35 FC Transmissions
04-17-2006, 16:11
35 FC Transmissions
Tom, a diesel or gasoline engine is an air breathing device. A turbo
charger increases the amount of air it can breath. If the boost pressure provided is 14.7 PSI, the engine sees instead of the normal one atmosphere of pressure, two atmospheres. It is, at 14.7PSI of boost, without losses considerations, now twice the size engine. It does of course as you noted, take more fuel. The intercooler takes some of the heat out of the intake air, providing a denser, heavier fuel air mixture. The magic as I see it is the electronic controls and devices used today to not only lower emissions but also create more power with less fuel. Jerry MS Gulf Coast Looking for a BB _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner Sent: Monday, April 17, 2006 10:27 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions Hank thats about what I am getting with my 1982 FC35 with the Cat 3208NA. People forget that turbo chargers and intercoolers do not make an engine more efficient they allow a denser fuel/air charge to be pumped into the cylinder. More fuel pumped into the cylinder means more fuel used. A horsepower increase from 210HP to 300HP in the same engine can only be realized thru the use of more fuel. There is no magic involved. Tom Warner Vernon Center,NY 1982 FC35 (for sale http://tinyurl.com/lotbdcan ) 1985 PT40 At 09:55 PM 4/17/2006, you wrote: >---Mike: >That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg >consistently while my 90SP36 gets only 6-7mpg!!! That's a true >staement and NOT nuts! >Regards, >Hank Hannigan >1990SP36 > > > > > >In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" ><MHOHNSTEIN@...> wrote: > > > > That's nuts. Turbo charging and charge air coolers are methods to >improve the efficiency of diesel engines. The 5 speed OD trans >keeps engine speed down and increased horse power improves the power >to weight ratio over the older NA/643 speed bumps. Most 87up FCs >have two airs and the smaller lighter gen set, handling and >acceleration are greatly enhanced. There is no way a NA gets better >mileage than a turbo, level playing field. > > I drove Millers 88 FC a while back and it was a night and day >diffference compared to my well tuned 250 hp 83 rear bath. > > Engine speed is the major issue when considering improving >milage. > > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm at >full throttle and don't need to go over 2500 rpm for max power. NAs >need to spin faster due to the lack of forced induction and need >more fuel to facilitate that. > > Now I could be over looking something, so if you have some REAL >experience that might lend some credibility to your aurgument I'm >listening Warner. I'm interested in miles you have driven your NA, >average speed, speed on grades, that sort of thing. I assume you >have taken some trips, so lets hear what you have really seen for >fuel use. Those considering your FC might want to know. > > Mike Hohnstein > > ----- Original Message ----- > > From: Tom Warner > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, April 16, 2006 9:58 PM > > Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > I doubt very much if you will find an 87-89 FC that will even >get > > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I >believe > > the 4th gear is the same as the 5th or 6th gear in the 87-89. > > > > Tom Warner > > Vernon Center,NY > > 1982 FC35 ( for sale at ><http://s69.photobucket.com/albums/i57/warbucks13477/>http://s69.photobucke t.com/albums/i57/warbucks13477/ >) > > 1985 PT 40 > > > > > > At 09:55 PM 4/16/2006, you wrote: > > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway" > > > > > > >i hear storys from 7-10 mpg on the fcs with the 4 speed > > >tranny,now,thats not bad milage as i see it! > > >randy dupree > > > > Does anyone know if they ever put the 5 or 6 speed overdrive > > > > transmission in the 35 FC? If so, what year did they >start? I've > > > > zeroed in on the 35FC as the correct Bird for my wife and I, > > >however, I > > > > really hesitate buying one that gets such poor fuel mileage >as the 4 > > > > speed Allison. John & Pat - Wantabee's, Stuart > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& >w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr >eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh >n_ObWmSYTw>Recreational > > >vehicles > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot >ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v >ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- >8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge >&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec >reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm >y34cC1O9CxA>Automotive > > >maintenance > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander >lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah >aeYHfELr6o72IW1A>Recreational > > >vehicle dealer > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl >odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used >+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km >4L-kXbDI4ZSadEw>Used > > >recreational vehicles > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w >3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre >ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT >nMq_4GlXA>Automotive > > >radiators > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/gr oup/WanderlodgeForum>WanderlodgeForum" > >on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > > > > > >---------- > > > > > > > > > > > > > > > > ------------------------------------------------------------------- >----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms >of Service. > > > > > > ------------------------------------------------------------------- >----------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > derlodgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> vehicles Wanderlodge <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> maintenance Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer Used <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> radiators _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] |
04-17-2006, 16:28
35 FC Transmissions
Jerry the electronic controls on todays diesel engine were installed
to ensure that the engines meet the very stringent emission standards of today. They have not become more efficient they have become compliant with the laws at the expense of lowering their efficiency. They achieve that by creating more heat and thus run at higher temperatures, and they therefore need better lubricants and increased maintenance, at the same time of operating at reduced power. Remember there is always a tradeoff to everything. A gallon of diesel fuel contains approximately 140,000 BTUs. One horsepower equals 2545 BTUs per hour. Its easy to see that increased horsepower is only achieved thru packing more fuel/air mixture into the cylinders and efficiently exhausting it. Tom Warner Vernon Center,NY 1982 FC35 for sale ( http://tinyurl.com/zv2on ) 1985 PT40 . At 12:11 AM 4/18/2006, you wrote: >Tom, a diesel or gasoline engine is an air breathing device. A turbo >charger increases the amount of air it can breath. If the boost pressure >provided is 14.7 PSI, the engine sees instead of the normal one atmosphere >of pressure, two atmospheres. It is, at 14.7PSI of boost, without losses >considerations, now twice the size engine. It does of course as you noted, >take more fuel. The intercooler takes some of the heat out of the intake >air, providing a denser, heavier fuel air mixture. The magic as I see it is >the electronic controls and devices used today to not only lower emissions >but also create more power with less fuel. > > > >Jerry > >MS Gulf Coast > >Looking for a BB > > > > > > _____ > >From: WanderlodgeForum@yahoogroups.com >[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner >Sent: Monday, April 17, 2006 10:27 PM >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > >Hank thats about what I am getting with my 1982 FC35 with the Cat >3208NA. People forget that turbo chargers and intercoolers do not >make an engine more efficient they allow a denser fuel/air charge to >be pumped into the cylinder. More fuel pumped into the cylinder means >more fuel used. A horsepower increase from 210HP to 300HP in the same >engine can only be realized thru the use of more fuel. There is no >magic involved. > >Tom Warner >Vernon Center,NY >1982 FC35 (for sale <http://tinyurl.com/lotbdcan>http://tinyurl.com/lotbdcan ) >1985 PT40 > >At 09:55 PM 4/17/2006, you wrote: > >---Mike: > >That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg > >consistently while my 90SP36 gets only 6-7mpg!!! That's a true > >staement and NOT nuts! > >Regards, > >Hank Hannigan > >1990SP36 > > > > > > > > > > > >In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > ><MHOHNSTEIN@...