Antifreeze
06-09-2005, 12:19
Antifreeze
Hello Everyone,
Does anyone know what the PH level should be for the antifreeze in the Cat. 3208? Mine has been in this engine for over 4 years, and is showing a PH of 11 on the test strips I have. Is this to high, to low? Thanks, Larry Holland 82FC35 3208T Canandaigua, N.Y. |
06-09-2005, 13:24
Antifreeze
11 sure sounds high, possibly creating lots of deposits in the radiator
etc., but I really don't know as I simply go by the color-code on the bottle with the test-strips in it. What does your test-strip bottle say about the color? - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "Larry holland" > Hello Everyone, > > Does anyone know what the PH level should be for the antifreeze in > the > Cat. 3208? Mine has been in this engine for over 4 years, and is > showing a PH of 11 on the test strips I have. Is this to high, to low? > > Thanks, > Larry Holland > 82FC35 3208T > Canandaigua, N.Y. |
06-10-2005, 13:16
Antifreeze
---Jeff,
According to info. I get on the internet a PH of 11 would be acid. A Ph of 7 would be neutral, and any PH below a 7 would Alkaline. I do have a quart of CAT coolant additive that is very alkaline, but I don't know what the PH value should be. Better get to the local Cat dealer I guess. Larry Holland In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > 11 sure sounds high, possibly creating lots of deposits in the radiator > etc., but I really don't know as I simply go by the color-code on the > bottle with the test-strips in it. What does your test-strip bottle say > about the color? > > - Jeff Miller > > > --- In WanderlodgeForum@yahoogroups.com, "Larry holland" > > > Hello Everyone, > > > > Does anyone know what the PH level should be for the antifreeze in > > the > > Cat. 3208? Mine has been in this engine for over 4 years, and is > > showing a PH of 11 on the test strips I have. Is this to high, to low? > > > > Thanks, > > Larry Holland > > 82FC35 3208T > > Canandaigua, N.Y. |
06-11-2005, 13:26
Antifreeze
Cat tests coolant samples for about $15. They supply sample bottles
just like the oil test bottles. The test analysis printout covers multiple properties and advises recommended levels, required additives and whether to replace the coolant. The explanation on the back of the printout states: For ELC (extended life coolant?) pH minimum is 7.0, maximum is 10.0, recommended is 7.5-9.5 with ideal 8.5. For DEAC (?) pH minimum is 8.5, maximum is 11.0, recommended is 8.5-10.5 with ideal 9.5. With level too low ferrous metals and solder will be attacked and with level too high aluminum will be attacked. --- In WanderlodgeForum@yahoogroups.com, "Larry holland" > Hello Everyone, > > Does anyone know what the PH level should be for the antifreeze in > the > Cat. 3208? Mine has been in this engine for over 4 years, and is > showing a PH of 11 on the test strips I have. Is this to high, to low? > > Thanks, > Larry Holland > 82FC35 3208T > Canandaigua, N.Y. |
06-13-2005, 16:19
Antifreeze
At 6/11/2005 08:16 AM, Larry holland wrote:
>According to info. I get on the internet a PH of 11 would be acid. A >Ph of 7 would be neutral, and any PH below a 7 would Alkaline. I do >have a quart of CAT coolant additive that is very alkaline, but I >don't know what the PH value should be. Better get to the local Cat >dealer I guess. You're operating with bad information. pH below 7 is acidic, pH above 7 is alkaline. The further away from 7, the more {acidic,alkaline} it is. -- Dennis Nichols '88 WB40 XXV "Priscilla" -- No virus found in this outgoing message. Checked by AVG Anti-Virus. Version: 7.0.323 / Virus Database: 267.7.1 - Release Date: 6/13/2005 |
02-25-2006, 16:32
Antifreeze
on my trip out to az I started to use a lot of antifreez. Any one have
any suggestion to where to antifreez could be going? I check for leaks and don't find one. Could it be going into the oil? Does anyone know where I can get my oil checked in AZ? We had a new engine put in five years ago and now this started to happen. Joe in AZ 1984 1/2 PT 40 |
02-26-2006, 02:16
Antifreeze
Unfortunately: The coolant has to be going somewhere. How has your
temp. been running? Has it blown out of the expansion tank? Is your radiator cap not holding pressure? Are you using the correct coolant and is it ph balanced with additive? Check your oil stick and see if there is any frothy white on the stick. This would definitely indicate it was in the oil. If you are anywhere near a Speedco Truck Lube Center, take it there and let them do an oil analysis on the spot. Let us know what you discover. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "mjzakowski" <mjzakowski@...> wrote: > > on my trip out to az I started to use a lot of antifreez. Any one have > any suggestion to where to antifreez could be going? I check for leaks > and don't find one. Could it be going into the oil? Does anyone know > where I can get my oil checked in AZ? We had a new engine put in five > years ago and now this started to happen. > Joe in AZ 1984 1/2 PT 40 > |
02-26-2006, 09:19
Antifreeze
Joe, check the oil for anti-freeze; there are a number of ways that it can get
in the oil. Smell the dip stick and see if you detect anti-freeeze; better still you can put a bit of oil on your finger and taste it. You will taste the anti-freeze if it is there--I did not say swallow you notice. I had this experience with a 85 Detroit and it was a head gasket leaking. If you don't find my idea pallatable, oil test is only other answer. Wallace Craig 95WLWB42 Azle, Tx mjzakowski <mjzakowski@...> wrote: on my trip out to az I started to use a lot of antifreez. Any one have any suggestion to where to antifreez could be going? I check for leaks and don't find one. Could it be going into the oil? Does anyone know where I can get my oil checked in AZ? We had a new engine put in five years ago and now this started to happen. Joe in AZ 1984 1/2 PT 40 Yahoo! Groups Links --------------------------------- Yahoo! Mail Bring photos to life! New PhotoMail makes sharing a breeze. [Non-text portions of this message have been removed] |
02-26-2006, 15:15
Antifreeze
Joe, did you check the Trans fluid? If you find any milkey or foamy
fluid, put the bus on a flatbed for a flush and a new transcooler. ALso run the chassis heat and look for a leak at the cockpit or lines leading to the cockpit heater core. If you have a pinhole in a hose that is directed at the exhaust or turbo you will smell a sweet oder in the engine bay at high RPM's. I hope it is a simple fix Gregory O'Connor 94pt40 Romoland Ca --- In WanderlodgeForum@yahoogroups.com, "mjzakowski" <mjzakowski@...> wrote: > > on my trip out to az I started to use a lot of antifreez. Any one have > any suggestion to where to antifreez could be going? I check for leaks > and don't find one. Could it be going into the oil? Does anyone know > where I can get my oil checked in AZ? We had a new engine put in five > years ago and now this started to happen. > Joe in AZ 1984 1/2 PT 40 > |
04-29-2006, 12:34
Antifreeze
I have antifreeze in my oil. How did it get there?? If it is a head
gasket, what head could it be? Symptons?? Could it be the oil cooler? How can you tell? or could it be a cylinder gasket? How can one pinpoint the leak of antifreeze into the engine? I would like some input before I take it into a garage so I don't get taken down the pee patch. I live in northern Indiana and would like a good honest garage in or around the area. Joe 1984 1/2 PT 40 |
