Reworked Alternator Tag
05-11-2006, 16:43
While fixing the problem I had with my cooling fan I decided to change
all the belts and since I was pulling all the belts I might as well pull the alternator and have it gone thru. It is a Leece-Neville and it has a label stuck over the data plate. It says "Reworked Alternator BB no.08258 Standard Alternator Will Not Work Properly" Anyone know what BlueBird reworked on their alternators? Also what is the normal life span of the water pump on a 3208,it wouldn't take much to change it now,The mileage on the coach is 71,000 and it looks like the cooling system was well maintained. Jim Matus 1984FC35SB Rescue CA |
05-11-2006, 21:35
the little oil cooler hoses were the ones that started leaking on my FC. You
have to have a good swing radiator to get to those- or a body of a teenager. Ernie-83pt40 in Texas [Non-text portions of this message have been removed] |
05-12-2006, 00:24
Miller knows what's up with the LN alternator. Do the water pump and change out
the oil cooler hoses. Don't forget to take your arrangement numbers to the Cat parts house. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: jim matus To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 11, 2006 11:43 PM Subject: [WanderlodgeForum] Reworked Alternator Tag While fixing the problem I had with my cooling fan I decided to change all the belts and since I was pulling all the belts I might as well pull the alternator and have it gone thru. It is a Leece-Neville and it has a label stuck over the data plate. It says "Reworked Alternator BB no.08258 Standard Alternator Will Not Work Properly" Anyone know what BlueBird reworked on their alternators? Also what is the normal life span of the water pump on a 3208,it wouldn't take much to change it now,The mileage on the coach is 71,000 and it looks like the cooling system was well maintained. Jim Matus 1984FC35SB Rescue CA SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
05-12-2006, 07:52
On the standard alternator, BlueBird removed the tab between the
voltage regulator terminal and the positive terminal. This is an external strip/tab, the one on the negative side stays. This allows the alternator to sense voltage remotely and charge the batteries at a more accurate charging voltage when there is a heavy load. If you install an alternator with this tab NOT removed, turning off the master 12v switch will cause the coach electrical systems to be powered through this tab and a small (16AWG?) wire, will burn up the wire if there is any significant load. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "jim matus" wrote: > > While fixing the problem I had with my cooling fan I decided to change > all the belts and since I was pulling all the belts I might as well > pull the alternator and have it gone thru. It is a Leece-Neville and it > has a label stuck over the data plate. It says "Reworked Alternator BB > no.08258 Standard Alternator Will Not Work Properly" Anyone know what > BlueBird reworked on their alternators? Also what is the normal life > span of the water pump on a 3208,it wouldn't take much to change it > now,The mileage on the coach is 71,000 and it looks like the cooling > system was well maintained. > Jim Matus 1984FC35SB Rescue CA > |
05-12-2006, 09:02
Jeff,
I had the Motorola alternator rebuilt before our winter trip. The master disconnect kill switch was in the "ON" position for over three months. Upon returning home, I began to again use the master disconnect switch. When switching to the "Off" position, there is now a voltage leak in the system, some on the relays will chatter. Especially the air step relays and the dash/ step/ open light will flicker. It seems to be a less than 12 volt leakage. To get a positive shut down, I now turn on a small load like a heater fan, then switch the master disconnect to the "OFF" position. Could this tab be my problem?? Is this tab on the Motorola?? Could the alternator rebuild shop have hooked up this tab?? Thanks, Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > On the standard alternator, BlueBird removed the tab between the > voltage regulator terminal and the positive terminal. This is an > external strip/tab, the one on the negative side stays. > > This allows the alternator to sense voltage remotely and charge the > batteries at a more accurate charging voltage when there is a heavy > load. > > If you install an alternator with this tab NOT removed, turning off the > master 12v switch will cause the coach electrical systems to be powered > through this tab and a small (16AWG?) wire, will burn up the wire if > there is any significant load. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "jim matus" > wrote: > > > > While fixing the problem I had with my cooling fan I decided to > change > > all the belts and since I was pulling all the belts I might as well > > pull the alternator and have it gone thru. It is a Leece-Neville and > it > > has a label stuck over the data plate. It says "Reworked Alternator > BB > > no.08258 Standard Alternator Will Not Work Properly" Anyone know what > > BlueBird reworked on their alternators? Also what is the normal life > > span of the water pump on a 3208,it wouldn't take much to change it > > now,The mileage on the coach is 71,000 and it looks like the cooling > > system was well maintained. > > Jim Matus 1984FC35SB Rescue CA > > > |
05-12-2006, 15:25
Not on the Motorola, I'm not aware of any '87-up coaches having this
