head lights
06-11-2006, 11:04
head lights
My 1988 FC 35 has excellent bright lites but the lows are like candles.
There are lots of Hi Tech replacements avaialble. BUT what is the correct beam #. This a 4 light rectanglar system. Something like a 6054 or?? All mine have on them is "2A1" Approx. 4 1/4 by 6.5 Bruce 1988 FC35 |
06-11-2006, 13:23
head lights
You may want to consider the headlight relay modification in
the 'Files' section, I did this on my 82 FC and it was like night and day. Scott Forman 82 FC35RB Memphis --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > My 1988 FC 35 has excellent bright lites but the lows are like candles. > There are lots of Hi Tech replacements avaialble. BUT what is the > correct beam #. This a 4 light rectanglar system. Something like a 6054 > or?? All mine have on them is "2A1" Approx. 4 1/4 by 6.5 > > Bruce 1988 FC35 > |
06-12-2006, 04:01
head lights
Bruce,
I upgraded my headlight system. What a difference! As Scott suggests you may want to do the same. I can provide you with a detail set of instructions, part numbers, etc. Send me a private email, or respond this email, so I have your email address and I'll send you a copy of what I have. Before the upgrade the low beams were basically useless as far as seeing the road. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Scott Forman wrote: > You may want to consider the headlight relay modification in > the 'Files' section, I did this on my 82 FC and it was like night and > day. > > Scott Forman > 82 FC35RB > Memphis > > --- In WanderlodgeForum@yahoogroups.com > > > > > > My 1988 FC 35 has excellent bright lites but the lows are like > candles. > > There are lots of Hi Tech replacements avaialble. BUT what is the > > correct beam #. This a 4 light rectanglar system. Something like a > 6054 > > or?? All mine have on them is "2A1" Approx. 4 1/4 by 6.5 > > > > Bruce 1988 FC35 > > > > |
06-12-2006, 11:34
head lights
Curt would this apply to my rig (94). I think my low beams could use some
improvement. My high beams are great. On 12/06/06, Curt Sprenger > > Bruce, > I upgraded my headlight system. What a difference! As Scott suggests you > may want to do the same. I can provide you with a detail set of > instructions, part numbers, etc. Send me a private email, or respond > this email, so I have your email address and I'll send you a copy of > what I have. Before the upgrade the low beams were basically useless as > far as seeing the road. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > Scott Forman wrote: > > > You may want to consider the headlight relay modification in > > the 'Files' section, I did this on my 82 FC and it was like night and > > day. > > > > Scott Forman > > 82 FC35RB > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > My 1988 FC 35 has excellent bright lites but the lows are like > > candles. > > > There are lots of Hi Tech replacements avaialble. BUT what is the > > > correct beam #. This a 4 light rectanglar system. Something like a > > 6054 > > > or?? All mine have on them is "2A1" Approx. 4 1/4 by 6.5 > > > > > > Bruce 1988 FC35 > > > > > > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
06-12-2006, 13:06
head lights
Curt,
Could send me a copy as well. Thanx Dick Hayden - '87 PT 38 - Lake Stevens, WA rhhayden@... ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 12, 2006 9:01 AM Subject: Re: [WanderlodgeForum] Re: head lights Bruce, I upgraded my headlight system. What a difference! As Scott suggests you may want to do the same. I can provide you with a detail set of instructions, part numbers, etc. Send me a private email, or respond this email, so I have your email address and I'll send you a copy of what I have. Before the upgrade the low beams were basically useless as far as seeing the road. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Scott Forman wrote: > You may want to consider the headlight relay modification in > the 'Files' section, I did this on my 82 FC and it was like night and > day. > > Scott Forman > 82 FC35RB > Memphis > > --- In WanderlodgeForum@yahoogroups.com > > > > > > My 1988 FC 35 has excellent bright lites but the lows are like > candles. > > There are lots of Hi Tech replacements avaialble. BUT what is the > > correct beam #. This a 4 light rectanglar system. Something like a > 6054 > > or?? All mine have on them is "2A1" Approx. 4 1/4 by 6.5 > > > > Bruce 1988 FC35 > > > > [Non-text portions of this message have been removed] |
06-12-2006, 13:39
head lights
Check the ground be for you get to carried away.
