Power Steering Belt: Removal? Are two belts better than one?
06-16-2006, 15:58
Howdy,
I have a 1978 FC33, 3208NA, with disagreeable power steering (noise, high effort). I want to replace the power steering belt to rule it out. So I checked the files on this forum which state "2ea", My pump has one belt and a one-belt pulley. Note: there is an un-used V slot on the Crank Pulley, possibly intended to drive the PS pump. Can someone solve this mystery? Any advantage to two belts? In looking at the belt, it is behind two other belts, which go up to the fan with no obvious way to induce slack. Do I need to remove the radiator to change the PS belt? Is there a procedure (or diagram) someone can share with me. Thanks, Danny FC33, 1978 San Jose, CA |
06-17-2006, 01:56
My '81 has only one power steering belt - it goes around the crank
and pump pulleys only. It is behind at least two other belts on the crank pulley, both need to be removed in order to get it off. In order to get to them, you need to get behind the radiator. I have tightened my power steering belt without opening up the rad though, its not easy but was definately quicker than swinging the radiator. Good luck, Tim Hannink Winter Park, FL 1981 FC-33SB --- In WanderlodgeForum@yahoogroups.com, "Dan" > > Howdy, > > I have a 1978 FC33, 3208NA, with disagreeable power steering (noise, > high effort). > > I want to replace the power steering belt to rule it out. So I > checked the files on this forum which state "2ea", My pump has one > belt and a one-belt pulley. Note: there is an un-used V slot on the > Crank Pulley, possibly intended to drive the PS pump. Can someone > solve this mystery? Any advantage to two belts? > > In looking at the belt, it is behind two other belts, which go up to > the fan with no obvious way to induce slack. Do I need to remove the > radiator to change the PS belt? Is there a procedure (or diagram) > someone can share with me. > > Thanks, > > Danny > FC33, 1978 > San Jose, CA > |
06-17-2006, 04:09
Stop and think of all of the complaints you hear on this forum and
others about the power steering unit causing problems and making noise. If you install the correct number of belts and tension them properly as I noted then you should have no trouble for a long time. I decided on replacing all of the V belts on the engine every 2 years whether they looked good or not. I am sure there will be others that will poo poo this for a number of reasons. But my rationale is this. I do what ever preventative maintenance that will give me the smallest chance of breaking down on the road. Its easiest, cheapest and fastest to replace belts at home where I can do the work at my leisure and do it right. The installation of the belts and proper tensioning of them with the Kriket works. Once again put to much tension on the various belts and you run the risk of premature belt failure and problems with the power steering pump and engine coolant pump. However that is a decision each of you can make for yourselves. tom warner vernon center,ny 1985 PT 40 At 09:56 AM 6/17/2006, you wrote: >My '81 has only one power steering belt - it goes around the crank >and pump pulleys only. It is behind at least two other belts on the >crank pulley, both need to be removed in order to get it off. In >order to get to them, you need to get behind the radiator. I have >tightened my power steering belt without opening up the rad though, >its not easy but was definately quicker than swinging the radiator. > >Good luck, > >Tim Hannink >Winter Park, FL >1981 FC-33SB > >--- In > >"Dan" > > > > Howdy, > > > > I have a 1978 FC33, 3208NA, with disagreeable power steering >(noise, > > high effort). > > > > I want to replace the power steering belt to rule it out. So I > > checked the files on this forum which state "2ea", My pump has one > > belt and a one-belt pulley. Note: there is an un-used V slot on >the > > Crank Pulley, possibly intended to drive the PS pump. Can someone > > solve this mystery? Any advantage to two belts? > > > > In looking at the belt, it is behind two other belts, which go up >to > > the fan with no obvious way to induce slack. Do I need to remove >the > > radiator to change the PS belt? Is there a procedure (or diagram) > > someone can share with me. > > > > Thanks, > > > > Danny > > FC33, 1978 > > San Jose, CA > > > > |
06-17-2006, 05:31
Hi Tim,
