Transmision Fluid?
04-23-2006, 01:41
Transmision Fluid?
Can someone please tell me the type of trans. fluid the allison uses,
the manual I have only says the amount it holds,it leaks a small amount out the copper tube that comes out the tranny where it tapers down to the drive shaft when its driven(overflow?), level seams fine but if I add some I would like to add the rite kind. Thankyou Very Much! Jeff and Michelle August 1980FC35RB(with a 89 motor) Plymouth Wi |
04-23-2006, 01:50
Transmision Fluid?
This is a link to Allison's approved fluid list
https://www.fuelsurvey.swri.org/C4/C4App...sting.aspx Ken Hunter Army Airfield, GA ----- Original Message ----- From: Jeff August To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 23, 2006 9:41 AM Subject: [WanderlodgeForum] Transmision Fluid? Can someone please tell me the type of trans. fluid the allison uses, the manual I have only says the amount it holds,it leaks a small amount out the copper tube that comes out the tranny where it tapers down to the drive shaft when its driven(overflow?), level seams fine but if I add some I would like to add the rite kind. Thankyou Very Much! Jeff and Michelle August 1980FC35RB(with a 89 motor) Plymouth Wi ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-23-2006, 02:26
Transmision Fluid?
Dextron 2 or 3 will work fine.
MH ----- Original Message ----- From: Jeff August To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 23, 2006 8:41 AM Subject: [WanderlodgeForum] Transmision Fluid? Can someone please tell me the type of trans. fluid the allison uses, the manual I have only says the amount it holds,it leaks a small amount out the copper tube that comes out the tranny where it tapers down to the drive shaft when its driven(overflow?), level seams fine but if I add some I would like to add the rite kind. Thankyou Very Much! Jeff and Michelle August 1980FC35RB(with a 89 motor) Plymouth Wi ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-23-2006, 02:47
Transmision Fluid?
Thanks Mike
--- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Dextron 2 or 3 will work fine. > MH > ----- Original Message ----- > From: Jeff August > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, April 23, 2006 8:41 AM > Subject: [WanderlodgeForum] Transmision Fluid? > > > Can someone please tell me the type of trans. fluid the allison uses, > the manual I have only says the amount it holds,it leaks a small amount > out the copper tube that comes out the tranny where it tapers down to > the drive shaft when its driven(overflow?), level seams fine but if I > add some I would like to add the rite kind. > Thankyou Very Much! > Jeff and Michelle August > 1980FC35RB(with a 89 motor) > Plymouth Wi > > > > > > > -------------------------------------------------------------------- ---------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > -------------------------------------------------------------------- ---------- > > > > [Non-text portions of this message have been removed] > |