David T 89 fc 35 Wi > > My 1988 FC 35 has excellent bright lites but the lows are like candles. > There are lots of Hi Tech replacements avaialble. BUT what is the > correct beam #. This a 4 light rectanglar system. Something like a 6054 > or?? All mine have on them is "2A1" Approx. 4 1/4 by 6.5 > > Bruce 1988 FC35 > |
06-12-2006, 17:00
head lights
Rob, Curt built a relay setup for the tail lights on my 94pt that
made a huge difference in the rear. One thing he found was the pin connectors that plug into the Volvo lights are easy to mix up and infact were mixed up on my bus. When Curt fixed the mixup prior to the new relays in the rear, the headlights got brighter. The mixup also caused all the lights to dim when the turnsignal and brakes were used at the same time. . Bob Gradowski pointed out that the connector for the wire loom at the lift door gets loose and disconnects also. Gregory O'Connor 94pt Romoland Ca --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Curt would this apply to my rig (94). I think my low beams could use some > improvement. My high beams are great. > > On 12/06/06, Curt Sprenger > > > > Bruce, > > I upgraded my headlight system. What a difference! As Scott suggests you > > may want to do the same. I can provide you with a detail set of > > instructions, part numbers, etc. Send me a private email, or respond > > this email, so I have your email address and I'll send you a copy of > > what I have. Before the upgrade the low beams were basically useless as > > far as seeing the road. > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > Scott Forman wrote: > > |
06-12-2006, 17:59
head lights
Hi Greg, ya I know Curt has a few tricks up his sleeve. One of these days
I'm going to sneak down south into his neck of the woods and ambush him with some Modello Especial (sp). Did I say 'ambush'? I meant bribe. Ya bribe, that's the right word On 12/06/06, Gregory OConnor > > Rob, Curt built a relay setup for the tail lights on my 94pt that > made a huge difference in the rear. One thing he found was the pin > connectors that plug into the Volvo lights are easy to mix up and > infact were mixed up on my bus. When Curt fixed the mixup prior to > the new relays in the rear, the headlights got brighter. The mixup > also caused all the lights to dim when the turnsignal and brakes were > used at the same time. . Bob Gradowski pointed out that the connector > for the wire loom at the lift door gets loose and disconnects also. > Gregory O'Connor > 94pt Romoland Ca > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > Curt would this apply to my rig (94). I think my low beams could > use some > > improvement. My high beams are great. > > > > > On 12/06/06, Curt Sprenger > > > > > > Bruce, > > > I upgraded my headlight system. What a difference! As Scott > suggests you > > > may want to do the same. I can provide you with a detail set of > > > instructions, part numbers, etc. Send me a private email, or > respond > > > this email, so I have your email address and I'll send you a copy > of > > > what I have. Before the upgrade the low beams were basically > useless as > > > far as seeing the road. > > > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > Scott Forman wrote: > > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
06-13-2006, 01:16
head lights
Curt ,
Please send me a copy also. Howard Truitt truitt44@... ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 12, 2006 9:06 PM Subject: Re: [WanderlodgeForum] Re: head lights Curt, Could send me a copy as well. Thanx Dick Hayden - '87 PT 38 - Lake Stevens, WA rhhayden@... ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 12, 2006 9:01 AM Subject: Re: [WanderlodgeForum] Re: head lights Bruce, I upgraded my headlight system. What a difference! As Scott suggests you may want to do the same. I can provide you with a detail set of instructions, part numbers, etc. Send me a private email, or respond this email, so I have your email address and I'll send you a copy of what I have. Before the upgrade the low beams were basically useless as far as seeing the road. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Scott Forman wrote: > You may want to consider the headlight relay modification in > the 'Files' section, I did this on my 82 FC and it was like night and > day. > > Scott Forman > 82 FC35RB > Memphis > > --- In WanderlodgeForum@yahoogroups.com > > > > > > My 1988 FC 35 has excellent bright lites but the lows are like > candles. > > There are lots of Hi Tech replacements avaialble. BUT what is the > > correct beam #. This a 4 light rectanglar system. Something like a > 6054 > > or?? All mine have on them is "2A1" Approx. 4 1/4 by 6.5 > > > > Bruce 1988 FC35 > > > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
06-19-2006, 04:28
head lights
Curt, If you don't mind, I would appreciate a copy also.
Thanks, Alex Smith 82FC35 Tallahassee replytoalex@... Richard Hayden Curt, Could send me a copy as well. Thanx Dick Hayden - '87 PT 38 - Lake Stevens, WA rhhayden@... ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 12, 2006 9:01 AM Subject: Re: [WanderlodgeForum] Re: head lights Bruce, I upgraded my headlight system. What a difference! As Scott suggests you may want to do the same. I can provide you with a detail set of instructions, part numbers, etc. Send me a private email, or respond this email, so I have your email address and I'll send you a copy of what I have. Before the upgrade the low beams were basically useless as far as seeing the road. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Scott Forman wrote: > You may want to consider the headlight relay modification in > the 'Files' section, I did this on my 82 FC and it was like night and > day. > > Scott Forman > 82 FC35RB > Memphis > > --- In WanderlodgeForum@yahoogroups.com > > > > > > My 1988 FC 35 has excellent bright lites but the lows are like > candles. > > There are lots of Hi Tech replacements avaialble. BUT what is the > > correct beam #. This a 4 light rectanglar system. Something like a > 6054 > > or?? All mine have on them is "2A1" Approx. 4 1/4 by 6.5 > > > > Bruce 1988 FC35 > > > > [Non-text portions of this message have been removed] --------------------------------- Sneak preview the all-new Yahoo.com. It's not radically different. Just radically better. [Non-text portions of this message have been removed] |
