Ernie Broke Down
05-15-2006, 13:06
Ernie Broke Down
Just talked with Ernie about 10 minutes ago. He asked me tell
everyone that he won't have an internet connection until morning. Apparently the problem with the oil leak is caused by the fact that the turbo is loose on the manifold, no gasket or screen. It was blowing oil out of this joint. He found some good country boys in Childress, TX that found the problem very quickly. R.E. (Ron) Marabito, Dallas, TX 92WB40 |
05-15-2006, 13:38
Ernie Broke Down
Glad he caught it in time, I saw an '86 burned from an oil leak at
the turbo. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > Just talked with Ernie about 10 minutes ago. He asked me tell > everyone that he won't have an internet connection until morning. > > Apparently the problem with the oil leak is caused by the fact that > the turbo is loose on the manifold, no gasket or screen. It was > blowing oil out of this joint. He found some good country boys in > Childress, TX that found the problem very quickly. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > |
05-15-2006, 15:41
Ernie Broke Down
Gasket dressing is a critical factor on turbo reinstall. I
reinstalled a turbo several times (On a 115 hp tractor) only to have the gasket fail every time until I learned that the prep dressing I was using would make the gasket brittle at the high temps. The correct install was to use no dressing. (I do not know what DD dictates for reinstall) The only oil that leaked in my instance was the oil that passed the turbo Bearing seals. The intake gasket would have sent the oil to the pistons. I wonder if bearing lube is sealed with a gasket on Ernie's Bus. If not the B seals must be damaged. I damage Turbo seals, bearings and gaskets by shutting equipment down too quick. The tractors run at full RPM and when a project calls for quick shutdown, a turbos temp continue to get hotter as oil movement from the oil pump stops with ignition. Seems that seals at the bearings went before gaskets. Many over the road trucks have a delayed shutdown. The driver sets a time removes the key and the engine will shutdown after the cooldown time expires. --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > Just talked with Ernie about 10 minutes ago. He asked me tell > everyone that he won't have an internet connection until morning. > > Apparently the problem with the oil leak is caused by the fact that > the turbo is loose on the manifold, no gasket or screen. It was > blowing oil out of this joint. He found some good country boys in > Childress, TX that found the problem very quickly. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > |
05-15-2006, 15:44
Ernie Broke Down
Yes, it was good. That was my old coach and the in-frame overhaul was
done by the previous owner. I did not have any problem with that. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > Glad he caught it in time, I saw an '86 burned from an oil leak at > the turbo. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > Just talked with Ernie about 10 minutes ago. He asked me tell > > everyone that he won't have an internet connection until morning. > > > > Apparently the problem with the oil leak is caused by the fact that > > the turbo is loose on the manifold, no gasket or screen. It was > > blowing oil out of this joint. He found some good country boys in > > Childress, TX that found the problem very quickly. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > |
05-15-2006, 15:49
Ernie Broke Down
He told me that he had the bearing seals re-done not too long ago.
Any chance that that was not done correctly? R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Gasket dressing is a critical factor on turbo reinstall. I > reinstalled a turbo several times (On a 115 hp tractor) only to have > the gasket fail every time until I learned that the prep dressing I > was using would make the gasket brittle at the high temps. The > correct install was to use no dressing. (I do not know what DD > dictates for reinstall) The only oil that leaked in my instance was > the oil that passed the turbo Bearing seals. The intake gasket would > have sent the oil to the pistons. > > I wonder if bearing lube is sealed with a gasket on Ernie's Bus. If > not the B seals must be damaged. I damage Turbo seals, bearings and > gaskets by shutting equipment down too quick. The tractors run at > full RPM and when a project calls for quick shutdown, a turbos temp > continue to get hotter as oil movement from the oil pump stops with > ignition. Seems that seals at the bearings went before gaskets. > > Many over the road trucks have a delayed shutdown. The driver sets a > time removes the key and the engine will shutdown after the cooldown > time expires. --- In > WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > wrote: > > > > Just talked with Ernie about 10 minutes ago. He asked me tell > > everyone that he won't have an internet connection until morning. > > > > Apparently the problem with the oil leak is caused by the fact that > > the turbo is loose on the manifold, no gasket or screen. It was > > blowing oil out of this joint. He found some good country boys in > > Childress, TX that found the problem very quickly. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > |
