrote: > Those lights are actually 110V florescent lights. The circuit board is > the inverter. > > I have replaced those. They run about $35 ea. > > After the Zab Juda/Mayweather fight, I'll see if I can find where to > buy and the part#. > |
04-08-2006, 13:43
Thin lites
Hi Ernie,
Check out <http://www.thinlite.com> They have a flat rate repair on their units that is, IIRC $23.50 and you get the same warranty as a new lite. I had a couple of mine done and they were great. George Lowry '06 Alpine Alpex - Formerly '95 WBDA 4203 Spearfish, SD Now in Columbia, CA -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Ernest Ekberg Sent: Saturday, April 08, 2006 1:50 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Thin lites I have removed my bath thin lite and was going to replace the ballast. Low and behold there is a circuit board on the back of that thing. That is the culprit that is fried. Anyone replace this circuit board? why would there be a circuit board on a flourescent fixture? Inquiring non electrical mind wants to know. Ernie-83pt40 in Louisiana Yahoo! Groups Links -- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.385 / Virus Database: 268.3.5/303 - Release Date: 4/6/2006 |
04-09-2006, 04:55
Thin lites
Thanks, Jay. I bought those inverter/ballasts from Stephen Birtles last
year. I was not expecting a "strip' ballast.Stephen called me and directed me through the process. ernie-83pt40- coach in louisiana, me home in texas [Non-text portions of this message have been removed] |
04-09-2006, 07:58
Thin lites
We now have the replacement ballasts for twin tubes lights. These
ballasts are a higher quality than thin lite and bolt or rivet into the same place as the original ballast. They come in two power capacities up to 8 watt twin tube or 16 wattts total and up to 15 watt twin tube or 30 watts total. They are voltage stable between 9and 16 volts and will survuve temporary surges to 24 volts although not recommended We are also going to offer a rebuild service for 12 volt flourescent lights and it is very competitively priced with other sources in the industry Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > > Those lights are actually 110V florescent lights. The circuit board is > the inverter. > > I have replaced those. They run about $35 ea. > > After the Zab Juda/Mayweather fight, I'll see if I can find where to > buy and the part#. > > Jay Darst > 85PT40 > Springfield, IL > > > > --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > > > > I have removed my bath thin lite and was going to replace the > ballast. > > Low and behold there is a circuit board on the back of that thing. > That > > is the culprit that is fried. Anyone replace this circuit board? why > > would there be a circuit board on a flourescent fixture? Inquiring > non > > electrical mind wants to know. Ernie-83pt40 in Louisiana > > > |