> wrote: > > > > > > That's nuts. Turbo charging and charge air coolers are methods to > >improve the efficiency of diesel engines. The 5 speed OD trans > >keeps engine speed down and increased horse power improves the power > >to weight ratio over the older NA/643 speed bumps. Most 87up FCs > >have two airs and the smaller lighter gen set, handling and > >acceleration are greatly enhanced. There is no way a NA gets better > >mileage than a turbo, level playing field. > > > I drove Millers 88 FC a while back and it was a night and day > >diffference compared to my well tuned 250 hp 83 rear bath. > > > Engine speed is the major issue when considering improving > >milage. > > > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm at > >full throttle and don't need to go over 2500 rpm for max power. NAs > >need to spin faster due to the lack of forced induction and need > >more fuel to facilitate that. > > > Now I could be over looking something, so if you have some REAL > >experience that might lend some credibility to your aurgument I'm > >listening Warner. I'm interested in miles you have driven your NA, > >average speed, speed on grades, that sort of thing. I assume you > >have taken some trips, so lets hear what you have really seen for > >fuel use. Those considering your FC might want to know. > > > Mike Hohnstein > > > ----- Original Message ----- > > > From: Tom Warner > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Sunday, April 16, 2006 9:58 PM > > > Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > > > > I doubt very much if you will find an 87-89 FC that will even > >get > > > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I > >believe > > > the 4th gear is the same as the 5th or 6th gear in the 87-89. > > > > > > Tom Warner > > > Vernon Center,NY > > > 1982 FC35 ( for sale at > ><<http://s69.photobucket.com/albums/i57/warbucks13477/>http://s69.p > hotobucket.com/albums/i57/warbucks13477/>http://s69.photobucke >t.com/albums/i57/warbucks13477/ > >) > > > 1985 PT 40 > > > > > > > > > At 09:55 PM 4/16/2006, you wrote: > > > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway" > > > > > > > > >i hear storys from 7-10 mpg on the fcs with the 4 speed > > > >tranny,now,thats not bad milage as i see it! > > > >randy dupree > > > > > Does anyone know if they ever put the 5 or 6 speed overdrive > > > > > transmission in the 35 FC? If so, what year did they > >start? I've > > > > > zeroed in on the 35FC as the correct Bird for my wife and I, > > > >however, I > > > > > really hesitate buying one that gets such poor fuel mileage > >as the 4 > > > > > speed Allison. John & Pat - Wantabee's, Stuart > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://groups.ya\ hoo.com/gads? > >t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& > >w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr > >eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh > >n_ObWmSYTw>Recreational > > > >vehicles > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://groups.ya\ hoo.com/gads? > >t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot > >ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v > >ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- > >8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://groups.ya\ hoo.com/gads? > >t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge > >&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec > >reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm > >y34cC1O9CxA>Automotive > > > >maintenance > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://groups.ya\ hoo.com/gads? > >t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander > >lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use > >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah > >aeYHfELr6o72IW1A>Recreational > > > >vehicle dealer > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://groups.ya\ hoo.com/gads? > >t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl > >odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used > >+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km > >4L-kXbDI4ZSadEw>Used > > > >recreational vehicles > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://groups.ya\ hoo.com/gads? > >t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w > >3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre > >ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT > >nMq_4GlXA>Automotive > > > >radiators > > > > > > > > > > > >---------- > > > >YAHOO! GROUPS LINKS > > > > > > > > * Visit your group > > > > > > > > >"<<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/grou\ p/WanderlodgeForum>http://groups.yahoo.com/gr >oup/WanderlodgeForum>WanderlodgeForum" > > > >on the web. > > > > * > > > > * To unsubscribe from this group, send an email to: > > > > * > > > > > > > > > > > > * > > > > * Your use of Yahoo! Groups is subject to the > > > > > > ><<<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>http://d\ ocs.yahoo.com/info/terms/>Yahoo! > > > Terms of Service. > > > > > > > > > > > >---------- > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------- > >----------- > > > YAHOO! GROUPS LINKS > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > b.. To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > >of Service. > > > > > > > > > ------------------------------------------------------------------- > >----------- > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/\ WanderlodgeForum>WanderlodgeForum" > on the >web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > >derlodgeForum-unsubscribe@yahoogroups.com > > > > * > > * Your use of Yahoo! Groups is subject to the > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > > >---------- > > > > > > > > >SPONSORED LINKS > > >Recreational ><<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v>h\ ttp://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v >ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea >ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU >kCKkU7Dzhn_ObWmSYTw> vehicles > >Wanderlodge ><<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2>h\ ttp://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 >=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP >j9U0JvqYQ> > >Automotive ><<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+>h\ ttp://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ >vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de >aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF >4u_5wI8Pmy34cC1O9CxA> maintenance > > >Recreational ><<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati>h\ ttp://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati >onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic >le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s >ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer > >Used ><<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio>h\ ttp://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio >nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl >e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si >g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles > >Automotive ><<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve>h\ ttp://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve >hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal >er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV >MmISsCWgTnMq_4GlXA> radiators > > > > _____ > >YAHOO! GROUPS LINKS > > > >* Visit your group "WanderlodgeForum ><<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/\ WanderlodgeForum> >" on the web. > > >* To unsubscribe from this group, send an email to: >WanderlodgeForum-unsubscribe@yahoogroups.com > > > >* Your use of Yahoo! Groups is subject to the Yahoo! ><<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/> >Terms of Service. > > > > _____ > > > >[Non-text portions of this message have been removed] > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
