oil leak part 2
05-15-2006, 21:44
oil leak part 2
After the mechanics removed the turbo, they found the blower plate bolts
LOOSE!! They removed that plate to check the blower. The blower checked out fine-BUT- there was NO gasket between the plate and the engine. So, whoever did the inframe reman- left out the gasket. It really is rocket science!! No wonder I have been plagued with all this oil scum. More later- Erniie-83pt40 in Childress, Tx, for a short time, I hope [Non-text portions of this message have been removed] |
05-16-2006, 06:54
oil leak part 2
Hi Hank, thanks for the advice. I believe that it happenned before Ron
bought the coach . He had it for 6 years and we have had it for 4- so I don't even know if the previous, previous owner is still alive. Its gonna cost a liittle over $600 to get it fixed. BUT- if this corrects the oil leaks, its money well spent. These leaks we have been chasing for years. Ernie-83ptt40 in Childress-where is that place?-Texas [Non-text portions of this message have been removed] |
05-16-2006, 07:22
oil leak part 2
I don't know if Ron has any documentation about that repair. I don''t have
anything in my records. We'll see. Thanks, Ernie 83pt40 in Texas [Non-text portions of this message have been removed] |
05-16-2006, 08:21
oil leak part 2
George, thank you for that insight. Ernie-83pt40 waiting for parts- they
better show up tomorrow or I'll go really nuts in Childress, Tx [Non-text portions of this message have been removed] |
05-16-2006, 10:47
oil leak part 2
---Ernie:
Not sure what Texas legal ground u stand on as that rebuild was a while ago, however it was evidently done incorrectly. As such it has been a concern since day one of the rebuild. Recommend u chat with a Texas attorney(first visit free right?) about the traceable problem. Perhaps the attorney or you could m ake some noise to the rebuild company and request they pay your bill. No doubt their screwup caused it. LOL Hank Hannigan 90SP36 In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > After the mechanics removed the turbo, they found the blower plate bolts > LOOSE!! They removed that plate to check the blower. The blower checked out > fine-BUT- there was NO gasket between the plate and the engine. So, whoever did > the inframe reman- left out the gasket. It really is rocket science!! No > wonder I have been plagued with all this oil scum. More later- Erniie-83pt40 in > Childress, Tx, for a short time, I hope > > > [Non-text portions of this message have been removed] > |
05-16-2006, 11:12
oil leak part 2
---ERNIE:
If u no where the work was done, making some noise to the garage owner, with documented paperwork from the repair people showing absence of the gasket was the root cause of all the troubles since day one, could do some good. At least the original "fixer" would know that u r NOT going to say anything NICE about his repair shop if he does not "share" some of your expense. As a member of the Forum, YOU are a powerful voice to repair seekers. nuf said. LOL Hank Hannigan 90SP36 In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Hi Hank, thanks for the advice. I believe that it happenned before Ron > bought the coach . He had it for 6 years and we have had it for 4- so I don't even > know if the previous, previous owner is still alive. Its gonna cost a > liittle over $600 to get it fixed. BUT- if this corrects the oil leaks, its money > well spent. These leaks we have been chasing for years. Ernie- 83ptt40 in > Childress-where is that place?-Texas > > > [Non-text portions of this message have been removed] > |
05-16-2006, 12:18
oil leak part 2
Hank,
If I may chime in here as a repair shop owner and mechanic... If the bolts were loose and the gasket not present, is it possible that the bolts failed, came loose and the pressure blew the gasket out? The fact that no gasket was found only means "no gasket was found". It doesn't necessarily mean it was never installed. Tightening bolts stretches them and the resulting stretch provides a clamping force. If the bolts fail, they stretch too far, like a rubber band that was stretched too far and they get loose, since the clamping force is no longer present. This could allow the gasket to blow out from the pressure. Hence, no gasket could be found. Next, I believe Federal Law only requires a warranty to be 90 days or 3,000 miles on mechanical repairs, so any warranty would be up by now. Moral of the story: Be sure they throw out the bolts that were loose and use new ones. Once any bolt is found loose, you never "tighten them up" as they are probably stretched. Also be sure they use the proper grade of bolt and they're torqued to the proper spec for the grade and thread pitch. Each grade has a different torque spec and so does each thread pitch for that grade