Thanks four sounding in on this. I think we have the same setup, two belts blocking the removal path of the PS belt. I found some BB documetation indicating one belt was standard. Thanks for the adjusting comments. But, unfortuately my PS belt has no molding definition left - i.e. there are no edges remaining - everything is rounded, so I think it needs replacing. Question: When your coach is not rolling, can you turn the wheel with normal effort and no noise? Thanks, Danny FC33 1978 San Jose, CA --- In WanderlodgeForum@yahoogroups.com, "Tim Hannink" > > My '81 has only one power steering belt - it goes around the crank > and pump pulleys only. It is behind at least two other belts on the > crank pulley, both need to be removed in order to get it off. In > order to get to them, you need to get behind the radiator. I have > tightened my power steering belt without opening up the rad though, > its not easy but was definately quicker than swinging the radiator. > > Good luck, > > Tim Hannink > Winter Park, FL > 1981 FC-33SB |
06-17-2006, 06:21
> Question: When your coach is not rolling, can you turn the wheel > with normal effort and no noise? I can when its warm, but its pretty noisy when cold. I very seldom do it and avoid doing it as much as possible. My daily driver has no power steering so it pretty instinctive for me to only turn the wheel when the vehicle is in motion. Good luck, Tim Hannink Winter Park, FL 1981 FC-33SB |
06-17-2006, 11:56
Hi Tom,
I agree, it's better to labor at home than fowl up a trip/vacation. My coach's PS pump pulley lacks a second V groove - it can take just one belt. However, I am thinking that two belts confer the following benefits, 1. redundancy, and 2. less lateral strain on the pump bearings. If smart people like you agree with me, then I am going to hunt down or make a pulley with two V grooves! Thanks, Danny FC33, 1978 San Jose, CA --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Stop and think of all of the complaints you hear on this forum and > others about the power steering unit causing problems and making > noise. If you install the correct number of belts and tension them > properly as I noted then you should have no trouble for a long time. > I decided on replacing all of the V belts on the engine every 2 years > whether they looked good or not. I am sure there will be others that > will poo poo this for a number of reasons. But my rationale is this. > I do what ever preventative maintenance that will give me the > smallest chance of breaking down on the road. Its easiest, cheapest > and fastest to replace belts at home where I can do the work at my > leisure and do it right. The installation of the belts and proper > tensioning of them with the Kriket works. > Once again put to much tension on the various belts and you run the > risk of premature belt failure and problems with the power steering > pump and engine coolant pump. However that is a decision each of you > can make for yourselves. > > tom warner > vernon center,ny > 1985 PT 40 > > > At 09:56 AM 6/17/2006, you wrote: > > >My '81 has only one power steering belt - it goes around the crank > >and pump pulleys only. It is behind at least two other belts on the > >crank pulley, both need to be removed in order to get it off. In > >order to get to them, you need to get behind the radiator. I have > >tightened my power steering belt without opening up the rad though, > >its not easy but was definately quicker than swinging the radiator. > > > >Good luck, > > > >Tim Hannink > >Winter Park, FL > >1981 FC-33SB > > > >--- In > > > >"Dan" > > > > > > Howdy, > > > > > > I have a 1978 FC33, 3208NA, with disagreeable power steering > >(noise, > > > high effort). > > > > > > I want to replace the power steering belt to rule it out. So I > > > checked the files on this forum which state "2ea", My pump has one > > > belt and a one-belt pulley. Note: there is an un-used V slot on > >the > > > Crank Pulley, possibly intended to drive the PS pump. Can someone > > > solve this mystery? Any advantage to two belts? > > > > > > In looking at the belt, it is behind two other belts, which go up > >to > > > the fan with no obvious way to induce slack. Do I need to remove > >the > > > radiator to change the PS belt? Is there a procedure (or diagram) > > > someone can share with me. > > > > > > Thanks, > > > > > > Danny > > > FC33, 1978 > > > San Jose, CA > > > > > > > > |
06-17-2006, 13:21
Yes sir, I agree with you completely and I added to that list