04-17-2006, 16:33
35 FC Transmissions
---Mike:
You said an NA is "not good at all." I have a Mercedes NA diesel here in Australia and it is simply great! 4:11 diff and I get great mileage too. That ole 210NA CAT is great too!!I bet a lot of guys like their 210 CAT NA's!! Wish I had my old 77FC33 back!! Simple, 8-9mpg, a "thrill" to steer and noisy!! and...$100,000 less tied up in it!! Regards, Hank Hannigan 1990 SP36 (stored in VEGAS) In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > And I said level playing field. You want to talk about weight difference? How about speed? You are comparing apples to oranges and that IS nuts. NAs are nasty smoky obsolete and over the hill, at best. A diesel with out a turbo isn't good > not good at all. > MH > ----- Original Message ----- > From: Henry Jay Hannigan > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, April 17, 2006 8:55 PM > Subject: [WanderlodgeForum] Re: 35 FC Transmissions > > > ---Mike: > That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg > consistently while my 90SP36 gets only 6-7mpg!!! That's a true > staement and NOT nuts! > Regards, > Hank Hannigan > 1990SP36 > > > > > > In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@> wrote: > > > > That's nuts. Turbo charging and charge air coolers are methods to > improve the efficiency of diesel engines. The 5 speed OD trans > keeps engine speed down and increased horse power improves the power > to weight ratio over the older NA/643 speed bumps. Most 87up FCs > have two airs and the smaller lighter gen set, handling and > acceleration are greatly enhanced. There is no way a NA gets better > mileage than a turbo, level playing field. > > I drove Millers 88 FC a while back and it was a night and day > diffference compared to my well tuned 250 hp 83 rear bath. > > Engine speed is the major issue when considering improving > milage. > > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm at > full throttle and don't need to go over 2500 rpm for max power. NAs > need to spin faster due to the lack of forced induction and need > more fuel to facilitate that. > > Now I could be over looking something, so if you have some REAL > experience that might lend some credibility to your aurgument I'm > listening Warner. I'm interested in miles you have driven your NA, > average speed, speed on grades, that sort of thing. I assume you > have taken some trips, so lets hear what you have really seen for > fuel use. Those considering your FC might want to know. > > Mike Hohnstein > > ----- Original Message ----- > > From: Tom Warner > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, April 16, 2006 9:58 PM > > Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > I doubt very much if you will find an 87-89 FC that will even > get > > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I > believe > > the 4th gear is the same as the 5th or 6th gear in the 87-89. > > > > Tom Warner > > Vernon Center,NY > > 1982 FC35 ( for sale at > http://s69.photobucket.com/albums/i57/warbucks13477/ ) > > 1985 PT 40 > > > > > > At 09:55 PM 4/16/2006, you wrote: > > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway" > > > > > > >i hear storys from 7-10 mpg on the fcs with the 4 speed > > >tranny,now,thats not bad milage as i see it! > > >randy dupree > > > > Does anyone know if they ever put the 5 or 6 speed overdrive > > > > transmission in the 35 FC? If so, what year did they > start? I've > > > > zeroed in on the 35FC as the correct Bird for my wife and I, > > >however, I > > > > really hesitate buying one that gets such poor fuel mileage > as the 4 > > > > speed Allison. John & Pat - Wantabee's, Stuart > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > ><http://groups.yahoo.com/gads? > t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& > w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr > eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh > n_ObWmSYTw>Recreational > > >vehicles > > ><http://groups.yahoo.com/gads? > t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot > ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v > ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- > 8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > ><http://groups.yahoo.com/gads? > t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge > &w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec > reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm > y34cC1O9CxA>Automotive > > >maintenance > > ><http://groups.yahoo.com/gads? > t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander > lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use > d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah > aeYHfELr6o72IW1A>Recreational > > >vehicle dealer > > ><http://groups.yahoo.com/gads? > t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl > odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used > +recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km > 4L-kXbDI4ZSadEw>Used > > >recreational vehicles > > ><http://groups.yahoo.com/gads? > t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w > 3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre > ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT > nMq_4GlXA>Automotive > > >radiators > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" > on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > > > > >---------- > > > > > > > > > > > > > > > > --------------------------------------------------------------- ---- > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > --------------------------------------------------------------- ---- > ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > |
04-17-2006, 17:06
35 FC Transmissions
I belive there is a diffrence in lenght and weight between the two
coaches, kind of like apples and oranges Thanks Bruce Campbell 83FCSB "Blue Skies" slow,heavy,7-8mpg,running 60mph with gennie wide open --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > ---Mike: > That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg > consistently while my 90SP36 gets only 6-7mpg!!! That's a true > staement and NOT nuts! > Regards, > Hank Hannigan > 1990SP36 > > > > > > In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@> wrote: > > > > That's nuts. Turbo charging and charge air coolers are methods to > improve the efficiency of diesel engines. The 5 speed OD trans > keeps engine speed down and increased horse power improves the power > to weight ratio over the older NA/643 speed bumps. Most 87up FCs > have two airs and the smaller lighter gen set, handling and > acceleration are greatly enhanced. There is no way a NA gets better > mileage than a turbo, level playing field. > > I drove Millers 88 FC a while back and it was a night and day > diffference compared to my well tuned 250 hp 83 rear bath. > > Engine speed is the major issue when considering improving > milage. > > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm at > full throttle and don't need to go over 2500 rpm for max power. NAs > need to spin faster due to the lack of forced induction and need > more fuel to facilitate that. > > Now I could be over looking something, so if you have some REAL > experience that might lend some credibility to your aurgument I'm > listening Warner. I'm interested in miles you have driven your NA, > average speed, speed on grades, that sort of thing. I assume you > have taken some trips, so lets hear what you have really seen for > fuel use. Those considering your FC might want to know. > > Mike Hohnstein > > ----- Original Message ----- > > From: Tom Warner > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, April 16, 2006 9:58 PM > > Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > I doubt very much if you will find an 87-89 FC that will even > get > > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I > believe > > the 4th gear is the same as the 5th or 6th gear in the 87-89. > > > > Tom Warner > > Vernon Center,NY > > 1982 FC35 ( for sale at > http://s69.photobucket.com/albums/i57/warbucks13477/ ) > > 1985 PT 40 > > > > > > At 09:55 PM 4/16/2006, you wrote: > > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway" > > > > > > >i hear storys from 7-10 mpg on the fcs with the 4 speed > > >tranny,now,thats