and size bolt. This is the reason my shop NEVER reuses cylinder head bolts when replacing a "blown head gasket", since the bolts could have stretched and caused the gasket to blow. Just some background from a mechanic's perspective... George Witt 81 FC 35 Lincoln, Nebraska --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > ---Ernie: > Not sure what Texas legal ground u stand on as that rebuild was a > while ago, however it was evidently done incorrectly. As such it has > been a concern since day one of the rebuild. Recommend u chat with > a Texas attorney(first visit free right?) about the traceable > problem. Perhaps the attorney or you could m ake some noise to the > rebuild company and request they pay your bill. No doubt their > screwup caused it. > LOL > Hank Hannigan > 90SP36 > > > > > > In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > After the mechanics removed the turbo, they found the blower plate > bolts > > LOOSE!! They removed that plate to check the blower. The blower > checked out > > fine-BUT- there was NO gasket between the plate and the engine. > So, whoever did > > the inframe reman- left out the gasket. It really is rocket > science!! No > > wonder I have been plagued with all this oil scum. More later- > Erniie-83pt40 in > > Childress, Tx, for a short time, I hope > > > > > > [Non-text portions of this message have been removed] > > > |
05-16-2006, 12:42
oil leak part 2
---Hey George!
Great reply from a mechanics view! ur correct about implied warranty of merchantabilty for only 90 days,. However, discovery comes into view also..and...if it is true that GASKET was NEVER installed, don't u thing the Installer owner has some good faith/good will obligation to respond? Also please note that I told Ernie to have the repair mechanic certify the "never installed" gasket fact in writing. Probably all moot and nothing will happen except Ernie will eat the bill, but if it were me, and...I had the facts, I would make a phone call to the garage owner where it was installed and share the story. Besides, I have nothing to do in retirement and was very bored as I have slowed my online poker down, so I thought I would respond to Ernie...AND I got SUNBURN laying on the beach at KOolina Resort yesterday. LOL Hank Hannigan 90SP36(stored inVegas but for sale so I can pay my Hawaii hotel bill) In Hawaii washing dishes..LOL In WanderlodgeForum@yahoogroups.com, "George Witt" <mrdonut12@...> wrote: > > Hank, > If I may chime in here as a repair shop owner and mechanic... > If the bolts were loose and the gasket not present, is it possible > that the bolts failed, came loose and the pressure blew the gasket out? > The fact that no gasket was found only means "no gasket was > found". It doesn't necessarily mean it was never installed. > Tightening bolts stretches them and the resulting stretch > provides a clamping force. If the bolts fail, they stretch too far, > like a rubber band that was stretched too far and they get loose, > since the clamping force is no longer present. This could allow the > gasket to blow out from the pressure. Hence, no gasket could be found. > Next, I believe Federal Law only requires a warranty to be 90 > days or 3,000 miles on mechanical repairs, so any warranty would be up > by now. > Moral of the story: Be sure they throw out the bolts that were > loose and use new ones. Once any bolt is found loose, you never > "tighten them up" as they are probably stretched. Also be sure they > use the proper grade of bolt and they're torqued to the proper spec > for the grade and thread pitch. Each grade has a different torque > spec and so does each thread pitch for that grade and size bolt. > This is the reason my shop NEVER reuses cylinder head bolts when > replacing a "blown head gasket", since the bolts could have stretched > and caused the gasket to blow. > Just some background from a mechanic's perspective... > > George Witt > 81 FC 35 > Lincoln, Nebraska > > > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > ---Ernie: > > Not sure what Texas legal ground u stand on as that rebuild was a > > while ago, however it was evidently done incorrectly. As such it has > > been a concern since day one of the rebuild. Recommend u chat with > > a Texas attorney(first visit free right?) about the traceable > > problem. Perhaps the attorney or you could m ake some noise to the > > rebuild company and request they pay your bill. No doubt their > > screwup caused it. > > LOL > > Hank Hannigan > > 90SP36 > > > > > > > > > > > > In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > > > After the mechanics removed the turbo, they found the blower plate > > bolts > > > LOOSE!! They removed that plate to check the blower. The blower > > checked out > > > fine-BUT- there was NO gasket between the plate and the engine. > > So, whoever did > > > the inframe reman- left out the gasket. It really is rocket > > science!! No > > > wonder I have been plagued with all this oil scum. More later- > > Erniie-83pt40 in > > > Childress, Tx, for a short time, I hope > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > |
