Dometic refrigerator
09-23-2005, 01:07
Post: #21
An additional point to check; my Dometic had an
"in-line 12V fuse" located within the outside access hole compartment that was not shown on the schematics and that I discovered quite by accident. It was wrapped with electrician's tape making me believe it was a butt-splice that had been excessively taped. Upon unwrapping, it appeared as an original red #12 gauge, stranded wire, in-line, fuse connection and not someone's afterthought spliced into place. John Suter --- Blair > One quick point....the board needs a min of 12 volts > to operater.....check > your batteries...Blair > > > > > > At 08:16 PM 9/22/2005, you wrote: > >Bill, there are many things that can go wrong but > if you have power > >and gas then it gets smaller, you can call Dinasaur > Electronics > >directly and they have techs that will talk you > thru checking the > >board out and if it is a problem they will > reference you to a dealer > >they are not there to sell you anything but will > spend time helping > >you. I had a problem with my board they helped me > troubleshoot. I > >really appreciate there help and would recomend > them. > > > >John Mann > >1985 pt40 > >Granbury Tx > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, > "bill_brayton" > > > > > In my 78 FC the Dometic 3 way refer won't > operate as gas only. It > > > operates as DC and as AC without problem, but > the flame won't light. I > > > have recycled the system several times as > indicated in the manual. I > > > have bled the system at the back of the refer. > There is propane > > > flowing to the burner, but no ignition. > > > > > > The refer has not been on in a couple of months, > and the gas only mode > > > has seldom been used in the past couple of > years. What is the next > > > step in finding the problem? > > > > > > Bill Brayton > > > 78FC > > > Nordland, Wa. > > > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" > on the web. > > * > > * To unsubscribe from this group, send an > email to: > > * > > > odgeForum-unsubscribe@yahoogroups.com > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of > Service. > > > > > >---------- > > > [Non-text portions of this message have been > removed] > > __________________________________ Yahoo! Mail - PC Magazine Editors' Choice 2005 http://mail.yahoo.com |
10-15-2005, 04:41
Post: #22
We just purchased a 1988 FC in September and have put 4000 mostly pleasant
miles on her. She now needs a good vacuuming. My first question is: would anyone be willing to tell where the built in vac was located on this model? Slowly learning, John Barry 88FC Carlsbad, NM ----- Original Message ----- From: Blair To: WanderlodgeForum@yahoogroups.com Sent: Friday, September 23, 2005 6:20 AM Subject: Re: [WanderlodgeForum] Re: Dometic Refrigerator One quick point....the board needs a min of 12 volts to operater.....check your batteries...Blair At 08:16 PM 9/22/2005, you wrote: >Bill, there are many things that can go wrong but if you have power >and gas then it gets smaller, you can call Dinasaur Electronics >directly and they have techs that will talk you thru checking the >board out and if it is a problem they will reference you to a dealer >they are not there to sell you anything but will spend time helping >you. I had a problem with my board they helped me troubleshoot. I >really appreciate there help and would recomend them. > >John Mann >1985 pt40 >Granbury Tx > > > >--- In WanderlodgeForum@yahoogroups.com, "bill_brayton" > > > In my 78 FC the Dometic 3 way refer won't operate as gas only. It > > operates as DC and as AC without problem, but the flame won't light. I > > have recycled the system several times as indicated in the manual. I > > have bled the system at the back of the refer. There is propane > > flowing to the burner, but no ignition. > > > > The refer has not been on in a couple of months, and the gas only mode > > has seldom been used in the past couple of years. What is the next > > step in finding the problem? > > > > Bill Brayton > > 78FC > > Nordland, Wa. > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
10-16-2005, 20:33
Post: #23
John,
The built-in vacuum is located on the back wall of the driver's side closet in our WL. We made the mistake of having a "regular" hose made for our unit. Takes up too much room so we leave it at home. Bill & Rita in Roanoke, VA 1987 FC-35 SB [Non-text portions of this message have been removed] |
10-17-2005, 03:04
Post: #24
Our 73FC was made before Vacumes were installed, so I went to Sears,