not bad milage as i see it! > > >randy dupree > > > > Does anyone know if they ever put the 5 or 6 speed overdrive > > > > transmission in the 35 FC? If so, what year did they > start? I've > > > > zeroed in on the 35FC as the correct Bird for my wife and I, > > >however, I > > > > really hesitate buying one that gets such poor fuel mileage > as the 4 > > > > speed Allison. John & Pat - Wantabee's, Stuart > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > ><http://groups.yahoo.com/gads? > t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& > w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr > eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh > n_ObWmSYTw>Recreational > > >vehicles > > ><http://groups.yahoo.com/gads? > t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot > ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v > ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- > 8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > ><http://groups.yahoo.com/gads? > t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge > &w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec > reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm > y34cC1O9CxA>Automotive > > >maintenance > > ><http://groups.yahoo.com/gads? > t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander > lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use > d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah > aeYHfELr6o72IW1A>Recreational > > >vehicle dealer > > ><http://groups.yahoo.com/gads? > t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl > odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used > +recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km > 4L-kXbDI4ZSadEw>Used > > >recreational vehicles > > ><http://groups.yahoo.com/gads? > t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w > 3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre > ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT > nMq_4GlXA>Automotive > > >radiators > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" > on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > > > > >---------- > > > > > > > > > > > > > > > > ------------------------------------------------------------------ - > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > ------------------------------------------------------------------ - > ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > |
04-17-2006, 17:06
35 FC Transmissions
You sound bitter.
MH ----- Original Message ----- From: Henry Jay Hannigan To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 17, 2006 11:33 PM Subject: [WanderlodgeForum] Re: 35 FC Transmissions ---Mike: You said an NA is "not good at all." I have a Mercedes NA diesel here in Australia and it is simply great! 4:11 diff and I get great mileage too. That ole 210NA CAT is great too!!I bet a lot of guys like their 210 CAT NA's!! Wish I had my old 77FC33 back!! Simple, 8-9mpg, a "thrill" to steer and noisy!! and...$100,000 less tied up in it!! Regards, Hank Hannigan 1990 SP36 (stored in VEGAS) In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > And I said level playing field. You want to talk about weight difference? How about speed? You are comparing apples to oranges and that IS nuts. NAs are nasty smoky obsolete and over the hill, at best. A diesel with out a turbo isn't good > not good at all. > MH > ----- Original Message ----- > From: Henry Jay Hannigan > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, April 17, 2006 8:55 PM > Subject: [WanderlodgeForum] Re: 35 FC Transmissions > > > ---Mike: > That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg > consistently while my 90SP36 gets only 6-7mpg!!! That's a true > staement and NOT nuts! > Regards, > Hank Hannigan > 1990SP36 > > > > > > In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@> wrote: > > > > That's nuts. Turbo charging and charge air coolers are methods to > improve the efficiency of diesel engines. The 5 speed OD trans > keeps engine speed down and increased horse power improves the power > to weight ratio over the older NA/643 speed bumps. Most 87up FCs > have two airs and the smaller lighter gen set, handling and > acceleration are greatly enhanced. There is no way a NA gets better > mileage than a turbo, level playing field. > > I drove Millers 88 FC a while back and it was a night and day > diffference compared to my well tuned 250 hp 83 rear bath. > > Engine speed is the major issue when considering improving > milage. > > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm at > full throttle and don't need to go over 2500 rpm for max power. NAs > need to spin faster due to the lack of forced induction and need > more fuel to facilitate that. > > Now I could be over looking something, so if you have some REAL > experience that might lend some credibility to your aurgument I'm > listening Warner. I'm interested in miles you have driven your NA, > average speed, speed on grades, that sort of thing. I assume you > have taken some trips, so lets hear what you have really seen for > fuel use. Those considering your FC might want to know. > > Mike Hohnstein > > ----- Original Message ----- > > From: Tom Warner > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, April 16, 2006 9:58 PM > > Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > I doubt very much if you will find an 87-89 FC that will even > get > > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I > believe > > the 4th gear is the same as the 5th or 6th gear in the 87-89. > > > > Tom Warner > > Vernon Center,NY > > 1982 FC35 ( for sale at > http://s69.photobucket.com/albums/i57/warbucks13477/ ) > > 1985 PT 40 > > > > > > At 09:55 PM 4/16/2006, you wrote: > > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway" > > > > > > >i hear storys from 7-10 mpg on the fcs with the 4 speed > > >tranny,now,thats not bad milage as i see it! > > >randy dupree > > > > Does anyone know if they ever put the 5 or 6 speed overdrive > > > > transmission in the 35 FC? If so, what year did they > start? I've > > > > zeroed in on the 35FC as the correct Bird for my wife and I, > > >however, I > > > > really hesitate buying one that gets such poor fuel mileage > as the 4 > > > > speed Allison. John & Pat - Wantabee's, Stuart > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > ><http://groups.yahoo.com/gads? > t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& > w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr > eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh > n_ObWmSYTw>Recreational > > >vehicles > > ><http://groups.yahoo.com/gads? > t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot > ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v > ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- > 8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > ><http://groups.yahoo.com/gads? > t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge > &w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec > reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm > y34cC1O9CxA>Automotive > > >maintenance > > ><http://groups.yahoo.com/gads? > t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander > lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use > d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah > aeYHfELr6o72IW1A>Recreational > > >vehicle dealer > > ><http://groups.yahoo.com/gads? > t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl > odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used > +recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km > 4L-kXbDI4ZSadEw>Used > > >recreational vehicles > > ><http://groups.yahoo.com/gads? > t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w > 3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre > ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT > nMq_4GlXA>Automotive > > >radiators > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" > on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > > > > >---------- > > > > > > > > > > > > > > > > --------------------------------------------------------------- ---- > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > --------------------------------------------------------------- ---- > ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-17-2006, 17:09
35 FC Transmissions
Naturally Warner will be detuning his PT.