05-16-2006, 12:51
oil leak part 2
If Ron had the coach for 6 years and Ernie for 4 then how could it be
possible that the gasket was never installed? It had to have been so why is this avenue even being discussed? I would look at whether the bolts had thread locker on them or not. But even then you are not going to get anyplace on a repair that was done over 10 years ago. Tom Warner Vernon Center,NY 1985 PT 40 At 08:42 PM 5/16/2006, you wrote: >---Hey George! > >Great reply from a mechanics view! ur correct about implied >warranty of merchantabilty for only 90 days,. However, discovery >comes into view also..and...if it is true that GASKET was NEVER >installed, don't u thing the Installer owner has some good >faith/good will obligation to respond? > >Also please note that I told Ernie to have the repair mechanic >certify the "never installed" gasket fact in writing. > >Probably all moot and nothing will happen except Ernie will eat the >bill, but if it were me, and...I had the facts, I would make a phone >call to the garage owner where it was installed and share the story. > >Besides, I have nothing to do in retirement and was very bored as I >have slowed my online poker down, so I thought I would respond to >Ernie...AND I got SUNBURN laying on the beach at KOolina Resort >yesterday. LOL >Hank Hannigan >90SP36(stored inVegas but for sale so I can pay my Hawaii hotel bill) >In Hawaii washing dishes..LOL > > > > > >In WanderlodgeForum@yahoogroups.com, "George Witt" <mrdonut12@...> >wrote: > > > > Hank, > > If I may chime in here as a repair shop owner and mechanic... > > If the bolts were loose and the gasket not present, is it >possible > > that the bolts failed, came loose and the pressure blew the gasket >out? > > The fact that no gasket was found only means "no gasket was > > found". It doesn't necessarily mean it was never installed. > > Tightening bolts stretches them and the resulting stretch > > provides a clamping force. If the bolts fail, they stretch too >far, > > like a rubber band that was stretched too far and they get loose, > > since the clamping force is no longer present. This could allow >the > > gasket to blow out from the pressure. Hence, no gasket could be >found. > > Next, I believe Federal Law only requires a warranty to be 90 > > days or 3,000 miles on mechanical repairs, so any warranty would >be up > > by now. > > Moral of the story: Be sure they throw out the bolts that >were > > loose and use new ones. Once any bolt is found loose, you never > > "tighten them up" as they are probably stretched. Also be sure >they > > use the proper grade of bolt and they're torqued to the proper spec > > for the grade and thread pitch. Each grade has a different torque > > spec and so does each thread pitch for that grade and size bolt. > > This is the reason my shop NEVER reuses cylinder head bolts >when > > replacing a "blown head gasket", since the bolts could have >stretched > > and caused the gasket to blow. > > Just some background from a mechanic's perspective... > > > > George Witt > > 81 FC 35 > > Lincoln, Nebraska > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > > > > ---Ernie: > > > Not sure what Texas legal ground u stand on as that rebuild was >a > > > while ago, however it was evidently done incorrectly. As such it >has > > > been a concern since day one of the rebuild. Recommend u chat >with > > > a Texas attorney(first visit free right?) about the traceable > > > problem. Perhaps the attorney or you could m ake some noise to >the > > > rebuild company and request they pay your bill. No doubt their > > > screwup caused it. > > > LOL > > > Hank Hannigan > > > 90SP36 > > > > > > > > > > > > > > > > > > In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > > > > > After the mechanics removed the turbo, they found the blower >plate > > > bolts > > > > LOOSE!! They removed that plate to check the blower. The >blower > > > checked out > > > > fine-BUT- there was NO gasket between the plate and the >engine. > > > So, whoever did > > > > the inframe reman- left out the gasket. It really is rocket > > > science!! No > > > > wonder I have been plagued with all this oil scum. More later- > > > Erniie-83pt40 in > > > > Childress, Tx, for a short time, I hope > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
05-16-2006, 14:33
oil leak part 2