pressurized radiator caps, thermostats, minor water carrying pressurized hoses, sending units etc. These items are cheaper than being towed outa who knows where. Leroy Eckert 1990 WB-40 Niceville,FL --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Stop and think of all of the complaints you hear on this forum and > others about the power steering unit causing problems and making > noise. If you install the correct number of belts and tension them > properly as I noted then you should have no trouble for a long time. > I decided on replacing all of the V belts on the engine every 2 years > whether they looked good or not. I am sure there will be others that > will poo poo this for a number of reasons. But my rationale is this. > I do what ever preventative maintenance that will give me the > smallest chance of breaking down on the road. Its easiest, cheapest > and fastest to replace belts at home where I can do the work at my > leisure and do it right. The installation of the belts and proper > tensioning of them with the Kriket works. > Once again put to much tension on the various belts and you run the > risk of premature belt failure and problems with the power steering > pump and engine coolant pump. However that is a decision each of you > can make for yourselves. > > tom warner > vernon center,ny > 1985 PT 40 > > > At 09:56 AM 6/17/2006, you wrote: > > >My '81 has only one power steering belt - it goes around the crank > >and pump pulleys only. It is behind at least two other belts on the > >crank pulley, both need to be removed in order to get it off. In > >order to get to them, you need to get behind the radiator. I have > >tightened my power steering belt without opening up the rad though, > >its not easy but was definately quicker than swinging the radiator. > > > >Good luck, > > > >Tim Hannink > >Winter Park, FL > >1981 FC-33SB > > > >--- In > > > >"Dan" > > > > > > Howdy, > > > > > > I have a 1978 FC33, 3208NA, with disagreeable power steering > >(noise, > > > high effort). > > > > > > I want to replace the power steering belt to rule it out. So I > > > checked the files on this forum which state "2ea", My pump has one > > > belt and a one-belt pulley. Note: there is an un-used V slot on > >the > > > Crank Pulley, possibly intended to drive the PS pump. Can someone > > > solve this mystery? Any advantage to two belts? > > > > > > In looking at the belt, it is behind two other belts, which go up > >to > > > the fan with no obvious way to induce slack. Do I need to remove > >the > > > radiator to change the PS belt? Is there a procedure (or diagram) > > > someone can share with me. > > > > > > Thanks, > > > > > > Danny > > > FC33, 1978 > > > San Jose, CA > > > > > > > > |
06-17-2006, 17:05
Leroy I agree with you. I save the old belts that I take off and use
them as spares, same with coolant hoses. They will normally work fine if they have to be installed away from home until I get back home and put new ones on. There is a reason for that. I dont believe it is a good idea to store new belts for they will deteriorate with age. I prefer to install new ones. When I sold my FC35 gave the new owner another starter, belts,hoses,Cat 3208 pan gaskets,filters,new LN 160 alternator and lots of other spare parts. I carry 4 double sided plastic see thru parts boxes (actually fishing tackle boxes) that I have picked up at garage sales for a couple of dollars each. In one of them I have all of the tools and parts to repair anything in the dash within reason of course. In the others I carry hose clamps, shrink wrap of different sizes, metal self tapping screws, tape, one of each relay in the coach and generator, a dozen Bosch relays and sockets, and lots of other things. Another special box holds my A/C gauges and O rings. Not much that I cant do even on the road. Am in the process of designing a cherry finish tool box to fit in the place where the Snap on box once was. Fellow that owned the coach before me wouldnt part with it(cant blame him). I can carry a lot more tools in one specifically designed for the tools I have. Tom Warner Vernon Center,NY 1985 PT 40 At 09:21 PM 6/17/2006, you wrote: >Yes sir, I agree with you completely and I added to that list >pressurized radiator caps, thermostats, minor water carrying >pressurized hoses, sending units etc. These items are cheaper than >being towed outa who knows where. > >Leroy Eckert >1990 