MH ----- Original Message ----- From: Tom Warner To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 17, 2006 10:26 PM Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions Hank thats about what I am getting with my 1982 FC35 with the Cat 3208NA. People forget that turbo chargers and intercoolers do not make an engine more efficient they allow a denser fuel/air charge to be pumped into the cylinder. More fuel pumped into the cylinder means more fuel used. A horsepower increase from 210HP to 300HP in the same engine can only be realized thru the use of more fuel. There is no magic involved. Tom Warner Vernon Center,NY 1982 FC35 (for sale http://tinyurl.com/lotbdcan ) 1985 PT40 At 09:55 PM 4/17/2006, you wrote: >---Mike: >That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg >consistently while my 90SP36 gets only 6-7mpg!!! That's a true >staement and NOT nuts! >Regards, >Hank Hannigan >1990SP36 > > > > > >In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" ><MHOHNSTEIN@...> wrote: > > > > That's nuts. Turbo charging and charge air coolers are methods to >improve the efficiency of diesel engines. The 5 speed OD trans >keeps engine speed down and increased horse power improves the power >to weight ratio over the older NA/643 speed bumps. Most 87up FCs >have two airs and the smaller lighter gen set, handling and >acceleration are greatly enhanced. There is no way a NA gets better >mileage than a turbo, level playing field. > > I drove Millers 88 FC a while back and it was a night and day >diffference compared to my well tuned 250 hp 83 rear bath. > > Engine speed is the major issue when considering improving >milage. > > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm at >full throttle and don't need to go over 2500 rpm for max power. NAs >need to spin faster due to the lack of forced induction and need >more fuel to facilitate that. > > Now I could be over looking something, so if you have some REAL >experience that might lend some credibility to your aurgument I'm >listening Warner. I'm interested in miles you have driven your NA, >average speed, speed on grades, that sort of thing. I assume you >have taken some trips, so lets hear what you have really seen for >fuel use. Those considering your FC might want to know. > > Mike Hohnstein > > ----- Original Message ----- > > From: Tom Warner > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, April 16, 2006 9:58 PM > > Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > I doubt very much if you will find an 87-89 FC that will even >get > > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I >believe > > the 4th gear is the same as the 5th or 6th gear in the 87-89. > > > > Tom Warner > > Vernon Center,NY > > 1982 FC35 ( for sale at ><http://s69.photobucket.com/albums/i57/warbucks13477/>http://s69.photobucket.co\ m/albums/i57/warbucks13477/ >) > > 1985 PT 40 > > > > > > At 09:55 PM 4/16/2006, you wrote: > > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway" > > > > > > >i hear storys from 7-10 mpg on the fcs with the 4 speed > > >tranny,now,thats not bad milage as i see it! > > >randy dupree > > > > Does anyone know if they ever put the 5 or 6 speed overdrive > > > > transmission in the 35 FC? If so, what year did they >start? I've > > > > zeroed in on the 35FC as the correct Bird for my wife and I, > > >however, I > > > > really hesitate buying one that gets such poor fuel mileage >as the 4 > > > > speed Allison. John & Pat - Wantabee's, Stuart > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& >w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr >eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh >n_ObWmSYTw>Recreational > > >vehicles > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot >ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v >ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- >8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge >&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec >reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm >y34cC1O9CxA>Automotive > > >maintenance > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander >lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah >aeYHfELr6o72IW1A>Recreational > > >vehicle dealer > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl >odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used >+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km >4L-kXbDI4ZSadEw>Used > > >recreational vehicles > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w >3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre >ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT >nMq_4GlXA>Automotive > > >radiators > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/\ WanderlodgeForum>WanderlodgeForum" > >on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > > > > > >---------- > > > > > > > > > > > > > > > > ------------------------------------------------------------------- >----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms >of Service. > > > > > > ------------------------------------------------------------------- >----------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-17-2006, 17:16
35 FC Transmissions
You got that right Jerry.