and bought a "Wall Mounted Shop Unit", which is long and skinny. It is supposed to be rated at FIVE HP. Sounds a bit much!! Anyway, It mounts well in the back corner of the front closet. With the 18 foot hose, it will reach both ends of the coach and has a bunch of attachments, cost was (on Sale) $69.95..... Jack Smith 1973FC31 SoCal --- In WanderlodgeForum@yahoogroups.com, racin41@a... wrote: > > John, > > The built-in vacuum is located on the back wall of the driver's side closet > in our WL. > > We made the mistake of having a "regular" hose made for our unit. Takes up > too much room so we leave it at home. > > Bill & Rita in Roanoke, VA > 1987 FC-35 SB > > > [Non-text portions of this message have been removed] > |
05-06-2006, 10:09
Post: #25
Hi could anyone tell me if there is a replacement Fridge for model #
RM 1303 For a 1985 Bluebird 40 ft. that would fit the opening.. Everything that I have found are to big or to small.. Thanks in advance Mario |
05-06-2006, 12:34
Post: #26
You can use rm2820 With a small filler at the top. 0r 3862 or 3863
3863 by increasing the cutout height by abut 2". Allen Powell 88 WBWL40 |
05-06-2006, 14:18
Post: #27
Hi Mario,
We just got back today with a new frig put in by Camping World. It's the model RM2862. It's 59" high, 24" wide,24" deep..same dims as old model. I would think your dims are the same..cost for the Americana model was $1,183 plus $131 labor for install. Hope this helps. Bob Lawrence 84 PT36 Tacoma, Wa. > > Hi could anyone tell me if there is a replacement Fridge for model # > RM 1303 For a 1985 Bluebird 40 ft. that would fit the opening.. > Everything that I have found are to big or to small.. > > Thanks in advance > Mario > |
05-06-2006, 14:47
Post: #28
> Thanks For the quick reply Bob Mario 85 pt40 Lunenburg, Ma. > Hi Mario, > We just got back today with a new frig put in by Camping World. It's > the model RM2862. It's 59" high, 24" wide,24" deep..same dims as old > model. I would think your dims are the same..cost for the Americana > model was $1,183 plus $131 labor for install. Hope this helps. > > Bob Lawrence > 84 PT36 > Tacoma, Wa. > > > > Hi could anyone tell me if there is a replacement Fridge for model # > > RM 1303 For a 1985 Bluebird 40 ft. that would fit the opening.. > > Everything that I have found are to big or to small.. > > > > Thanks in advance > > Mario > > > |
05-07-2006, 14:13
Post: #29
Mario,
I also replaced my fridge with that model. About 1" shorter than the original. No problem for the boys at camping world, they made a piece to go in the bottom. Looks factory, no problem at all. Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "bestvalueworcester" <bestvalueworcester@...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > Thanks For the quick reply Bob > Mario > 85 pt40 > Lunenburg, Ma. > > Hi Mario, > > We just got back today with a new frig put in by Camping World. It's > > the model RM2862. It's 59" high, 24" wide,24" deep..same dims as old > > model. I would think your dims are the same..cost for the Americana > > model was $1,183 plus $131 labor for install. Hope this helps. > > > > Bob Lawrence > > 84 PT36 > > Tacoma, Wa. > > > > > > Hi could anyone tell me if there is a replacement Fridge for model # > > > RM 1303 For a 1985 Bluebird 40 ft. that would fit the opening.. > > > Everything that I have found are to big or to small.. > > > > > > Thanks in advance > > > Mario > > > > > > |
05-08-2006, 00:12
Post: #30
I just replaced my 29 year old Dometic RM100 with the Dometic Classic Series
RM2820 and it is the same size as the old box. Camping world has a chart that you take your old model number and it tell you the relpacement model. The clasic series is designed as a direct replacement. Byrne 77FC35 Louisiana Jay Darst Mario, I also replaced my fridge with that model. About 1" shorter than the original. No problem for the boys at camping world, they made a piece to go in the bottom. Looks factory, no problem at all. Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "bestvalueworcester" <bestvalueworcester@...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > Thanks For the quick reply Bob > Mario > 85 pt40 > Lunenburg, Ma. > > Hi Mario, > > We just got back today with a new frig put in by Camping World. It's > > the model RM2862. It's 59" high, 24" wide,24" deep..same dims as old > > model. I would think your dims are the same..cost for the Americana > > model was $1,183 plus $131 labor for install. Hope this helps. > > > > Bob Lawrence > > 84 PT36 > > Tacoma, Wa. > > > > > > Hi could anyone tell me if there is a replacement Fridge for model # > > > RM 1303 For a 1985 Bluebird 40 ft. that would fit the opening.. > > > Everything that I have found are to big or to small.. > > > > > > Thanks in advance > > > Mario > > > > > > SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- New Yahoo! Messenger with Voice. Call regular phones from your PC and save big. [Non-text portions of this message have been removed] |
