Cylinder function SP36
06-05-2006, 05:48
What is the function of the metal cylinder with 2 hoses in it mounted
on the rear of the coach to the right of the radiator? Chuck Harrison 90 SP36 Akron, Ohio |
06-05-2006, 13:06
Chuck
Unless you speak about the air filter I can't find any thing I would describe as a cylinder. LT 90 SP in Eclectic, AL ----- Original Message ----- From: "williamcharrison" To: Sent: Monday, June 05, 2006 12:48 PM Subject: [WanderlodgeForum] Cylinder function SP36 > What is the function of the metal cylinder with 2 hoses in it mounted > on the rear of the coach to the right of the radiator? > > Chuck Harrison > 90 SP36 > Akron, Ohio > > > > > > > > > Yahoo! Groups Links > > > > > > > |
06-05-2006, 14:03
r u talking about ether bottle fo cold starts???? Hank 90SP36 In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" > > Chuck > Unless you speak about the air filter I can't find any thing I would > describe as a cylinder. > LT 90 SP in Eclectic, AL > ----- Original Message ----- > From: "williamcharrison" > To: > Sent: Monday, June 05, 2006 12:48 PM > Subject: [WanderlodgeForum] Cylinder function SP36 > > > > What is the function of the metal cylinder with 2 hoses in it mounted > > on the rear of the coach to the right of the radiator? > > > > Chuck Harrison > > 90 SP36 > > Akron, Ohio > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > |
06-05-2006, 23:43
Sounds like the engine/coolant heater on my FC. Turn on your engine
heater and you should be able to feel/hear it run. Good luck, Tim Hannink Winter Park, FL 1981 FC-33SB --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > What is the function of the metal cylinder with 2 hoses in it mounted > on the rear of the coach to the right of the radiator? > > Chuck Harrison > 90 SP36 > Akron, Ohio > |
06-06-2006, 01:21
Just above this "cylinder, is the mfg label for brake shoes and
chassis reference number. Just below it is an air valve. It is only visible when you raise the back cover. --- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" > > Chuck > Unless you speak about the air filter I can't find any thing I would > describe as a cylinder. > LT 90 SP in Eclectic, AL > ----- Original Message ----- > From: "williamcharrison" > To: > Sent: Monday, June 05, 2006 12:48 PM > Subject: [WanderlodgeForum] Cylinder function SP36 > > > > What is the function of the metal cylinder with 2 hoses in it mounted > > on the rear of the coach to the right of the radiator? > > > > Chuck Harrison > > 90 SP36 > > Akron, Ohio > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > |
06-06-2006, 01:24
The ether bottle is accessible from the air cleaner compartment.
This is accessible only after opening the radiator cover and raising it. --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > --- > > > > > > r u talking about ether bottle fo cold starts???? > Hank > > 90SP36 > > > In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" > > > > > Chuck > > Unless you speak about the air filter I can't find any thing I > would > > describe as a cylinder. > > LT 90 SP in Eclectic, > AL > > ----- Original Message ----- > > From: "williamcharrison" > > To: > > Sent: Monday, June 05, 2006 12:48 PM > > Subject: [WanderlodgeForum] Cylinder function SP36 > > > > > > > What is the function of the metal cylinder with 2 hoses in it > mounted > > > on the rear of the coach to the right of the radiator? > > > > > > Chuck Harrison > > > 90 SP36 > > > Akron, Ohio > > > > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > |
06-06-2006, 11:00
Power steering reservoir LT in Alabama
----- Original Message ----- From: "williamcharrison" To: Sent: Tuesday, June 06, 2006 8:21 AM Subject: [WanderlodgeForum] Re: Cylinder function SP36 > Just above this "cylinder, is the mfg label for brake shoes and > chassis reference number. Just below it is an air valve. It is only > visible when you raise the back cover. > > --- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" > >> >> Chuck >> Unless you speak about the air filter I can't find any thing I > would >> describe as a cylinder. >> LT 90 SP in Eclectic, > AL >> ----- Original Message ----- >> From: "williamcharrison" >> To: >> Sent: Monday, June 05, 2006 12:48 PM >> Subject: [WanderlodgeForum] Cylinder function SP36 >> >> >> > What is the function of the metal cylinder with 2 hoses in it > mounted >> > on the rear of the coach to the right of the radiator? >> > >> > Chuck Harrison >> > 90 SP36 >> > Akron, Ohio >> > >> > >> > >> > >> > >> > >> > >> > >> > Yahoo! Groups Links >> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > Yahoo! Groups Links > > > > > > > > |