MH ----- Original Message ----- From: Jerry To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 17, 2006 11:11 PM Subject: RE: [WanderlodgeForum] Re: 35 FC Transmissions Tom, a diesel or gasoline engine is an air breathing device. A turbo charger increases the amount of air it can breath. If the boost pressure provided is 14.7 PSI, the engine sees instead of the normal one atmosphere of pressure, two atmospheres. It is, at 14.7PSI of boost, without losses considerations, now twice the size engine. It does of course as you noted, take more fuel. The intercooler takes some of the heat out of the intake air, providing a denser, heavier fuel air mixture. The magic as I see it is the electronic controls and devices used today to not only lower emissions but also create more power with less fuel. Jerry MS Gulf Coast Looking for a BB _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner Sent: Monday, April 17, 2006 10:27 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions Hank thats about what I am getting with my 1982 FC35 with the Cat 3208NA. People forget that turbo chargers and intercoolers do not make an engine more efficient they allow a denser fuel/air charge to be pumped into the cylinder. More fuel pumped into the cylinder means more fuel used. A horsepower increase from 210HP to 300HP in the same engine can only be realized thru the use of more fuel. There is no magic involved. Tom Warner Vernon Center,NY 1982 FC35 (for sale http://tinyurl.com/lotbdcan ) 1985 PT40 At 09:55 PM 4/17/2006, you wrote: >---Mike: >That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg >consistently while my 90SP36 gets only 6-7mpg!!! That's a true >staement and NOT nuts! >Regards, >Hank Hannigan >1990SP36 > > > > > >In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" ><MHOHNSTEIN@...> wrote: > > > > That's nuts. Turbo charging and charge air coolers are methods to >improve the efficiency of diesel engines. The 5 speed OD trans >keeps engine speed down and increased horse power improves the power >to weight ratio over the older NA/643 speed bumps. Most 87up FCs >have two airs and the smaller lighter gen set, handling and >acceleration are greatly enhanced. There is no way a NA gets better >mileage than a turbo, level playing field. > > I drove Millers 88 FC a while back and it was a night and day >diffference compared to my well tuned 250 hp 83 rear bath. > > Engine speed is the major issue when considering improving >milage. > > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm at >full throttle and don't need to go over 2500 rpm for max power. NAs >need to spin faster due to the lack of forced induction and need >more fuel to facilitate that. > > Now I could be over looking something, so if you have some REAL >experience that might lend some credibility to your aurgument I'm >listening Warner. I'm interested in miles you have driven your NA, >average speed, speed on grades, that sort of thing. I assume you >have taken some trips, so lets hear what you have really seen for >fuel use. Those considering your FC might want to know. > > Mike Hohnstein > > ----- Original Message ----- > > From: Tom Warner > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, April 16, 2006 9:58 PM > > Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > I doubt very much if you will find an 87-89 FC that will even >get > > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I >believe > > the 4th gear is the same as the 5th or 6th gear in the 87-89. > > > > Tom Warner > > Vernon Center,NY > > 1982 FC35 ( for sale at ><http://s69.photobucket.com/albums/i57/warbucks13477/>http://s69.photobucke t.com/albums/i57/warbucks13477/ >) > > 1985 PT 40 > > > > > > At 09:55 PM 4/16/2006, you wrote: > > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway" > > > > > > >i hear storys from 7-10 mpg on the fcs with the 4 speed > > >tranny,now,thats not bad milage as i see it! > > >randy dupree > > > > Does anyone know if they ever put the 5 or 6 speed overdrive > > > > transmission in the 35 FC? If so, what year did they >start? I've > > > > zeroed in on the 35FC as the correct Bird for my wife and I, > > >however, I > > > > really hesitate buying one that gets such poor fuel mileage >as the 4 > > > > speed Allison. John & Pat - Wantabee's, Stuart > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& >w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr >eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh >n_ObWmSYTw>Recreational > > >vehicles > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot >ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v >ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- >8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge >&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec >reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm >y34cC1O9CxA>Automotive > > >maintenance > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander >lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah >aeYHfELr6o72IW1A>Recreational > > >vehicle dealer > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl >odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used >+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km >4L-kXbDI4ZSadEw>Used > > >recreational vehicles > > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w >3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre >ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT >nMq_4GlXA>Automotive > > >radiators > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/gr oup/WanderlodgeForum>WanderlodgeForum" > >on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > > > > > >---------- > > > > > > > > > > > > > > > > ------------------------------------------------------------------- >----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms >of Service. > > > > > > ------------------------------------------------------------------- >----------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > derlodgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> vehicles Wanderlodge <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> maintenance Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer Used <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> radiators _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-17-2006, 21:36
35 FC Transmissions
Mike:
u r rite about the wieght difference. lol Regards, Hank Hannigan 90SP36 In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > You sound bitter. > MH > ----- Original Message ----- > From: Henry Jay Hannigan > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, April 17, 2006 11:33 PM > Subject: [WanderlodgeForum] Re: 35 FC Transmissions > > > ---Mike: > > You said an NA is "not good at all." I have a Mercedes NA diesel > here in Australia and it is simply great! 4:11 diff and I get great > mileage too. > That ole 210NA CAT is great too!!I bet a lot of guys like their 210 > CAT NA's!! > > Wish I had my old 77FC33 back!! Simple, 8-9mpg, a "thrill" to > steer and noisy!! and...$100,000 less tied up in it!! > Regards, > Hank Hannigan > 1990 SP36 (stored in VEGAS) > > > In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@> wrote: > > > > And I said level playing field. You want to talk about weight > difference? How about speed? You are comparing apples to oranges > and that IS nuts. NAs are nasty smoky obsolete and over the hill, > at best. A diesel with out a turbo isn't good > > not good at all. > > MH > > ----- Original Message ----- > > From: Henry Jay Hannigan > > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, April 17, 2006 8:55 PM > > Subject: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > ---Mike: > > That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg > > consistently while my 90SP36 gets only 6-7mpg!!! That's a true > > staement and NOT nuts! > > Regards, > > Hank Hannigan > > 1990SP36 > > > > > > > > > > > > In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > > <MHOHNSTEIN@> wrote: > > > > > > That's nuts. Turbo charging and charge air coolers are > methods to > > improve the efficiency of diesel engines. The 5 speed OD trans > > keeps engine speed down and increased horse power improves the > power > > to weight ratio over the older NA/643 speed bumps. Most 87up > FCs > > have two airs and the smaller lighter gen set, handling and > > acceleration