WB-40 >Niceville,FL > >--- In > >Tom Warner >wrote: > > > > Stop and think of all of the complaints you hear on this forum and > > others about the power steering unit causing problems and making > > noise. If you install the correct number of belts and tension them > > properly as I noted then you should have no trouble for a long >time. > > I decided on replacing all of the V belts on the engine every 2 >years > > whether they looked good or not. I am sure there will be others >that > > will poo poo this for a number of reasons. But my rationale is >this. > > I do what ever preventative maintenance that will give me the > > smallest chance of breaking down on the road. Its easiest, cheapest > > and fastest to replace belts at home where I can do the work at my > > leisure and do it right. The installation of the belts and proper > > tensioning of them with the Kriket works. > > Once again put to much tension on the various belts and you run the > > risk of premature belt failure and problems with the power steering > > pump and engine coolant pump. However that is a decision each of >you > > can make for yourselves. > > > > tom warner > > vernon center,ny > > 1985 PT 40 > > > > > > At 09:56 AM 6/17/2006, you wrote: > > > > >My '81 has only one power steering belt - it goes around the crank > > >and pump pulleys only. It is behind at least two other belts on the > > >crank pulley, both need to be removed in order to get it off. In > > >order to get to them, you need to get behind the radiator. I have > > >tightened my power steering belt without opening up the rad though, > > >its not easy but was definately quicker than swinging the radiator. > > > > > >Good luck, > > > > > >Tim Hannink > > >Winter Park, FL > > >1981 FC-33SB > > > > > >--- In > > > ahoogroups.com, > > > >"Dan" > > > > > > > > Howdy, > > > > > > > > I have a 1978 FC33, 3208NA, with disagreeable power steering > > >(noise, > > > > high effort). > > > > > > > > I want to replace the power steering belt to rule it out. So I > > > > checked the files on this forum which state "2ea", My pump has >one > > > > belt and a one-belt pulley. Note: there is an un-used V slot on > > >the > > > > Crank Pulley, possibly intended to drive the PS pump. Can >someone > > > > solve this mystery? Any advantage to two belts? > > > > > > > > In looking at the belt, it is behind two other belts, which go >up > > >to > > > > the fan with no obvious way to induce slack. Do I need to remove > > >the > > > > radiator to change the PS belt? Is there a procedure (or >diagram) > > > > someone can share with me. > > > > > > > > Thanks, > > > > > > > > Danny > > > > FC33, 1978 > > > > San Jose, CA > > > > > > > > > > > > > > |
06-18-2006, 04:24
Dan, two belts is not always better than one. If tension are
identical on a set and the set age identical and react to heat identical it may help. If factors differ on a set, one belt will fail early and throw the other of a set and/or other appliance belts. Belts now use a softer rubber and stronger cord. the tension specs were written for the belts of the time. Lateral strain - two belts with 30 lbs tension each on a pully put 30 lbs tension on the pully so does three and one belt . I find that appliances that startup reguardless of engine rpms require the shared torque start up strain spread out between belts. I dont think redundancy was a factor in engineering the requirement for the two belts. When I wash an engine down I keep degreaser and light oil solvent (diesel) away from the belts and hoses. I think they do damage to the rubber? Make a pully? wish you lived more south! I agree with Tom on the age replacement factor but every so often I replace the spare belts in my tool box (Irish trait called "Ima gonna" often trumped by other traits). The older a mechanic gets the more PM he/she does, I wonder if that is because there is more time or there is more learned experience? Gregory O'Connor 94pt Romoland Ca Imagonna take the Christmass lights down this weekend for sure. --- In WanderlodgeForum@yahoogroups.com, "Dan" > > Hi Tom, > > I agree, it's better to labor at home than fowl up a trip/vacation. > > My coach's PS pump pulley lacks a second V groove - it can take just > one belt. However, I am thinking that two belts confer the following > benefits, 1. redundancy, and 2. less lateral strain on the pump > bearings. If smart people like you agree with me, then I am going to > hunt