arrangement but ?? I'd have to look at my '88 schematics to come up with a theory on that one, not tonight I'm afraid. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > > Jeff, > > I had the Motorola alternator rebuilt before our winter trip. > > The master disconnect kill switch was in the "ON" position for over > three months. Upon returning home, I began to again use the master > disconnect switch. When switching to the "Off" position, there is > now a voltage leak in the system, some on the relays will chatter. > Especially the air step relays and the dash/ step/ open light will > flicker. It seems to be a less than 12 volt leakage. > To get a positive shut down, I now turn on a small load like a > heater fan, then switch the master disconnect to the "OFF" position. > > Could this tab be my problem?? > Is this tab on the Motorola?? > Could the alternator rebuild shop have hooked up this tab?? > > Thanks, > > Bill 88 FC Michigan > > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > > > > On the standard alternator, BlueBird removed the tab between the > > voltage regulator terminal and the positive terminal. This is an > > external strip/tab, the one on the negative side stays. > > > > This allows the alternator to sense voltage remotely and charge > the > > batteries at a more accurate charging voltage when there is a > heavy > > load. > > > > If you install an alternator with this tab NOT removed, turning > off the > > master 12v switch will cause the coach electrical systems to be > powered > > through this tab and a small (16AWG?) wire, will burn up the wire > if > > there is any significant load. > > > > - Jeff Miller > > in Holland, MI > > > > > > --- In WanderlodgeForum@yahoogroups.com, "jim matus" > > wrote: > > > > > > While fixing the problem I had with my cooling fan I decided to > > change > > > all the belts and since I was pulling all the belts I might as > well > > > pull the alternator and have it gone thru. It is a Leece- Neville > and > > it > > > has a label stuck over the data plate. It says "Reworked > Alternator > > BB > > > no.08258 Standard Alternator Will Not Work Properly" Anyone know > what > > > BlueBird reworked on their alternators? Also what is the normal > life > > > span of the water pump on a 3208,it wouldn't take much to change > it > > > now,The mileage on the coach is 71,000 and it looks like the > cooling > > > system was well maintained. > > > Jim Matus 1984FC35SB Rescue CA > > > > > > |
05-12-2006, 23:01
Jeff,
Are all the Leece NeVilles built with that little tab? Thanks Jay Darst 85PT40 Spfld, IL --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > On the standard alternator, BlueBird removed the tab between the > voltage regulator terminal and the positive terminal. This is an > external strip/tab, the one on the negative side stays. > > This allows the alternator to sense voltage remotely and charge the > batteries at a more accurate charging voltage when there is a heavy > load. > > If you install an alternator with this tab NOT removed, turning off the > master 12v switch will cause the coach electrical systems to be powered > through this tab and a small (16AWG?) wire, will burn up the wire if > there is any significant load. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "jim matus" > wrote: > > > > While fixing the problem I had with my cooling fan I decided to > change > > all the belts and since I was pulling all the belts I might as well > > pull the alternator and have it gone thru. It is a Leece-Neville and > it > > has a label stuck over the data plate. It says "Reworked Alternator > BB > > no.08258 Standard Alternator Will Not Work Properly" Anyone know what > > BlueBird reworked on their alternators? Also what is the normal life > > span of the water pump on a 3208,it wouldn't take much to change it > > now,The mileage on the coach is 71,000 and it looks like the cooling > > system was well maintained. > > Jim Matus 1984FC35SB Rescue CA > > > |
05-13-2006, 15:25
Thanks Jeff, When I dropped the alternator off at the rebuild shop I
deal with the techs. there did not know what the rework might consist of,but they said they would give it back to me in the same configuration as it was. Now that I know I will make sure they don't install the tie. Jim Matus 1984 FC35SB Rescue CA WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > On the standard alternator, BlueBird removed the tab between the > voltage regulator terminal and the positive terminal. This is an > external strip/tab, the one on the negative side stays. > > This allows the alternator to sense voltage remotely and charge the > batteries at a more accurate charging voltage when there is a heavy > load. > > If you install an alternator with this tab NOT removed, turning off the > master 12v switch will cause the coach electrical systems to be powered > through this tab and a small (16AWG?) wire, will burn up the wire if > there is any significant load. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "jim matus" > wrote: > > > > While fixing the problem I had with my cooling fan I decided to > change > > all the belts and since I was pulling all the belts I might as well > > pull the alternator and have it gone thru. It is a Leece-Neville and > it > > has a label stuck over the data plate. It says "Reworked Alternator > BB > > no.08258 Standard Alternator Will Not Work Properly" Anyone know what > > BlueBird reworked on their alternators? Also what is the normal life > > span of the water pump on a 3208,it wouldn't take much to change it > > now,The mileage on the coach is 71,000 and it looks like the cooling > > system was well maintained. > > Jim Matus 1984FC35SB Rescue CA > > > |