are greatly enhanced. There is no way a NA gets > better > > mileage than a turbo, level playing field. > > > I drove Millers 88 FC a while back and it was a night and day > > diffference compared to my well tuned 250 hp 83 rear bath. > > > Engine speed is the major issue when considering improving > > milage. > > > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm > at > > full throttle and don't need to go over 2500 rpm for max power. > NAs > > need to spin faster due to the lack of forced induction and need > > more fuel to facilitate that. > > > Now I could be over looking something, so if you have some > REAL > > experience that might lend some credibility to your aurgument > I'm > > listening Warner. I'm interested in miles you have driven your > NA, > > average speed, speed on grades, that sort of thing. I assume > you > > have taken some trips, so lets hear what you have really seen > for > > fuel use. Those considering your FC might want to know. > > > Mike Hohnstein > > > ----- Original Message ----- > > > From: Tom Warner > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Sunday, April 16, 2006 9:58 PM > > > Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > > > > I doubt very much if you will find an 87-89 FC that will > even > > get > > > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I > > believe > > > the 4th gear is the same as the 5th or 6th gear in the 87-89. > > > > > > Tom Warner > > > Vernon Center,NY > > > 1982 FC35 ( for sale at > > http://s69.photobucket.com/albums/i57/warbucks13477/ ) > > > 1985 PT 40 > > > > > > > > > At 09:55 PM 4/16/2006, you wrote: > > > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway" > > > > > > > > >i hear storys from 7-10 mpg on the fcs with the 4 speed > > > >tranny,now,thats not bad milage as i see it! > > > >randy dupree > > > > > Does anyone know if they ever put the 5 or 6 speed > overdrive > > > > > transmission in the 35 FC? If so, what year did they > > start? I've > > > > > zeroed in on the 35FC as the correct Bird for my wife > and I, > > > >however, I > > > > > really hesitate buying one that gets such poor fuel > mileage > > as the 4 > > > > > speed Allison. John & Pat - Wantabee's, Stuart > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > > ><http://groups.yahoo.com/gads? > > > t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& > > > w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr > > > eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh > > n_ObWmSYTw>Recreational > > > >vehicles > > > ><http://groups.yahoo.com/gads? > > > t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot > > > ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v > > ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- > > 8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > > ><http://groups.yahoo.com/gads? > > > t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge > > > &w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec > > > reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm > > y34cC1O9CxA>Automotive > > > >maintenance > > > ><http://groups.yahoo.com/gads? > > > t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander > > > lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use > > > d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah > > aeYHfELr6o72IW1A>Recreational > > > >vehicle dealer > > > ><http://groups.yahoo.com/gads? > > > t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl > > > odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used > > > +recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km > > 4L-kXbDI4ZSadEw>Used > > > >recreational vehicles > > > ><http://groups.yahoo.com/gads? > > > t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w > > > 3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre > > > ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT > > nMq_4GlXA>Automotive > > > >radiators > > > > > > > > > > > >---------- > > > >YAHOO! GROUPS LINKS > > > > > > > > * Visit your group > > > > > > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" > > on the web. > > > > * > > > > * To unsubscribe from this group, send an email to: > > > > * > > > > unsubscribe@yahoogroups.com > > > > > > > > * > > > > * Your use of Yahoo! Groups is subject to the > > > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > > > > > > > >---------- > > > > > > > > > > > > > > > > > > > > > > > > ----------------------------------------------------------- ---- > ---- > > ----------- > > > YAHOO! GROUPS LINKS > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > b.. To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! > Terms > > of Service. > > > > > > > > > ----------------------------------------------------------- ---- > ---- > > ----------- > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > --------------------------------------------------------------- ---- > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > --------------------------------------------------------------- ---- > ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > |
04-17-2006, 23:39
35 FC Transmissions
04-18-2006, 01:38
35 FC Transmissions
Spoken like a true technical illiterate. Sophisticated contempary fuel controls
are responsible for the greatly extended service life of engines, gasoline and diesel. Extrordinary horse power per cubic inch production is common place these days, dwarfing power levels of 20 years ago. There is a reason a 3208 10.3 litre engine is limited to 300 hp in highway use and an 8.3 litre Cummins routinely make in excess of 330, more if you can cool it. We work on many hot rod trucks in the shop and it's unbelievable how much punch these new fangled 5.9s can produce. Electronics are really magic. Expensive but very very cool. I wish I could retrofit my throwaways (3208) with new fuel controls. MH ----- Original Message ----- From: Tom Warner To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 17, 2006 11:28 PM Subject: RE: [WanderlodgeForum] Re: 35 FC Transmissions Jerry the electronic controls on todays diesel engine were installed to ensure that the engines meet the very stringent emission standards of today. They have not become more efficient they have become compliant with the laws at the expense of lowering their efficiency. They achieve that by creating more heat and thus run at higher temperatures, and they therefore need better lubricants and increased maintenance, at the same time of operating at reduced power. Remember there is always a tradeoff to everything. A gallon of diesel fuel contains approximately 140,000 BTUs. One horsepower equals 2545 BTUs per hour. Its easy to see that increased horsepower is only achieved thru packing more fuel/air mixture into the cylinders and efficiently exhausting it. Tom Warner Vernon Center,NY 1982 FC35 for sale ( http://tinyurl.com/zv2on ) 1985 PT40 . At 12:11 AM 4/18/2006, you wrote: >Tom, a diesel or gasoline engine is an air breathing device. A turbo >charger increases the amount of air it can breath. If the boost pressure >provided is 14.7 PSI, the engine sees instead of the normal one atmosphere >of pressure, two atmospheres. It is, at 14.7PSI of boost, without losses >considerations, now twice the size engine. It does of course as you noted, >take more fuel. The intercooler takes some of the heat out of the intake >air, providing a denser, heavier fuel air mixture. The magic as I see it is >the electronic controls and devices used today to not only lower emissions >but also create more power with less fuel. > > > >Jerry > >MS Gulf Coast > >Looking for a BB > > > > > > _____ > >From: WanderlodgeForum@yahoogroups.com >[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner >Sent: Monday, April 17, 2006 10:27 PM >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > >Hank thats about what I am getting with my 1982 FC35 with the Cat >3208NA. People forget that turbo chargers and intercoolers do not >make an engine more efficient they allow a denser fuel/air charge to >be pumped into the cylinder. More fuel pumped into the cylinder means >more fuel used. A horsepower increase from 210HP to 300HP in the same >engine can only be realized thru the use of more fuel. There is no >magic involved. > >Tom Warner >Vernon Center,NY >1982 FC35 (for sale <http://tinyurl.com/lotbdcan>http://tinyurl.com/lotbdcan ) >1985 PT40 > >At 09:55 PM 4/17/2006, you wrote: > >---Mike: > >That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg > >consistently while my 90SP36 gets only 6-7mpg!!! That's a true > >staement and NOT nuts! > >Regards, > >Hank Hannigan > >1990SP36 > > > > > > > > > > > >In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > ><MHOHNSTEIN@...