Need help (In regards to do not shift light)
05-18-2006, 01:11
Rick,
Is the red light near your left leg (sitting in the driver's seat) blinking out codes, and making a clicking sound? If so, I'd take it to Allison dealer, or at least give them a call and ask for some advice. Have you tried re-setting the trans microprocessor by removing all 12V power (shore line disconnected, coach batteries disconnected? My trans "glitches" once or so a year, with the "Do not shift" lighting...Luckily, all it needed was shutting everything off, which reset the computer, and restarting (per the Allison owner's handbook) All returns to normal. Maybe I'm just lucky. Let us know how you get it resolved...please. Kevin McKeown Yorba Linda, CA 1986 38' PT 8V92 [Non-text portions of this message have been removed] |
05-18-2006, 03:02
Have a 86PT38 8V92. The do not shift light is on and it will not shift
out of neutral. Have check fluid, ground wires and many other things. Did notice that the tachometer is showing the engine to be running between 1000 and 2100 rpm's. When i turn the high idle on it shows the engine running 1500 to 1700 rpm's. I turn it off and the engine slows back down to normal and the tachometer doesn't. Could this be giving a false signal to the transmission and causing the do not shift light to be on. If so were do i start looking for the problem. Any help would be appreciated. Best Regards, Rick Mcintire 86PT38 Patillo,Tx |
05-18-2006, 05:28
Rick:
Get a hold of Benny at BB. He should know how they are connected to each other. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "trautoranch" wrote: > > Have a 86PT38 8V92. The do not shift light is on and it will not shift > out of neutral. Have check fluid, ground wires and many other things. > Did notice that the tachometer is showing the engine to be running > between 1000 and 2100 rpm's. When i turn the high idle on it shows the > engine running 1500 to 1700 rpm's. I turn it off and the engine slows > back down to normal and the tachometer doesn't. Could this be giving a > false signal to the transmission and causing the do not shift light to > be on. If so were do i start looking for the problem. Any help would be > appreciated. > Best Regards, > Rick Mcintire > 86PT38 > Patillo,Tx > |
05-18-2006, 05:36
-Kevin,
No, the red light is not on. Allison had me check for the code and there was no flashing light. The only thing they had me do was unplug the control box under the dash for the transmission and that didn't work. I have not turned all the power off to the coach yet. Also allison had me unplug the plug that goes into the transmission and clean it and plug it back up. I guess we are going to have find a place to stay and have it towed into the shop. We are full timing it since being transfered to new job. Best Regards, Rick Mcintire 86PT38 Patillo,TX 1-800-999-7107 -- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > Rick, > > Is the red light near your left leg (sitting in the driver's seat) blinking > out codes, and making a clicking sound? If so, I'd take it to Allison > dealer, or at least give them a call and ask for some advice. > > Have you tried re-setting the trans microprocessor by removing all 12V power > (shore line disconnected, coach batteries disconnected? > > My trans "glitches" once or so a year, with the "Do not shift" > lighting...Luckily, all it needed was shutting everything off, which reset the computer, > and restarting (per the Allison owner's handbook) All returns to normal. > Maybe I'm just lucky. > > Let us know how you get it resolved...please. > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > 8V92 > > > [Non-text portions of this message have been removed] > |
05-18-2006, 05:45
--Ron, Thanks, I have called Benny and he just called back. They
think it is the tach sender or the tang drive. He is sending them to me. Hope this works and we can get her rolling again. Terri is ready to hit the road again. Best Regards, Rick Mcintire 86PT38 Patillo,Tx PS, Terri said Hi to both of you. - In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > Rick: > > Get a hold of Benny at BB. He should know how they are connected > to each other. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > --- In WanderlodgeForum@yahoogroups.com, "trautoranch" > wrote: > > > > Have a 86PT38 8V92. The do not shift light is on and it will not shift > > out of neutral. Have check fluid, ground wires and many other things. > > Did notice that the tachometer is showing the engine to be running > > between 1000 and 2100 rpm's. When i turn the high idle on it shows the > > engine running 1500 to 1700 rpm's. I turn it off and the engine slows > > back down to normal and the tachometer doesn't. Could this be giving a > > false signal to the transmission and causing the do not shift light to > > be on. If so were do i start looking for the problem. Any help would be > > appreciated. > > Best Regards, > > Rick Mcintire > > 86PT38 > > Patillo,Tx > > > |
05-18-2006, 06:16
I had a problem similar to this. The engine was idling just a little over what