down or make a pulley with two V grooves! > > Thanks, > > Danny > FC33, 1978 > San Jose, CA > > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > wrote: > > I decided on replacing all of the V belts on the engine every 2 > years > > whether they looked good or not. I am sure there will be others > that > > will poo poo this for a number of reasons. But my rationale is > this. > > I do what ever preventative maintenance that will give me the > > smallest chance of breaking down on the road. Its easiest, > cheapest > > and fastest to replace belts at home where I can do the work at my > > leisure and do it right. > > tom warner > > vernon center,ny > > 1985 PT 40 > > |
06-18-2006, 06:07
Gregg if the requirement is for two belts then two belts should be
used and as you noted it is not for reducdancy. The friction between the sides of the belt and the pully are what gives you the power transmission that is required. Its the tension on the belt that ensures that the belt makes good contact with the pully. So two belts will have twice as much power handling ability as one belt. But with that said two belts will put twice as much load on the bearings of the power steering pump also not the same as with one belt. . I only use Gates V80 belts all of which are automatically matched with any other Gates V80 belt of the same size. Takes the guesswork out of selecting belts. There is a rather complicated way to mathematically calculate the size belt required for any two or more pullys and the minimum tension required to transmit a specific power but Gates simplified this by showing how tools like the Kriket can take the guess work out of it. If you inspect the sides of a V belt and it is shiny then there is slippage in the belt and you need to find out why. Carefully check the contour of the belt with the pully and make sure they match. http://tinyurl.com/rng9m Tom Warner Vernon Center,NY At 12:24 PM 6/18/2006, you wrote: >Dan, two belts is not always better than one. If tension are >identical on a set and the set age identical and react to heat >identical it may help. If factors differ on a set, one belt will >fail early and throw the other of a set and/or other appliance belts. >Belts now use a softer rubber and stronger cord. the tension specs >were written for the belts of the time. > >Lateral strain - two belts with 30 lbs tension each on a pully put >30 lbs tension on the pully so does three and one belt . I find that >appliances that startup reguardless of engine rpms require the shared >torque start up strain spread out between belts. I dont think >redundancy was a factor in engineering the requirement for the two >belts. >When I wash an engine down I keep degreaser and light oil solvent >(diesel) away from the belts and hoses. I think they do damage to the >rubber? > >Make a pully? wish you lived more south! > >I agree with Tom on the age replacement factor but every so often I >replace the spare belts in my tool box (Irish trait called "Ima >gonna" often trumped by other traits). The older a mechanic gets the >more PM he/she does, I wonder if that is because there is more time >or there is more learned experience? > >Gregory O'Connor >94pt Romoland Ca >Imagonna take the Christmass lights down this weekend for sure. > >--- In > >"Dan" > > > > Hi Tom, > > > > I agree, it's better to labor at home than fowl up a trip/vacation. > > > > My coach's PS pump pulley lacks a second V groove - it can take >just > > one belt. However, I am thinking that two belts confer the >following > > benefits, 1. redundancy, and 2. less lateral strain on the pump > > bearings. If smart people like you agree with me, then I am going >to > > hunt down or make a pulley with two V grooves! > > > > Thanks, > > > > Danny > > FC33, 1978 > > San Jose, CA > > > > > > --- In > > Tom Warner > > wrote: > > > I decided on replacing all of the V belts on the engine every 2 > > years > > > whether they looked good or not. I am sure there will be others > > that > > > will poo poo this for a number of reasons. But my rationale is > > this. > > > I do what ever preventative maintenance that will give me the > > > smallest chance of breaking down on the road. Its easiest, > > cheapest > > > and fastest to replace belts at home where I can do the work at >my > > > leisure and do it right. > > tom warner > > > vernon center,ny > > > 1985 PT 40 > > > > > |
User(s) browsing this thread: 13 Guest(s)
