best way to operate electric trailer brakes from BB pt-40
04-13-2006, 15:51
What type and make controller would be best to controll elec. brakes
on two axel trailer towed behind a pt-40? I notice there are electric operated or air- elec. operated. What would be the advantageof the air controled? Also I see that Reese has an hand- remote control. Would this be good or bad. Is there any reason you could not power the controler from the gen. set battery? thanks,marvin 1984 pt-40 |
04-14-2006, 02:21
On some brake controllers the controller unit under the dash is a kinda
rheostat that uses inertia to regulate the braking force. these controllers are enabled by the bus tail brake light throwing a switch after the controller ( if you go down hill the controller feels inertia and will signal trailer braking). I know of air over hydrolic brakes for trailers which is like a surge unit on the trailer operated by airpress from the tow veh. If there is a controller that uses air press as a force regulater for trailers , oder me one. In California you need a battery on the trailer for the brakeaway safty brake system. E brakes on a trailer do not react well with antilock tow brakes. I disable the antilock when towing with a pickup. Gregory O'Connor 94 pt40 Romoland California--- In WanderlodgeForum@yahoogroups.com, "sam09_99" > > > What type and make controller would be best to controll elec. brakes > on two axel trailer towed behind a pt-40? > > I notice there are electric operated or air- elec. operated. What > would be the advantageof the air controled? > > Also I see that Reese has an hand- remote control. Would this be good > or bad. > > Is there any reason you could not power the controler from the gen. > set battery? > thanks,marvin > 1984 pt-40 > |
04-14-2006, 05:51
Yes Hayes makes an air operated electric brake controller, just don't know what
the advantage would be.K1100400B is the part ph 800 892 2676Marvin SkaggsBuffalo, Ky. 427161984 PT40--- On Fri 04/14, Gregory OConnor < Gregoryoc@... > wrote:From: Gregory OConnor [mailto: Gregoryoc@...]To: WanderlodgeForum@...: Fri, 14 Apr 2006 14:21:03 -0000Subject: [WanderlodgeForum] Re: best way to operate electric trailer brakes from BB pt-40On some brake controllers the controller unit under the dash is a kinda rheostat that uses inertia to regulate the braking force. these controllers are enabled by the bus tail brake light throwing a switch after the controller ( if you go down hill the controller feels inertia and will signal trailer braking). I know of air over hydrolic brakes for trailers which is like a surge unit on the trailer operated by airpress from the tow veh. If there is a controller that uses air press as a force regulater for trailers , oder me one. In California you need a battery on the trailer for the brakeaway safty brake system. E brakes on a trailer do not react well with antilock tow brakes. I disable the antilock when towing with a pickup.Gregory O'Connor94 pt40 Romoland California--- In WanderlodgeForum@yahoogroups.com, "sam09_99" wrote:>> > What type and make controller would be best to controll elec. brakes > on two axel trailer towed behind a pt-40?> > I notice there are electric operated or air- elec. operated. What > would be the advantageof the air controled?> > Also I see that Reese has an hand- remote control. Would this be good > or bad.> > Is there any reason you could not power the controler from the gen. > set battery?> thanks,marvin> 1984 pt-40> YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. _______________________________________________ Join Excite! - http://www.excite.com The most personalized portal on the Web! [Non-text portions of this message have been removed] |
04-14-2006, 13:15
Marvin, I placed an order for the controller. The advantage I see is
that it will send a signal to the trailer true to the operators force on the brake pedal. The harder the operator pushes the brake pedal the more juice it will send to the e trailer brakes( even at 5 mph). The inertia controllers are finiky and braking force is a factor of too many variables, even mounting position and mounting angle of the inertia-controller can change or disable braking force. Gregory O'Connor 94pt40 Romoland California "The faster you can stop, the faster you can go" --- In WanderlodgeForum@yahoogroups.com, "" > > Yes Hayes makes an air operated electric brake controller, just don't know what the advantage would be.K1100400B is the part ph 800 892 2676Marvin SkaggsBuffalo, Ky. 427161984 PT40--- |
04-15-2006, 06:23
George,
What were the $ for that controller, if you don't mind my asking? Including shipping and tax if you know yet. Thanx Dick Hayden - '87 PT 38 - Lk Stevens, WA ----- Original Message ----- From: Gregory OConnor To: WanderlodgeForum@yahoogroups.com Sent: Friday, April 14, 2006 6:15 PM Subject: [WanderlodgeForum] Re: best way to operate electric trailer brakes from BB pt-40 Marvin, I placed an order for the controller. The advantage I see is that it will send a signal to the trailer true to the operators force on the brake pedal. The harder the operator pushes the brake pedal the more juice it will send to the e trailer brakes( even at 5 mph). The inertia controllers are finiky and braking force is a factor of too many variables, even mounting position and mounting angle of the inertia-controller can change or disable braking force. Gregory O'Connor 94pt40 Romoland California "The faster you can stop, the faster you can go" --- In WanderlodgeForum@yahoogroups.com, "" > > Yes Hayes makes an air operated electric brake controller, just don't know what the advantage would be.K1100400B is the part ph 800 892 2676Marvin SkaggsBuffalo, Ky. 427161984 PT40--- SPONSORED LINKS Recreational vehicles<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea\ ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKk\ U7Dzhn_ObWmSYTw> Wanderlodge<http://groups.yahoo.com/gads?t=ms&k=Wand...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj\ 9U0JvqYQ> Automotive maintenance<http://groups.yahoo.com/gads?t=ms&k=Auto...ecrea\ tional+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle\ +dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4\ u_5wI8Pmy34cC1O9CxA> Recreational vehicle dealer<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle\ +dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_\ XahaeYHfELr6o72IW1A> Used recreational vehicles<http://groups.yahoo.com/gads?t=ms&k=Used...Recre\ ational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl\ e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UG\ EY5km4L-kXbDI4ZSadEw> Automotive radiators<http://groups.yahoo.com/gads?t=ms&k=Auto...ation\ al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea\ ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmI\ SsCWgTnMq_4GlXA> ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-15-2006, 16:06
The air to electric brake-controller is from SouthWest Wheel . 150.00
no shipping charge and I will pay 7.75% local Riverside County sales Tax as it is for a dumptruck business purchase. http://www.brakecontroller.com/ I have purchased axles, hubs and trailer parts from SW Trailer in the past with no problems. Gregory O'Connor 94pt40 DT --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > George, > What were the $ for that controller, if you don't mind my asking? Including shipping and tax if you know yet. |