the tranny brainboard would allow to shift. The solution was to disassemble and clean the throttle at the engine. It was really gunked up with oil, grease and dirt. Prior to that the throttle had been quite slow to respond, both up and down until finally it just wouldn't go low enough to shift. Works fine now. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: trautoranch To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 18, 2006 8:02 AM Subject: [WanderlodgeForum] Need help (In regards to do not shift light) Have a 86PT38 8V92. The do not shift light is on and it will not shift out of neutral. Have check fluid, ground wires and many other things. Did notice that the tachometer is showing the engine to be running between 1000 and 2100 rpm's. When i turn the high idle on it shows the engine running 1500 to 1700 rpm's. I turn it off and the engine slows back down to normal and the tachometer doesn't. Could this be giving a false signal to the transmission and causing the do not shift light to be on. If so were do i start looking for the problem. Any help would be appreciated. Best Regards, Rick Mcintire 86PT38 Patillo,Tx SPONSORED LINKS Recreational vehicles<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=\ Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehic\ le+rate&c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> Recreational vehicle financing<http://groups.yahoo.com/gads?t=ms&k=Recr...g&w1=\ Recreational+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+\ repair&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati\ onal+vehicle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> Recreational vehicle repair<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> Recreational vehicle rental<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> Recreational vehicle camper<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> Recreational vehicle rate<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=\ Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehic\ le+rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
05-18-2006, 06:51
-Dick, Thanks for information. I'am going to get a new tach sender
and tang drive. When i receive these items i will clean the throttle at the same time. It has never been cleaned since we have owned it. We live in the country down a rock road. Best Regards, Rick Mcintire 86PT38 Patillo,Tx -- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > I had a problem similar to this. The engine was idling just a little over what the tranny brainboard would allow to shift. The solution was to disassemble and clean the throttle at the engine. It was really gunked up with oil, grease and dirt. Prior to that the throttle had been quite slow to respond, both up and down until finally it just wouldn't go low enough to shift. Works fine now. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > ----- Original Message ----- > From: trautoranch > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, May 18, 2006 8:02 AM > Subject: [WanderlodgeForum] Need help (In regards to do not shift light) > > > Have a 86PT38 8V92. The do not shift light is on and it will not shift > out of neutral. Have check fluid, ground wires and many other things. > Did notice that the tachometer is showing the engine to be running > between 1000 and 2100 rpm's. When i turn the high idle on it shows the > engine running 1500 to 1700 rpm's. I turn it off and the engine slows > back down to normal and the tachometer doesn't. Could this be giving a > false signal to the transmission and causing the do not shift light to > be on. If so were do i start looking for the problem. Any help would be > appreciated. > Best Regards, > Rick Mcintire > 86PT38 > Patillo,Tx > > > > > > SPONSORED LINKS Recreational vehicles<http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Recreational+ vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreational+vehic le+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate& c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> Recreational vehicle financing<http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicle+financing&w1=Recreational+vehicles&w2=Recr eational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreatio nal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> Recreational vehicle repair<http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicle+repair&w1=Recreational+vehicles&w2=Recreat ional+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreational +vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> > Recreational vehicle rental<http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicle+rental&w1=Recreational+vehicles&w2=Recreat ional+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreational +vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> Recreational vehicle camper<http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicle+camper&w1=Recreational+vehicles&w2=Recreat ional+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreational +vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> Recreational vehicle rate<http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicle+rate&w1=Recreational+vehicles&w2=Recreatio nal+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreational+v ehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> > > > -------------------------------------------------------------------- ---------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum >" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum- unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. > > > -------------------------------------------------------------------- ---------- > > > > [Non-text portions of this message have been removed] > |