> wrote: > > > > > > That's nuts. Turbo charging and charge air coolers are methods to > >improve the efficiency of diesel engines. The 5 speed OD trans > >keeps engine speed down and increased horse power improves the power > >to weight ratio over the older NA/643 speed bumps. Most 87up FCs > >have two airs and the smaller lighter gen set, handling and > >acceleration are greatly enhanced. There is no way a NA gets better > >mileage than a turbo, level playing field. > > > I drove Millers 88 FC a while back and it was a night and day > >diffference compared to my well tuned 250 hp 83 rear bath. > > > Engine speed is the major issue when considering improving > >milage. > > > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm at > >full throttle and don't need to go over 2500 rpm for max power. NAs > >need to spin faster due to the lack of forced induction and need > >more fuel to facilitate that. > > > Now I could be over looking something, so if you have some REAL > >experience that might lend some credibility to your aurgument I'm > >listening Warner. I'm interested in miles you have driven your NA, > >average speed, speed on grades, that sort of thing. I assume you > >have taken some trips, so lets hear what you have really seen for > >fuel use. Those considering your FC might want to know. > > > Mike Hohnstein > > > ----- Original Message ----- > > > From: Tom Warner > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Sunday, April 16, 2006 9:58 PM > > > Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > > > > I doubt very much if you will find an 87-89 FC that will even > >get > > > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I > >believe > > > the 4th gear is the same as the 5th or 6th gear in the 87-89. > > > > > > Tom Warner > > > Vernon Center,NY > > > 1982 FC35 ( for sale at > ><<http://s69.photobucket.com/albums/i57/warbucks13477/>http://s69.p > hotobucket.com/albums/i57/warbucks13477/>http://s69.photobucke >t.com/albums/i57/warbucks13477/ > >) > > > 1985 PT 40 > > > > > > > > > At 09:55 PM 4/16/2006, you wrote: > > > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway" > > > > > > > > >i hear storys from 7-10 mpg on the fcs with the 4 speed > > > >tranny,now,thats not bad milage as i see it! > > > >randy dupree > > > > > Does anyone know if they ever put the 5 or 6 speed overdrive > > > > > transmission in the 35 FC? If so, what year did they > >start? I've > > > > > zeroed in on the 35FC as the correct Bird for my wife and I, > > > >however, I > > > > > really hesitate buying one that gets such poor fuel mileage > >as the 4 > > > > > speed Allison. John & Pat - Wantabee's, Stuart > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://groups.ya\ hoo.com/gads? > >t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& > >w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr > >eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh > >n_ObWmSYTw>Recreational > > > >vehicles > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://groups.ya\ hoo.com/gads? > >t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot > >ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v > >ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- > >8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://groups.ya\ hoo.com/gads? > >t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge > >&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec > >reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm > >y34cC1O9CxA>Automotive > > > >maintenance > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://groups.ya\ hoo.com/gads? > >t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander > >lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use > >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah > >aeYHfELr6o72IW1A>Recreational > > > >vehicle dealer > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://groups.ya\ hoo.com/gads? > >t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl > >odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used > >+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km > >4L-kXbDI4ZSadEw>Used > > > >recreational vehicles > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://groups.ya\ hoo.com/gads? > >t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w > >3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre > >ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT > >nMq_4GlXA>Automotive > > > >radiators > > > > > > > > > > > >---------- > > > >YAHOO! GROUPS LINKS > > > > > > > > * Visit your group > > > > > > > > >"<<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/grou\ p/WanderlodgeForum>http://groups.yahoo.com/gr >oup/WanderlodgeForum>WanderlodgeForum" > > > >on the web. > > > > * > > > > * To unsubscribe from this group, send an email to: > > > > * > > > > > > > > > > > > * > > > > * Your use of Yahoo! Groups is subject to the > > > > > > ><<<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>http://d\ ocs.yahoo.com/info/terms/>Yahoo! > > > Terms of Service. > > > > > > > > > > > >---------- > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------- > >----------- > > > YAHOO! GROUPS LINKS > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > b.. To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > >of Service. > > > > > > > > > ------------------------------------------------------------------- > >----------- > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/\ WanderlodgeForum>WanderlodgeForum" > on the >web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > >derlodgeForum-unsubscribe@yahoogroups.com > > > > * > > * Your use of Yahoo! Groups is subject to the > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > > >---------- > > > > > > > > >SPONSORED LINKS > > >Recreational ><<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v>h\ ttp://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v >ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea >ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU >kCKkU7Dzhn_ObWmSYTw> vehicles > >Wanderlodge ><<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2>h\ ttp://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 >=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP >j9U0JvqYQ> > >Automotive ><<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+>h\ ttp://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ >vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de >aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF >4u_5wI8Pmy34cC1O9CxA> maintenance > > >Recreational ><<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati>h\ ttp://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati >onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic >le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s >ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer > >Used ><<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio>h\ ttp://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio >nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl >e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si >g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles > >Automotive ><<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve>h\ ttp://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve >hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal >er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV >MmISsCWgTnMq_4GlXA> radiators > > > > _____ > >YAHOO! GROUPS LINKS > > > >* Visit your group "WanderlodgeForum ><<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/\ WanderlodgeForum> >" on the web. > > >* To unsubscribe from this group, send an email to: >WanderlodgeForum-unsubscribe@yahoogroups.com > > > >* Your use of Yahoo! Groups is subject to the Yahoo! ><<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/> >Terms of Service. > > > > _____ > > > >[Non-text portions of this message have been removed] > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
User(s) browsing this thread: 11 Guest(s)