> > ---Hey George! > > Great reply from a mechanics view! ur correct about implied > warranty of merchantabilty for only 90 days,. However, discovery > comes into view also..and...if it is true that GASKET was NEVER > installed, don't u thing the Installer owner has some good > faith/good will obligation to respond? Hank, Playing Devil's Advocate (and telling you what a Defense Attorney might say), the repair mechanic cannot possibly certify the gasket was "never installed" in writing or otherwise. I'm assuming the mechanic was not present when the engine was installed/assembled. That's the only situation in which the mechanic could truthfully state "the gasket was never installed". If he was there at the time, he could certify as such. If he wasn't present when this was done, he has no idea whether it was or wasn't. The mechanic could truthfully state, "the bolts were loose and no gasket was found", but there's nothing else to which he could testify and offer proof other than that to which he could testify he had personally observed. > > Also please note that I told Ernie to have the repair mechanic > certify the "never installed" gasket fact in writing. Based on.........? > > Probably all moot and nothing will happen except Ernie will eat the > bill, but if it were me, and...I had the facts, I would make a phone > call to the garage owner where it was installed and share the story. Unfortunately, there are only 2 I can validate and none that I see that can get Ernie out of writing a check. The good new is, any problem we have that can be fixed with money is minor indeed, compared to the ones that money can't fix. :o) George Witt 81 FC 35 Lincoln, Nebraska > > Besides, I have nothing to do in retirement and was very bored as I > have slowed my online poker down, so I thought I would respond to > Ernie...AND I got SUNBURN laying on the beach at KOolina Resort > yesterday. LOL > Hank Hannigan > 90SP36(stored inVegas but for sale so I can pay my Hawaii hotel bill) > In Hawaii washing dishes..LOL > > > > > > In WanderlodgeForum@yahoogroups.com, "George Witt" <mrdonut12@> > wrote: > > > > Hank, > > If I may chime in here as a repair shop owner and mechanic... > > If the bolts were loose and the gasket not present, is it > possible > > that the bolts failed, came loose and the pressure blew the gasket > out? > > The fact that no gasket was found only means "no gasket was > > found". It doesn't necessarily mean it was never installed. > > Tightening bolts stretches them and the resulting stretch > > provides a clamping force. If the bolts fail, they stretch too > far, > > like a rubber band that was stretched too far and they get loose, > > since the clamping force is no longer present. This could allow > the > > gasket to blow out from the pressure. Hence, no gasket could be > found. > > Next, I believe Federal Law only requires a warranty to be 90 > > days or 3,000 miles on mechanical repairs, so any warranty would > be up > > by now. > > Moral of the story: Be sure they throw out the bolts that > were > > loose and use new ones. Once any bolt is found loose, you never > > "tighten them up" as they are probably stretched. Also be sure > they > > use the proper grade of bolt and they're torqued to the proper spec > > for the grade and thread pitch. Each grade has a different torque > > spec and so does each thread pitch for that grade and size bolt. > > This is the reason my shop NEVER reuses cylinder head bolts > when > > replacing a "blown head gasket", since the bolts could have > stretched > > and caused the gasket to blow. > > Just some background from a mechanic's perspective... > > > > George Witt > > 81 FC 35 > > Lincoln, Nebraska > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > > > > ---Ernie: > > > Not sure what Texas legal ground u stand on as that rebuild was > a > > > while ago, however it was evidently done incorrectly. As such it > has > > > been a concern since day one of the rebuild. Recommend u chat > with > > > a Texas attorney(first visit free right?) about the traceable > > > problem. Perhaps the attorney or you could m ake some noise to > the > > > rebuild company and request they pay your bill. No doubt their > > > screwup caused it. > > > LOL > > > Hank Hannigan > > > 90SP36 > > > > > > > > > > > > > > > > > > In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > > > > > After the mechanics removed the turbo, they found the blower > plate > > > bolts > > > > LOOSE!! They removed that plate to check the blower. The > blower > > > checked out > > > > fine-BUT- there was NO gasket between the plate and the > engine. > > > So, whoever did > > > > the inframe reman- left out the gasket. It really is rocket > > > science!! No > > > > wonder I have been plagued with all this oil scum. More later- > > > Erniie-83pt40 in > > > > Childress, Tx, for a short time, I hope > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > |
